Manilla 2D Customizer v0.7.104 (THEME MANAGEMENT)
headone
Một công cụ tuyệt vời để tùy biến M2D, chỉ dành cho những bản ROM M2D
UPDATE Sep-30-2008 11:00 CDT
v0.7.104
* oops, the theme management support for 0.6.97 was not future proof, so when updating to
this version your default theme will be applied. Your themes wil lstill exist, you
will just have to re apply them
* added support for *.zip theme files... the cath is that the zip file must contain a
HTCHomeSettings.xml file in it
* added support for multiple instances of the same named node, thanks to ababrekar from
xda-developers forexample
* added support for 3, 4, or 5 columsn, and 3, 6, or 9 rows in the launcher, thanks to
kidnamedAlbert from xda-developers for example
* attempt at more robust theme support, now reads and uses all values from
Imageslist, TabWidget, and HomeWidget in hte theme HTCHomeSettings.xml file,
I still see some bugs though (digital clock showing up in weird places, maybe due to
the skin developer removing the actual file rather than commenting out the xml
element or just giving the xml element an invalid name)
UPDATE Sep-28-2008 23:30 CDT
v0.6.97
* Theme management support, see the forums and the include readme.txt
file for more information
* modified the apptodate xml file location
(now looks for it directly from the subverison repository web access)
* fixed icon support for apptodate
* added a restore tab, this tab will tell all the other tabs to
restore the default values to M2D
* some small GUI changes in order to make it look more natural on WM6
* mostly automated the build process
(only needs human interaction to clean up changleog
and enter google code upload password)
UPDATE Sep-21-2008 16:00 CDT
v0.5.44
* added apptodate support
* fixed installer issues
* switched license to gpl
UPDATE Sep-20-2008 01:25 CDT
v0.4.29
* new tabbed layout
* added a basic launcher tab, can now set to 3 or 4 columns in launcher
* added "Apply"/"Cancel" softkey actions
UPDATE Sep-18-2008 22:25 CDT
v0.3.17
* added awesome looking new icon (thanks to twolf)
* No longer has hard coded folder paths so
** Non English roms should now be supported (Tested on Italian WM6 Professional emulator image)
** installing to storage card should now be supported
* Added somewhat extensive error logging, if for some reason the program can't write your new file, it should let you know, and tell you where a erro log text file is that you can post here or PM to me so that can see exactly what failed
UPDATE Sep-18-2008 09:35 CDT
v0.2.5
* fixed "read-only" problem people were having... now the program should have no problem if the file has been set to "Read Only". I tested by setting the file ot read only in total commander, have not confirmed if this will work if the xml file is part of the original rom as there is no manilla 2d rom for the titan yet
UPDATE Sep-18-2008
I have released the code for this program under an MIT license for now. So you can pretty much do whatever you want with it. You can check out the project page at http://code.google.com/p/manilla2dcustomizer/ I am releasing the code in hopes that people can learn form it, and so that if anyone wants to help I can easily let them in on everything. Plus it is nice of code.google.com to give me a free subversion repository
Download phiên bản mới nhất
http://manilla2dcustomizer.googlecode.com/files/M2DC_v0.7.104.CAB
http://manilla2dcustomizer.googlecode.com/files/M2DC_v0.7.104-src.zip
kimnam_2005
chơi 1 tràng tiếng anh hổng hiểu gì hết có hình up lên cho xem với bạn hiền chức năng là gì vậy nè
headone
Cái này tùy biến giao diện trong Manila 2D như:
-tùy biến theme (chắc theme là cái gì thì bạn biết rồi)
-tùy biến số dòng và cột trong program, trong program mặc định có 3 cột và 6 dòng thì nay có thể thay bằng 3, 4, or 5 cột, and 3, 6, or 9 dòng
-tùy biến số tab của M2D: bạn có thể thêm hoặc loại bỏ các tab dễ dàng, như không muốn tab people, mesage xuất hiện thì bạn chỉ việc bỏ dấu check trong CT này or thêm nhiều tab khác ngoài các tab hiện có
... và còn nhiều thay đổi khác hay ho chờ các bạn khám phá, các bạn nhớ download cả 2 files trên nhá
thay đổi khác hay ho đây
MY TODO LIST
These are things that I feel are necessary for the project, and things that I do plan on completing
InternetWidget
add new favorites to the internet tab http://forum.xda-developers.com/show...&postcount=358
Date Format
http://forum.xda-developers.com/show...postcount=3175
Clock
Add Enable/Disable support for
-anaolg clock
-digital clock
-digital clock AM/PM
Boring Programming Tasks
Scrollable UI (now when SIP appears the current PropertyPage is cut off)
REQUESTS (doesn't necessarily mean it is going to happen)
Custom Requests
- change tab functionalityhttp://forum.xda-developers.com/show...postcount=2271
- add new tabs
- Change Manilla 2D softkey settings
WeatherWidget
add custom cities to the weather widget
HomeWidget
-Add option to hide missed calls
-Add option to hide upcoming appointments
-Add option to have more than 1 upcoming appointment
-Add option to open a calendar program other than the default
LocationWidget
allow to use a mapping service other than GoogleMaps (Sprint Nav, LiveSearch)
PeopleWidget
Allow 4 columns just like the programs tab
EmailWidget
Allow multiple accounts to be displayed, and a way to differentiate between them
-Resolution / Orientation awareness (currently designed for portrait mode qvga)
-smart phone compatibility (I do not think this will be happening)
__________________
kimnam_2005
cái vụ này hay nè nhiều lúc muốn bỏ hay thêm tap kô được bây giờ có cái này quá đã đang down về voc cảm ơn bạn hiền nha
PhamHien
Rât cảm ơn bác headone nhưng mong bác lược dịch và giới thiệu bằng tiếng Việt để mọi người dễ hiểu và theo dõi!
