varius
![capture1zc.png](http://img153.imageshack.us/img153/1637/capture1zc.png)
![capture2f.png](http://img403.imageshack.us/img403/3153/capture2f.png)
![capture3d.png](http://img403.imageshack.us/img403/7379/capture3d.png)
Tính năng mới:
-SIS STUB Manager: đai loai nó cho phép bạn xóa gói như OpenOffice, AdobeReader không cần file .app hay xóa = tay
-File Hider: ẩn các tập tin trong ROFS hoặc ROM
- New Search Engine: hỗ trợ thêm kểu tìm kiếm mới với ? và [ ]
ex: *.r?*: kq là tất cả các file có*.r
*.r0[1-5] : kq là các file có .r0 trong khoảng từ 1-5
*.r0[!1-5]: kq là các file có .r0 trừ khoảng từ 1-5
*.o???01:kq là các file bắt đầu là o,3 kí tự ,kết thúc là 1
-& 1 số fix khác
New Features:
* SIS STUB Manager: This feature can be accessed inside the "Application Manager". It allows you to delete packages like OpenOffice, AdobeReader etc... without breaking a sweat!! All you need to do is to Extract your Repartitioned ROFS2 File, then open the Application Manager and goto SIS STUB Manager then Select the package you want to delete it and press the "Delete" button!!
!! This Addon works only on a partitioned ROFS2 File, like released C6 files by PNHT or derivatives. !!
* File Hider: This features allow to hide files in ROFS or ROM! Example: To hide a file in ROFS1 you do the following: Extract ROFS2 or ROFS3, open the File Hider and add the entry of the file \private\10207114\import\200039EF\200039EF.skn, Save and Repack your Firmware! That's all. This feature does not create Dummy files. It adds special entries to the built ROFS to hide the files.
Entires can be Manully added or by importing an ROFS file using the "Add ROFS" button.
This feature can be used to hide for example the Themes that are in our Partitioned CORE files. Example for Nokia 5800, add the following entries in "File Hider":
Code:
\resource\skins\200039EF\200039EF.mbm
\resource\skins\200039EF\200039EF.mif
Enhancements:
* New Search Engine: The search engine has been powered with a more powerful syntax. The ? and Range [ ] wildcards has been added with a possible combination of all of them. Example:
*.r?*: Return all *.r files with a
*.r0[1-5]: Return all *.r*1 to .r*5 files (ex: *.r01, *.r03, *.r15 etc...)
*.r0[!1-5]: Return all *.r* files, except the ones in range 1-5
*.o???01: Return any result with file extension starting with o, having 3 characters and ending with 01 ex: *.o12301
* Enhancement to the Language Manager
* Several Fixes
http://www.mediafire.com/?4udii05uh9m1961
