Satan
Rom 6.5 by Xplode X5!
This is the latest publically available build of Windows Mobile 6.5 Professional
I keep it clean as i can
Rom version:6.50.15
Rom Date:3.19.2009
Page Pool:24.5 MB
Core:5.2.21193
Build:21193.5.0.0
AKU:5.00
So what's not inside:
Removed: Office, SQM, Transcriber, Windows Live, Welcome Center, IPSECVPN and some more stuff which IMO is unneeded ... the rom so far is stable.
Added: in the extrom archive there is sample extrom which i use which includes latest PIE 8.12 + Adobe Flash Lite, Welcome Center, Windows Live Mobile 10.6.50.2700 (latest build to date), Repacked Office Mobile from this build + OneNote and a few more cabs which i think are needed. IN the rom removed many graphics but will include them as files
NK.exe customizations are taken from sun_dream's roms (hes nk.exe is fast) other stuff in the xip is ported from the original 21193 xip. Many thanks to sun_dream for the help with this rom. For my latest roms i have removed SQM, and customer experience sh** in order to lighten a lil the rom and protect personal information to be sent to microsoft. Try it on your own risk - it is beta build so you can encounter unpredicted bugs with it.
I want to thank to mamaich (still use hes tools in rom building for BA), bepe (BuildOS is hes work - a brilliant one), in random order, sun_dream, childrin, mun_rus, Tuatara (constant help and support), helmi_c, itsme (brilliant perl scripts which were used for dumping all the goodies from newer roms), cmonex and a lot more people involved ... I appreciate your help
Donators:
+ Que PPC - 5€
R2 - Changelog:
Browser resources fixed to WWE ones
Shell Updated to proper WWE one - (new tabs are present)
Shortcuts created properly to work with the grid menu
Customizations for grid menu to use the new icons - via CustomGrid.cab
Changed names of shortcuts in windows live cab to use proper names
Some minor tweaks
Bugs found so far:
PIE 8.12 still have chinese customization - i will deal with it today or some time tomorrow - fixed in second release
Outlook Live does not want to connect - maybe microsoft shutted down the test server after the build leaked
Marketplace can not connect either
My Phone crashes ...
widgets not working on ba - error is that this device is not suppoorted
windows live tab in chome is not in WM6.5 style (can be edited but looks like crap at the moment)
Start menu has some missing icons (again due to chinese characters in a provxml file) - fixed in second release via CustomGrid.cab
Tips:
to enable Favorites on CHome install PIE8_Flash.cab
to fix the OK and X buttons use the following cabs (these cabs will work on any qvga 21159 rom)
OK-X-Fix.cab- uses the original resources of this build with proper size and they are edited a little by me to have better looks
OK-X-FixL.cab- Large Size - like in the rom (the resized bigger images) but antialiased
to disable animations change the following from 1 to 0
Code:
[HKEY_LOCAL_MACHINE\System\GWE]
"EnableAnimations"=dword:00000001
or install the following cab
Link tham khảo: http://forum.xda-developers.com/showthread.php?t=482997
Link Rom: http://rapidshare.com/files/211349712/21193.7z
or http://www.megaupload.com/?d=X6UCRAD5
or http://www.ziddu.com/download/3935599/21193.zip.html
Link ExRom: http://rapidshare.com/files/211343548/21193_EXTROM.7z
or http://www.megaupload.com/?d=FCIBUICM
or http://www.ziddu.com/download/3935218/21193_EXTROM.zip.html
Link Themes: http://rapidshare.com/files/211343549/WM6.5_Themes.7z
or http://www.megaupload.com/?d=Y53IT3UE
or http://www.ziddu.com/download/3935217/WM6.5_Themes.zip.html
Rom version:6.50.15
Rom Date:3.19.2009
Page Pool:24.5 MB
Core:5.2.21193
Build:21193.5.0.0
AKU:5.00
Donators:
+ Que PPC - 5€
R2 - Changelog:
Some minor tweaks
Bugs found so far:
Tips:
Code:
