Mamaich 1 chuyên gia về phần cứng cũng như phần mềm ĐTDĐ, sau khi sáng chế nâng cấp UNI tăng Ram từ 64MB lên 128MB, đã build Rom 2.15.00 WWE chỉ dùng cho G3.
Rom mới này ổn định, tốc độ nhanh, wifi tốt, đặc biệt multimedia có hình ảnh và âm thanh rất rõ và hay. BT stereo vẫn chưa dùng được với Itech R35. Bộ nhớ sau khi cài nhiều softwares không còn nhiều, nhưng máy rất ổn định và tốc độ nhanh. Pin có vẻ không hao nhanh, vì mới uprom được vài giờ nên chưa đánh giá chính xác.
Download theo địa chỉ dưới đây:
http://rapidshare.com/files/69366055/nk.rar.html
Mamaich giới thiệu:
So here is the ROM. Use it as is, I would not answer any questions on ROM cooking or mods based on that ROM until i'll publish a final version with G4 support. Rom is stable, i'm using it in real life for several weeks. It is based on WM6 build 18533. Incorrect cooking based on this ROM would cause stability issues as all drivers and OS kernel are heavily interdependent.
Features:
- 128 Mb RAM support
- Page pool is completely turned off (size is set to 0xFFFFFFFF), so no modules are ever paged out. This still leaves lots of free RAM and gives a good speed increase. Of cause you'll get almost no free RAM on 64-mb devices ;-)
- ULDR is removed, so we have extra 3 MB of space in ROM
- Free space left in OS ROM is now accessible as a "Flash Disk" folder. It is 12.5 mb in size
- Extended_ROM is returned to its original function. I use it for installing my favorite apps after hard reset, and recommend everyone to do the same. It is writable by default, but hidden. There is a known bug - its content may be destroyed if you unhide extended ROM and use it a general storage. So keep it hidden, you have "Flash Disk" or SD-card for storing your data.
- Usual fixes: overclocking applet, Fn+Letter would work as Ctrl+Letter (only for english/russian kbd layout, and only unused keys), GAPI and display driver performance is optimized, SDHC is supported.
- Double tap on the only button of old BT headsets (those who don't support handsfree profile) would launch voice dialer app.
- \Windows\RouteBTAudio.exe - run it and it would route all audio to your old non-A2DP capable headset. Program is identical to "Bluetooth Audio Router", "BlueMusic", but is completely free. Source code is available on request.
- Apps included: MMS 4.x, Voice Dialer (with bluetooth headset support), Adobe PDF reader LE. Recommended APPs to be added to extended ROM: flash player, .cab to turn off security, SMS delivery report fix, WM5NewMenu, WM5torage
Known bugs:
- Extended_ROM would break if used as general storage. Keep it hidden!
I don't use extended ROM so this bug probably would not be fixed.
- G4 devices hang on boot screen. I'm working on this, but don't have G4 device to test, so it would take lots of time.
__________________
HTC Universal (128 Mb RAM)
ROM: WM6 aku x
Radio: 1.18.00
SD: 8 Gb Transcend SDHC
Mamaich giới thiệu:
Features:
Known bugs:
__________________
ROM: WM6 aku x
Radio: 1.18.00
