wimax16vnn
[ mới mới ] CFW 5230 v21.0.4 9HS samsung + ip OS
mình đã flash bản CFW này rồi, rất ổn ,nhanh, đầy đủ các apps, có fần hơn các CFW made in VN hiii
) >![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
SỬA ĐỔI:
- **** IDLE CPU clock rate increased (it will always run at more than 400hz)
- **** Battery has been optimised (the phone wont heat heavily due to overclocking and along with that battery will run for sufficient time)
- **** Increased the frame rate frm 22 FPS to 30 FPS(resulting to better fps)
- **** Buffer size improved (so u can multitask better)
- Voice Commands and GPRS Connection status Enabled
- Nokia SMS Sending (My Nokia) Disabled
- Tapping Mode added: Shake to get phone silent/snooze Alarm and Calls
- Default bluetooth name: Aurora Xtreme
- OVI Contacts totally disabled
- Now you can record up to 12 Hours
- Voice recording during call fixed
- RAM Cache in C:\ for better performance
- Browser Cache increased to 10MB and moved to E:\
- Fast Screen Rotation
- Kinetic Scrolling disabled in short lists
- No start up of background applications
- Flash with blank UDA to get max space
- No Lags in the menu and Smoother Kinetic Scrolling
Các tính năng chính
-Included the application policy mod(99% apps will b installed even if patches are nt applied)
-App and Games speed increased
-Phone Response Rate Increased
-Music Player only searches for E:\sounds\music. so no worries abt ringtones playing in ur music player
-Increased Heap Size to boost up performance
9 HOMESCREENS
1> Vodafone
2> N97 OT (Orange Tsunami)
3> Orange Tornado
4> Basic OMNIA
5> Navigation Bar
6> Finger Use
7> Full Page
8> Contacts Bar
9> Samsing widget (iphone or omnia hs)
CUSTOMISATIONS
- Original Nokia Shutdownscreen
- Original Nokia Splashscreen
- nokia green bootscreen
- Xtreme menu mod by Upakul
- s60 Busy Cirle in Menu
- Light Intensity set to 50% by default
- Theme Effects: Glide +speed effect 2
- Lags in Menu and Other Large Applications removed
- almost all bugs removed
- 73MB+ on C:\ (Phone memory) on startup(aftr auto installation of apps it will decrease to 70.4MB)
- RAM: 64MB on startup
- Removed annoying widget security warnings
- Default Browser can go landscape even if sensors are turned off
- Download manager will be started on browser start-up to resume
- Cache moved to E:\ and increased to 10MB
- Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads.
- Nokia default file browser will show system folders and root folder (Just enable ReadCroot.rmp Patch)
- Camera sound is disabled if warning tones are off in profile
- Camera will not leave in the background after closing it to save RAM
- Video Capture Quality improved
- Refresh faster
- Default internet browser will resume broken downloads
PERSONALISATIONS
1.ringtone changed to titanic tune.
