Nokia 6760s xách tay. up fw bi die phone
dnamve
Nokia 6760s xách tay úp fw bằng jaf bi diephone
pro nào vào xin giúp đỡ em.
JAF version 1.98.62
Detected PKEY: 90008E4F
Card life counter: 99.99%
FBUS INTERFACE NOT CONNECTED....!
USB Cable Driver version: 7.1.31.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-573\
Checking path: \Products\RM-573\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-573\rm573_03.38_PI-224_prd_core.fpsx
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-573\rm573_03.38_PI-224_prd_v14_01_apac1.fpsx
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-573\rm573_03.38_PI-224_prd_vJIBLACK50_01_BLACK.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-573\RM573_03.38_PI-224_001_U000.uda.fpsx
Detected P-KEY: 90008E4F
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 007.016.022
    Elf2flash 09.07.000
    CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting............PUBKEYS already sent...
.......Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 918, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-573\rm573_03.38_PI-224_prd_core.fpsx...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 0087FFFF ... Erase result: 0000
Erasing cmt zone 00880000 - 00B7FFFF ... Erase result: 0000
Erasing cmt zone 00B80000 - 0871FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-573\rm573_03.38_PI-224_prd_v14_01_apac1.fpsx...
Erasing cmt zone 053E0000 - 0791FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-573\rm573_03.38_PI-224_prd_vJIBLACK50_01_BLACK.fpsx...
Erasing cmt zone 07920000 - 0871FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-573\RM573_03.38_PI-224_001_U000.uda.fpsx...
Erasing cmt zone 08720000 - 0F8BFFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Sending CMT HASH for SOS+ROFS3
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Done!
PRESS POWER ON NOW!
Using 007.016.022
    Elf2flash 09.07.000
    CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
giangvungtau
bạn thử down lai FW mới rồi làm lại xem,có thể trong wá trình down Fw bị lỗi,mình cũng hay bị như vậy
doremon2301
Bình thường thì máy Nokia sẽ có 2 mã boot, cái mà mình dùng để khởi động máy gọi là Master Boot Code, còn cái thứ 2 là Secondary Boot Code, cái này bạn dùng trong trường hợp dead phone. Bạn Flash bằng Phoenix theo mình là an toàn hơn, và nhớ chọn tuỳ chọn Dead Phone Usb flashing, có gì không hiểu cứ hỏi ở đây. CHúc bạn thành công
ducminh90
1.dùng jaf flash lại máy
2.tải ver mới nhất của máy về
3.nếu ko dc thì nói rõ lỗi để anh em xử lý tiếp ;;)
