http://hi.baidu.com/汉化浪子
Regarding
On the test
Produced using normal text of the dictionary:
Save the dictionary (&S)
Select(&O)
Help(&H)
Select(&O)
Please select Chinese Resource Kit:
Please select English Resource Kit:
Dictionary of the merger:
Save the dictionary(&S)
Select(&O)
Help(&H)
Select(&O)
Please select the second dictionary file:
Please select a dictionary file:
The use of mobile resources, the production of Chinese dictionaries:
Select(&O)
Help(&H)
Select(& O)
Please select the mobile Chinese Chinese Resource Kit:
Please select the mobile Chinese English Resource Kit:
Streamline the dictionary:
Select(&O)
Help(&H)
More than the combined dictionary
Chinese dictionary tool Madman
Please select the dictionary file sharing
Paper(&F)
Share(&S)
Share Information
Please enter the dictionary description:
Please enter your e-mail:
Please enter the dictionary version:
Please enter the name of the dictionary:
Please enter your name:
Close(&C)
View other Share Information(&I)
Share dictionary
EXE file is automatically Chinese help for this function is finished off their previous software version instance, had previously finished S software version 1.0, they have a Chinese version, there are S software version 1.0 in English, but now S Software Update to 1.1 If S is not software EXE file can also be re-finished look, but if a large EXE file .... you can use the automatic function of the use of Chinese Methods: 1.0 English 1.0 Chinese Version EXE choose EXE choice of 1.1 English version of Chinese EXE automatic choice to save the file, the effectiveness and S Chinese software is identical to 1.0, finished all the data and S are the same 1.0 software, so that the new version of the word EXE has been the almost finished, You can update the new Chinese words. If you can not automatically finished the following reasons may be unable to automatically sinicized 1: your choice is not the same version of the EXE file (old version) 2: the failure of automatic shell, shell manually and then automatically finished
EXE automatic Chinese help
Please select the English version of an earlier version of EXE file EXE
Please choose an earlier version of Chinese Version EXE file EXE
Please select the English version of the new EXE file EXE
Automatic Chinese(&A)
Help(&H)
Please choose an earlier version of the English EXE file
Please choose an earlier version of Chinese EXE file
Export Dictionary(&C)
Help(&H)
EXE extraction Dictionary
EXE file dictionary to help this feature extraction is mainly directed against their own previous version of the software have been finished for example, had previously finished S software version 1.0, they have a Chinese version, there are S software version 1.0 in English, but now S Software Update to 1.1, If S is not software EXE file can also be re-finished look, but if a large EXE file .... you can use the dictionary feature extraction. Usage: select 1.0 select 1.0 English version of Chinese Version of EXE export EXE dictionary if you can not export the dictionary! The following reasons may be unable to export the dictionary 1: your choice is not the same version of the EXE file 2: the failure of automatic shell, shell manually and then export the dictionary
EXE file extracted dictionary to help
Bulk shell / single drag and drop files directly to the software interface automatically shell pack
Information(&I)
Help(&H)
Volume pack(&P)
Shell volume(&U)
Please select the shell pack folder after the file is saved
Select(&S)
Please select shell pack folder
Select(&S)
Batch filepack shell-EXE-DLL-Chinese prodigal
Document shell pack information
This form used to show that the word did not find, for some special the RSC may find some words, then we should use this function, will not be displayed below have been found words, if there is word that the right You have to manually Han "
If the following appears in English, these words can not use the language of the tool, please use 16 hex editor to manually Chinese
See there is no Chinese word
Offset current:
Amend the Offset Address:
Modify the word type:
Modify(&O)
Help(&H)
Download video tutorial(&S)
Amend the Offset + type
If you modify the interface to open the following chart, note this address is wrong, here we are can be identified. The beginning of the word should be 04 from the first beginning.
Therefore, we plan for the next as long as the amendments to it.
Do not modify the type of word, if you determine the type of error, and then modify!
Modified to help offset address
English
Chinese
Word type
Input Chinese characters:
F1 please add the revised list of Chinese data to Chinese A code RSC word when double-click the list of amendments to address The proposal to complete a Chinese dictionary files saved finished according EXE Enter data directly into line Double-click the losers "
Online translation(&F)
Add the Chinese(&Z)
Chinese shut down to preserve the form(&Q)
toolStrip1
Automatic translation(&X)
If you choose the automatic post-translational only the automatic translation of a word Please choose an "automatic translation" ----------------- ------ Click the list to stop automatic translation
Modified
If you find the address and the actual data migration manually modify different data
Show no Chinese word
This feature is mainly used for show did not find the words, for some special the RSC may find some words, then we should use this function, will not be displayed below the word has been found If there is word that the right You have to manually Han "
FFFF
When the Chinese when the length is less than the English, more over what to replace the use of English characters can be a word for each separate set of default FFFF
To search for data input -> Enter
Results:
Chinese undo (& C)
menuStrip1
Chinese list
Menu
Paper(&F)
Open the file(&O)
Open File: you want to open a Chinese language resource file
Save Chinese file(&S)
Save Chinese file: Save the file after you finished!
Save the resource file(&R)
Save the resource file: the resources txt file to a text file!
Exit(&E)
Exit: from the software!
Chinese(&Z)
The beginning of Chinese(&K)
Chinese dictionary(&D)
Chinese use of the dictionary, after the software update (the software you are finished) You can also complete the first time Chinese dictionary!
The production of the dictionary(&M)
The production of the dictionary: the production of the current resource file's dictionary
Into the dictionary(&R)
Into the dictionary: into the existing dictionary file
Export Dictionary(&U)
Export dictionaries: Export Chinese dictionary is conducive to the future to support the export!
Dictionary merger(&H)
EXE automatic language(&A)
Select an earlier version of the English EXE, choose an earlier version of the Chinese EXE, select the new version of the English EXE, a new version of the Chinese Auto Chinese EXE
MBM Chinese(&M)
Dictionary(&D)
Extraction of the dictionary-RSC(&R)
Tips from the RSC file dictionary function, from 1.0 and 1.0 English language version of RSC export RSC dictionary
Extraction of the dictionary-EXE(&E)
Exe file from the dictionary features tips, from 1.0 and 1.0 English language version exe export dictionary exe
Dictionary production(&D)
Create your own dictionary
Dictionary to share(&S)
To share their own dictionary to the network
See share(&V)
Show has benefited from the sharing of information
Other(&O)
pack shell(&U)
Bulk shellpack
RSC signature file(&S)
Set(&S)
Set(&S)
Settings: Set some common properties of software
Help(&H)
Online video(&A)
Online video: Open the online video tutorials
A video tutorial code RSC Chinese(&A)
U Code RSC Chinese Video Tutorial(&U)
PYC Chinese video tutorial(&P)
EXE Chinese video tutorial(&E)
Video download(&D)
A Code RSC finished downloading the video tutorials(&A)
U Code RSC Chinese download video tutorial(&I)
Chinese PYC download video tutorial(&W)
Chinese EXE download video tutorial(&R)
Video tutorial download software settings(&J)
Bookmark - extract RSC dictionary - the dictionary extract EXE - EXE automatic Chinese video tutorial(&O)
Modified offset address of 16 hexadecimal video tutorial(&H)
Chinese madman-1.8-video tutorial - Find the same word - no Chinese words to view - other(&B)
Tutorial page(&W)
Guide page: Open the web page tutorial
Chinese lunatics -12 seconds basic use of course the Chinese finished their work
Opda(&O)
Cnpda(&C)
Download Doc file(&D)
Basic use of lunatics Chinese Course - Chinese version of document type language dictionary + Share
Opda(&O)
Cnpda(&C)
Madman Chinese Dictionary of Graphic Tutorial combat the production of articles! by Gates
Opda(&O)
Cnpda(&C)
On(&A)
On the software(&T)
On the software: Some of the information on the software!
