[NEW] Road Chase-Xe Đua Đường Trường
nouvu2372
Road Chase
  1. If driving through city traffic makes you happy, if you are able to compete against running time and if you dont mind long distance under different weather conditions, you should try the adventure we give you! Motorways all over the world are waiting for you!HIGHLY REALISTIC
It is a realistic simulator of car driving under difficult weather conditions. Its not a typical race track where the one thing to worry about is speed. In our game you have to face the proper inter-city traffic which goes both directions. You have to consider it before taking any maneuver.
HIGH LEVEL OF ARTIFICIAL INTELLIGENCE
Cars are going different speed. They are overtaking each others drivers, AIl makes the traffic realistically predictably. You should keep it in mind all the time when driving.
REAL REARVIEW MIRROR
Your car is provided with a rearview mirror so you can see whats happening behind you.
CHANGEABLE WEATHER
Constantly changing weather will makes you trip way harder. Lucky you can use windscreen wipers which will make driving through rain and snow much easier.
SERVICE STATIONS
Bear in mind fuel gauge and damage level of you car. Stop at car garages to take care of it. The stronger engine works, the more fuel it uses, keep it in mind by looking at tachometer to save your petrol.
POLICE CHASES
Take into consideration speed limits so you can avoid the radars. In case you get caught and you realize, you are being chased by police, escape is always an option to save some time. Remember that police drivers usually are excellent skilled and you have to do your very best to make them lost you.
THREE DIFFERENT MAPS
There are 3 countries (England, China, USA) on different continents to be chosen. Make sure you choose the ones which matches your skills.
CHANGEABLE ROUTES
Its up to you which way you going to go to get to the destinations. That makes it possible to avoid bad weather. Each map matches very accurately reality, the roads lead you to cities, which exist. The maps are vector made so you can freely rotate, zoom and pan them as well as show or hide cities names.
Working on Nokia 3230, 6260, 6600, 6620, 6630, 6670, 6680, 6681, 6682, 7610, N70, N72, N90