2.Message tone change to message 2012
3.Custom version name changed to Aurora xtreme
4.Alarm snooze time decreased to 10 min
5.Display brightness reduced to 50% by default
6.Voice recording set to highest quality
7.September font added
THEMES:
- S60 2.0 exclusive by AJ23
- Dark grey (default)
- Nokia c6 white theme
APPLICATIONS:
- RomPatcher+
- Autoinstaller v1.2
- BTSwitch(switch on the Bluetooth with jst one tap on this app)
- KillMe
- File Browser
- Vivaz Conversation
- Next Track, Previous Track, Play/Pause(shortcuts used by orange tsunami)
- Widgetizer 1.4
- OVI Store (Latest)
OPTIMIZATIONS:
- FOTA reserved spaces in C: deleted: gain 5MB
- Autocreation of folders
- Cache folders in E:\
- E:\Sounds\Music
- E:\thinkchange\c
- E:\thinkchange\e
- the gadget.swf will be automatically copied to E:
- Ovi Store Latest is automatically copied to thinkchange installation folders
- Just Run Autoinstaller to quickly install these applications
ALL SUPPLIED PATCHES:
Install Everything.rmp - Allows the installation of any non signed application
Show system files.rmp - Shows all system folder and files in C: and E:
Remove Red Recording LED.rmp - Removes the RED led that lights up during Video Recording
Record Tone OFF.rmp - Turns off call recorder beep during recording
Remove Show Open Apps - Removes the "Show Open Applications" tab from options menu
Block GPRS & WLAN.rmp - Blocks bluetooth and WLAN
Disable Logs.rmp - Disables LOG application
Lock Settings.rmp - Disables settings application
Lock Bluetooth.rmp - Locks the bluetooth
Lock USB data.rmp - Locks USB connectivity
Lock Installation.rmp - Prevents installing of any softwares
Activate Bass Effects.rmp - Activates the bass effects
c2z4bin THUMB.rmp - c2z like patch for binary files
12 months call log.rmp - Increases log period from 30days to 12months
LCD Light ON.rmp - Keeps the LCD backlight ON
Show typed Password.rmp - Shows the typed password instead of "*"
Show hidden options.rmp - Shows hidden options in options menu
Restart Power Button.rmp - Long press power Button to Restart device
Short Multi Tap.rmp - Decreases the waiting time between pressing of two keys
Global Note Fix.rmp - Removes all popup notes (Base patch)
Disable Enh Note.rmp - Disables 'enhancement connected' notes
Disable USSD Notes.rmp - Disable operator USSD notes
No Profile Switch Note.rmp - Removes the popup note that opens when profiles are changed
ReadCRoot: Shows all C: drive contents on default File Manager (This Patch is buggy, be carefull)
PRE-ENABLED PATCHES:
Install Everything.rmp - Allows the installation of any non signed application*
Show system files.rmp - Shows all system folder and files in C: and E:*
Iphone hs users-
**there is no red bug with the iphone hs.
**the current iphone hs contains 2 pages and a dialer. i hv left the last page blank without any icons. u can customise it as u need. the xml file for this can be found in E:\
**the gadget.swf has been placed in E:\. u can replace it if u need.
** if the hs shows any errors like memory error or the top bar turns white jst switch to basic and again switch to samsung widget.
[DOWNLOAD]http://www.mediafire.com/?4v47d7bfy5msqkb[/DOWNLOAD]
CÒN CHẦN CHỜ GÌ NỮA MÀ KO DOWN VỀ TEST HẢ CÁC BÁC ^^
![Scr00d0004.jpg](http://cA4.upanh.com/10.349.14486422.TAL0/Scr00d0004.jpg)
![Scr0000012.jpg](http://cA3.upanh.com/10.349.14486425.KCN0/Scr0000012.jpg)
![Scr000001.jpg](http://cA5.upanh.com/10.349.14486427.BDV0/Scr000001.jpg)
![Scr000001s.jpg](http://cA2.upanh.com/10.349.14486428.DZU0/Scr000001s.jpg)
![Scr000002.jpg](http://cA3.upanh.com/10.349.14486429.RYM0/Scr000002.jpg)
![Scr000003.jpg](http://cA5.upanh.com/10.349.14486431.MZP0/Scr000003.jpg)
![Scr000004.jpg](http://cA3.upanh.com/10.349.14486433.OHZ0/Scr000004.jpg)
![Scr000005.jpg](http://cA2.upanh.com/10.349.14486436.XCP0/Scr000005.jpg)
![Scr000006.jpg](http://cA5.upanh.com/10.349.14486439.EVZ0/Scr000006.jpg)
SỬA ĐỔI:
Các tính năng chính
9 HOMESCREENS
1> Vodafone
3> Orange Tornado
4> Basic OMNIA
5> Navigation Bar
6> Finger Use
7> Full Page
8> Contacts Bar
CUSTOMISATIONS
- Refresh faster
PERSONALISATIONS
THEMES:
APPLICATIONS:
- RomPatcher+
- KillMe
- File Browser
- Widgetizer 1.4
OPTIMIZATIONS:
- E:\Sounds\Music
- E:\thinkchange\c
- E:\thinkchange\e
Iphone hs users-