Suggestions(&I)
Views on the test: tested the software / staff mentioned that the proposed
Test(&S)
toolStrip1
Open File
Chinese dictionary
Export Dictionary (&U)
Save Chinese
Not open the file
Chinese lunatics 2.3 By C # Code HanHuaLangZi
Please select the MBM file - unpack MBM file
Mbm Extract-V-2009.08.02 Usage: to open a MBM file, the software will automatically send your choice of MBM file copied to the C: \ \ under decompression, when You can directly modify the folder "
MBM Chinese
Please select a RSC file [ASCII encoded files]
Open(&O)
Please enter the contents of the signature
On(&A)
Delete(&D)
Show(&V)
Signature(&S)
If you enter the Chinese can not be Please press Ctrl + space the best use of Chinese information, do not enter the English, figures. If you enter these, others 16 M will be able to see very intuitive, so use Chinese bar. "
R ** Sign RSC document signed by Chinese prodigal
R ** Please select the English version of a document version number to the same
Select(&Y)
Please select Chinese Version R ** document version number to the same
Select(&O)
Export Dictionary
Delete(&D)
When you want to delete the contents of a selected, press the "Enter" to delete!
Delete(&R)
Delete selected(&S)
Delete all the same(&A)
Modify(&S)
Help(&H)
Modify(&S)
Delete(&D)
Delete selected(&S)
Help(&H)
RSC extracted dictionary
Can be re-finished look, but if a lot RSC file .... you can use the dictionary feature extraction. Usage: select 1.0 select 1.0 English language version of RSC Export RSC can be a dictionary to explain here but, not all resources can be derived dictionaries, for example, in the RSC, the word Chinese is Chinese manual words, 0408 0F00 2000 20E0 2020 words this fact will not be able to export the dictionary functions: support of the amendments to the list of the contents of a list of content to support the deletion of the same content to support the deletion of all the right mouse button to support the operation
Extraction of the dictionary to help
Send a message:
Send(&S)
Please enter your proposals! the best way to leave your link so I can return the information you You can also e-mail directly to me 603436562 @ qq. com
The views of the proposal
Send comments / suggestions to the author
Software attributes
Skin set up software
Description
Download more skin
Open skin function
Closure of skin function
Looking at the same Chinese word
I do not prompt
Find and prompted the replacement of
When prompted whether or not a resource when finished
I do not prompt
Immediately prompted Chinese
Software Update
Shielding word database update(&P)
Dictionary update(&D)
Update the main program(&Z)
Automatic file backup resources
Automatic backup file to the same directory
Normal Chinese file types
All types
Class file
App document
Pyc document
Exe file
Rsc file
From the software, if asked?
Directly from the
Prompted me
RSC Chinese
When opening a RSC, does show that Chinese resources?
This feature does not support the display of the resources manually finished such as: 0408 0F00 20 0020 E0 20 20
Display of Chinese resources
English resources do not show
Search word length
Letters of all words over
Search more than:
1
Shows that the word [A key Chinese]
With effective length + no effective length
Show All words
Chinese PYC
Chinese are also other types of file system shielding more than words[rsc(a code),rsc(u code),exe(u code),txt category]
Personal information is automatically added
Close(&N)
Open(& O)
Information is automatically added to Chinese PYC tail current status: closed automatically added
Word shield system
0 to select the current word
System Shield 0 words
After Tim PYC software to open documents, will no longer show the words are case-sensitive The following is a word had been shielding
Add(&A)
Delete(&D)
Export(&C)
Import(&R)
Modify(&S)
Search word length
Search more than:
2
EXE Chinese
Save Chinese EXE prompted after pack
Direct automatic pack
Does not suggest that non- pack
Prompted whether I pack
Bulk shell pack
Bulk shell pack
Search word length
Search more than:
1
Exe file manually shell
pack manually(&P)
Shell manually(&U)
3rd Exe automatically shell
Exe file automatically when a Chinese shell
Dictionary set
Please select the dictionary used in the production of a text editor
Select(&O)
Support the type of dictionary
Chinese dictionary *.txt【turmoil File:: file】
Dictionary own software *.ict File|Document
Accumulated dictionary
When prompted when new words are added to bring their own dictionary
Shut down automatically added
Production generated by the dictionary when the dictionary folder
Select(&O)
Save folder automatically export the dictionary
Select(&O)
System comes with the path dictionary
Select(&O)
Would you like to bring a dictionary into the system
Prompted me
Do not prompt me
Automatically derived from the software dictionary
Does not export the dictionary
Automatically export the dictionary
Madman Chinese language settings
Description
Software settings
Share Information
From dictionary to share
Dictionary Name
Dictionary Version
Dictionary Address
Download(&D)
Introduction dictionary
Share Information
