Lockitize Your Lock Screen v1.1 - Thay đổi giao diện Lockscreen cho iPhone [11/07/201
AnhPheCT
$0.99
Category: Utilities
Jul 07, 2011
Version: 1.1
2.5 MB
Seller: Kuhlmanation, LLC
© 2011 Kuhlmanation
LANGUAGES: English
REQUIREMENTS: Compatible with iPhone, iPod touch, and iPad. Requires iOS 4.0 or later.
Description
**Rated Top 5 in Utilities**
**Rated Top 75 in Overall App Store**
Statistics show that the illusion of security adds real security, especially against the annoying nosy casual snooper. Like placing a fake security sign outside your home, you can enjoy increased security without sacrificing convenience. The next time someone is messing with your phone, they will think it is locked. Only you know that it is just as easy to unlock as it ever was.
This app gives you the perfect combination between having perceived security without having to peck at numbers or letters every time you want to use your phone.
Four types of Lockitization:
1. Numeric entry similar to the built-in look and feel of the device.
2. Alpha-numeric similar to built-in look and feel of the device.
3. Android-like "connect-the-dots" security.
4. Faux-Fingerprint scanner.
How to "Lockitize Your Lock Screen"
1. Select a lock screen image or take a new picture. Both options are built into the app.
2. Move and scale the image to your satisfaction.
3. Press "Lockitize" to select one of the security options.
4. Save the final image to your library.
5. Set the new image to your lock screen wallpaper.
** Hopefully, by now, you understand this is not a real security system for your device. It is meant only to give the perception of security against the meddlesome scumpling.
What's new in Version 1.1
- Retina resolution upgrade
- Graphics tweaks