headone
Thank bạn, đúng ra phải như vậy, nhưng tôi bận quá mà lại muốn có cái mới ngay cho cộng đồng PDAVIET nên chưa dịch được đầy đủ. Mong bạn hoặc ai đó lúc nào rảnh thì dịch dùm
phần Theme bận quá chưa có thời gian nghiên cứu nên chưa biết tùy biến ra sao, mong tất cả hỗ trợ
thanks
headone
Manilla 2D - Multicolor Skins, clocks and wallpapers
Tên skin
dòng thứ nhất
Black skin by TWolf | M2DC Theme
Red by bombzhome
White by bombzhome
Green by Anolnx
Purple by Anolnx
Blue Void by kulet78
Diamond clock by mbarvian (updated)
Pink her by TWolf | M2DC Theme
dòng thứ 2
Teal Manilla by .HaVoC.
Feng Shui by Dredd 67:
MobileMatt TF2D Connection by mchapman007
KnobiSkin by Knobibrot
AZUL-T2D bu GODZSON
TF2D Alabaster Skin by MobileMatt
White on black skin by eboelzner
T2D-WIDGETZ THEME by GODZSON
dòng thứ 3
Type-R skin by kidnamedAlbert
yellow theme by .HaVoC.
HTC-TOUCH/VOUGE transformation package by PROBEX (external direct link)
Black Vista skin by TWolf | M2DC Theme
Black ICE by MobileMatt
TOXIC theme by txema_py
Creaton by GODZSON (2 backgrounds)
MobileMatt Black ICE V2.0 by mchapman007
dòng thứ tư
skin Gold S2W by lepsyfou
BLUE GALAXY TouchFLO2D by phantomy2g
Ska Theme By Txema_py
Neon Skin v1.0 by andrew-in-woking
Blackgold by S2W
t-mobile White&Magenta skin by deonidis
MobileMatt TF2D MIB (Matt In Black) by mchapman007
YELLOWIND THEME by wytro
T2d-haze by Godzson
Manilla 2D - White version 2.0 by eboelzner
Red&Purple skin by JCKOTZE
O2 Blue by dazzawright
Blue O2 Skin by JCKOTZE
Sticker theme by deonidis
RedXda by lepsyfou
TF2D MIB2 (Matt In Blue) by mchapman007
Tải tại đây
http://forum.xda-developers.com/showthread.php?t=425974
headone
Modded clocks (Các loại đồng hồ)​
Tên đồng hồ
TF2D digital clock by pcarvalho
Clean by TWolf | M2DC Theme
Glass digital clock by Alladin
Big clock by TWolf | M2DC Theme
Black clock by colonel00
Pack clock divers by lepsyfou
GoldLamb by dicast
small alien round clock by kwill
Another digital clock by dicast
Clock Colon by ababrekar
Cachehog Green Glow Digital Clock by cachehog
Analog & Digital centered by ababrekar + corrected digits
Gold Clock by lepsyfou
clock silver by lepsyfou
metal clock by lepsyfou
T2D 9 Clock Setups by GODZSON
simple RGB 3 clocks by ababrekar
clock new design by lepsyfou
bluecool by lepsyfou
Van Den Bos-ish Clock by stewdog
Blockish by bedaweed
semi-transparent analog clock by cosmindv
Tourbillon Clock by Taninpv
RomMod Clock by Taninpv
Draft clock by jomaga
4 clocks by jomaga
Bold digital clock by cachehog
3 Diamond Clocks - Vodafone|O2|T-Mobile by bornotty
link download như trên
headone
Icons (Biểu tượng)​
Tên icon
New icons by GODZSON
Leopard style icons by Dredd67
Neon Icons by ababrekar
Feng Shui Matching Icons by Dredd 67
weather graphics by BeyondInvisible **
3D icons by stabloid
Color and Black&White icons by tersoth
M2D Weather Graphics - Winter Edition by BeyondInvisible **
White tab icons by ababrekar
Landscape by btprice2001 *
simple colored by deonidis
XM2D weather graphics by BeyondInvisible **
namic
mình thấy cái này rất hấp dẫn. Mình đang sài cái V58 của Pác Quang. rất thích nhưng tùy biến cho today rất hạn chế (hầu như ko thay đổi được today khi mở TouchFlo). Do vậy công cụ này rất hữu ích đấy.
