N96 flash bị lỗi.
thaiminh40
Sau khi flash với cool fimware bị lỗi thì máy không thể mở nguồn được. Flash
lại fimware cũ tới giai đoạn cuối thì màng hình chỉ chớp trắng lên rồi tắt.không vào được tét mode:((
không dùng jaf được vì nó cứ báo can't find cmt booting...
Flashing started
Creating product data items list
Product data items list created
Backup not required
KeepProductInFlashModeAfterFlash is supported only for FPS-X devices. Ignoring the flag
Flashing phone
Initializing
Scanning image files...
Waiting for USB device...
1. Make sure USB cable, Battery and charger are removed from device.
2. Insert USB cable to device
3. Insert Battery to device
4. Insert Charger to device
--- Press phone's power button! ---
Loading secondary boot code: 39104 bytes
Secondary boot loaded
Loading update server code: 407169 bytes
Update server loaded
Loading slave secondary boot code: 15168 bytes
Slave secondary boot code loaded
Loading slave update server code: 462152 bytes
Slave update server loaded
Partitioning....
Partitioning complete
Erasing....
Erasing complete
Asic CMT: Start programming 6310 KB...
Asic CMT: Programming data sent: 0%
Asic CMT: Programming data sent: 10%
Asic CMT: Programming data sent: 20%
Asic CMT: Programming data sent: 30%
Asic CMT: Programming data sent: 40%
Asic CMT: Programming data sent: 50%
Asic CMT: Programming data sent: 60%
Asic CMT: Programming data sent: 70%
Asic CMT: Programming data sent: 80%
Asic CMT: Programming data sent: 90%
Asic APE: Start programming 114905 KB...
Asic APE: Programming data sent: 0%
Asic APE: Programming data sent: 10%
Asic APE: Programming data sent: 20%
Asic APE: Programming data sent: 30%
Asic APE: Programming data sent: 40%
Asic APE: Programming data sent: 50%
Asic APE: Programming data sent: 60%
Asic APE: Programming data sent: 70%
Asic APE: Programming data sent: 80%
Asic APE: Programming data sent: 90%
Asic APE: Programming data sent: 100%
Programming complete
Asic CMT: programming succeeded
Asic APE: programming succeeded
Asic CMT: Verifying communication to device...
Waiting for communication response: 25
Waiting for communication response: 24
Waiting for communication response: 23
Waiting for communication response: 22
Waiting for communication response: 21
Waiting for communication response: 20
Waiting for communication response: 19
Waiting for communication response: 18
Waiting for communication response: 17
Waiting for communication response: 16
Waiting for communication response: 15
Waiting for communication response: 14
Waiting for communication response: 13
Waiting for communication response: 12
Waiting for communication response: 11
Waiting for communication response: 10
Waiting for communication response: 9
Waiting for communication response: 8
Waiting for communication response: 7
Waiting for communication response: 6
Waiting for communication response: 5
Waiting for communication response: 4
Waiting for communication response: 3
Error 0x8401F121 communicating to phone. Unable to verify comm.
Warning: Unable to communicate to product after flashing
All operations completed
Product flashing failed.
XML log written
KjDBun
Bạn có thể flash lại bằng JAF với chế độ dead phone . Bạn có thể down FW dạng EXE về với các RM-xxx phù hợp sau
RM-247
RM-297
RM-472
với pass là : vietfones
thaiminh40
Cảm ơn bạn đã chia sẻ. Lâu minh không vào dd. Cái n96 mình thật sự bó tay. mình thủ hack vĩnh viễn bằng file intalsever.exe chép vào ổ z và kết quả là không thể nào mở máy được nữa. dù có nâng hay hạ fw cũng vậy. flash thì ok hết nhưng mở nguồn thì chỉ chớp và tắt. nên thay luôn cặp flash và cpu rồi.
