Nokia Lumia 710 Unlock Ok !
Taki7610
Unlock_GSM
[CODE]Looking for phone...Not found!
Can't read IMEI, backup will be skipped.
Looking for NAND disk...Not found.
Things to check:
1. Is the phone connected?(Plug to the USB)
2. Is it in the correct mode?(Try to switch to OSBL mode)
3. Have you installed the Qcom loader ?(Use the Install button)
Things to check:
Looking for phone...Done.
IMEI:     359774040907823
Changing phone mode...Done.
Things to check:
IMEI:
Please follow these steps:
1. Power off the phone
2. Remove the USB cable
3. Press and hold the Vol+ button
4. Plug the USB cable, wait for the buzz
5. Release the Vol+ button
Waiting for 30 seconds...Done.
Things to check:
Things to check:
Things to check:
Things to check:
Things to check:
Looking for NAND disk...Done.
Trying to parse partition tables...Done.
FAT16 absolute address:    0x001F4200
FAT16 partition size:      0x0927C000
Reading FAT16 raw...Done.
Searching locations...Done.
Found 1 locations to modify, processing:
Reading sector 0...Done.
Modify sector...Done.
Updating sector...Done.
Modification written. Please follow those steps:
1. Disconnect USB cable and remove the battery
2. Insert not supported simcard and power on the phone
3. If asked for PIN code, enter 00000000
4. If asked for PUK code, enter 0000000000
5. After unlock success, connect to USB, enter OSBL mode
6. Press Unlock again to restore the phone to original
[/CODE]
--> driver ok
--->bấm format mua cái mian mới thay lun :D
M1000
lumia 710 không nhận sim
Bác cho thêm chi tiết được không a. cai lumia 710 cua em gan sim vao vẫn bảo là error sim or invalid sim card a.
Taki7610
Unlock_GSM
Bỏ sim vào còn chế độ nhập code không ? Không còn thì flash lại xem.
Taki7610
Unlock_GSM
IMEI: 359774040468198
Things to check:
Things to check:
Things to check:
M1000
Thưa bác là máy em đã hết lần nhập code rồi a. em đa flash nhiu ban rom khac nhau van không đc a. máy này cua T-mobile a. Em chạy NSS 0.50 và 0.52 báo đã unlock thanh công nhưng em nó vẫn không xuất hiện nhập code hay PUK a.
Taki7610
Unlock_GSM
Vậy chỉ còn cách bung máy để unlock thôi. Giống như cái này này :D có thể được vì mình chưa gặp con nokia bị mất chế độ nhập code.
M1000
Để em thử theo cách của Bác rồi báo cáo ạ, ngặt nỗi bận quá.
Taki7610
Unlock_GSM
Things to check:
mjnha9
bác cho e hỏi,e mua con 902 cũ hàng at&t lúc mua không biết hàng này là hàng xách tay,vẫn thấy lắp sim mình dùng được bình thường,vậy có phải là máy đã unlock rồi dùng thoải mái phải không bác,có trường hợp nào dùng 1 thời gian lại bị khóa lại không ạ,e sợ quá mong bác chỉ giáo cho :sad:
kieukhanh
Mình có chiếc Lumia 810 T-Mobile mua mấy năm nay mà chưa Unlock được toàn dùng kiểu như mấy tính bảng :haha:
Có bác nào trên 4rum mở được không thì giúp cho với ! Cám ơn nhiều !
IMEI 354591050618701