Nhưng Pác Headone ui, bác có thể dịch hoặc hướng dẫn cụ thể cách cài đặt cái này cho anh em được không. Mong sự giúp đở của Pác.
headone
Cài đặt thì như bình thường thôi, chép file CAB vào máy rồi cài. Hiện tại cái này tùy biến TAB thôi, còn theme nhiều thứ chưa rõ ràng nên tôi chưa thể hướng dẫn cụ thể được
Các file Multicolor Skins, Modded clocks, Icons mốt số phải cài đặt, 1 số (*.tsk) chỉ cần chép vào thư mục windows là được
headone
headone
SKIN (tiếp theo)
1st row
Blackgold by S2W
2nd row
T2d-haze by Godzson
RedXda by lepsyfou
3rd row
Gold Red Velvet Mod Layout by ldostang
Nova by spacemonkey333
MobileMatt Green Acres by mchapman007 | M2DC Theme
ORO THEME by GODZSON
WHITE NOVA by spacemonkey333
RED SCARLET by S2W
Red Void by kidnamedAlbert
Sprint theme by kidnamedAlbert
1st row
Tiger osx by deonidis
Golden oldie by showaco
MobileMatt Bios by mchapman007
Blue Manilla by jvreeken
Chakram theme by kidnamedAlbert
PS3 theme by deonidis
iPhone by lepsyfou
COrange & CRed by JCKOTZE
2nd row
MobileMatt Zebrano by mchapman007
PROBEX VISTAstyle by PROBEX
PS3 with black icons by deonidis
Dark Tower by showaco
alltel theme by JCKOTZE
MobileMatt Solace by mchapman007
Playspiration 3 by Dredd67
Skin Blue xda + bonus Skin by lepsyfou
3rd row
Raider Nation by spacemonkey333
Longhorns theme BY stutzmason
OrangeWhite + BlueWhite + BlackWhite M2DCT by TWolf
Red Icone by lepsyfou
Michigan Wolverine Theme by stutzmason
Morbid Angel by tweaked
minimalistic by bereda
Grunge by mchapman007
MODDED CLOCK (tiếp theo)
1st row
4 clocks by jomaga
Pack clocks spb mobile shell by lepsyfou
Chrono CLOCK Face by JCKOTZE
Analogue clock by JCKOTZE
Blue Clock by JCKOTZE
2nd row
Digital clock by poorlyduck
source: XDA
headone
phiên bản mới của Manilla 2D Customizer (ngày 11/11, V0.22.215)
Link tải: http://manilla2dcustomizer.googlecode.com/files/M2DC_v0.22.215.CAB
UPDATE Nov-11-2008, v.0.22.215. Bạn có thể dùng bất cứ trình duyệt nào làm trình duyệt mặc định cho phiên bản Manila 2D version 20
- added an internet page that allows you to set a different default internet browser for Manila 2D version 20 (build 1.0.1820.3328)
source: XDA
miror1102
m2d nay xài cho atom exec đc ko bạn?sao mình dow về cài mà ko chạy đc
ah,đc rùi mà có phải nó 12M lận phải ko?
NhatToai
Thực ra đã có một Topic khác khá đầy đủ theme và các tool Customizer (M2DC) các phiên bản tại đây:http://www.pdaviet.net/showthread.php?t=33963
Tiếp theo và cũng là vấn đề chính là hầu hết các link download trong này đều die hoặc dẫn link sang forum khác,bài post thì copy nguyên văn English!!!
Vì vậy Topic sẽ được Close,các bạn vui lòng tham gia theo link đã đưa ở trên hoặc có thể thấy nó ngay dưới chữ ký của tôi,Thân.
Thread Closed!
