AquaSta
Category: Business
Apr 20, 2010
Version: 3.4.2
3.5 MB
Seller: Byte Squared
© Byte Squared Limited
Description
With Office² HD you can view, create and edit Word (DOC) and Excel (XLS) files on your iPad.
It integrates with Google Docs, DropBox and MobileMe iDisk too, which means that you can now access your important documents at all times.
Office² HD works with an external keyboard too, making it easy and quick to edit documents and spreadsheets.
Want to use it to transfer files between computers or read your favourite PDF files on the go? Office² HD can store any file, just like a USB stick and can view many different file formats.
GOOGLE/MOBILEME INTEGRATION
Office² HD works with Google Docs, allowing you to view and edit the documents (DOC) and spreadsheets (XLS) stored in your Google Docs account. Not only is this a great way of transferring files to and from Office² HD, it also means that you can manipulate the same files both on the iPad and from within your web browser.
MobileMe users can access files stored on an iDisk, either by opening them and editing them directly on the iDisk or copying them from the iDisk and editing them locally.
TRANSFERRING FILES TO AND FROM OFFICE² HD
Office² HD may be mounted as a drive from Mac Finder or Windows Explorer, or from a web browser on any platform. You can also transfer files over USB using iTunes.
You can open .xls and .doc email attachments into Office² HD and you can also email any file from within Office² HD.
GENERAL
● View, create, edit and save documents in Word (DOC) and spreadsheets in Excel (XLS) format.
● Compatible with Microsoft Word, NeoOffice, Excel, Numbers and any other .doc or .xls compatible programs.
● Portrait and landscape views.
● Copy and paste. For the word processor, this includes text and images from other applications, including Safari.
● Save documents and spreadsheets in PDF format.
WORD PROCESSOR
● Character formatting, including text and fill color, bold, italic, underline, font face and size.
● Paragraph formatting including alignment, indenting, bullets and numbering.
● Support for tables, including table creation.
● Support for images, including inserting of images from the camera roll or pasting from other programs.
● Searching of text within documents.
● Undo and redo, up to 100 undo levels.
● Auto-correction and auto-completion are supported.
SPREADSHEET
● Handles multiple worksheets with unlimited rows and columns.
● Searching and sorting of cells.
● Cell formatting, including bold, italic, borders, text and cell color, alignment, text wrapping.
● Cell types, including General, Number, Currency, Percentage, Date, Time, Date/Time and Text.
● Merge cells feature.
● Pane freezing.
● Tap and drag to change row heights and column widths.
● Intelligent auto range selection for range based functions.
● Tap cells to compose formula.
● Insert, copy, paste or cut cell ranges, rows or columns.
● Date formats, date separators and numeric separators are all handled correctly according to the current locale, with manual override.
● 112 Functions.
ORGANISING FILES
● Access files stored in Google Docs, iDisk, myDisk.se, Box.net and any WebDAV server, including open, edit, save, delete and rename.
● Create or delete folders.
● Move or copy files between folders locally
● Move or copy files between Google Docs or iDisk accounts and the local folders.
● Move or copy files within folders in Google Docs or iDisk accounts.
● Email files as attachments.
What's new in Version 3.4.2
The following features have been added:
- Improved table creation.
- Ability to add and remove table rows and columns.
- Can now change formatting for table rows, columns and cells.
The following bugs have been fixed:
- Images are no longer removed from documents when a password is set on the document.
- An issue with document formatting has been fixed.
- A crash when saving DOC files in Word that were created/saved by Office² HD has been fixed.
- A problem when correcting words in the document editor where the first character is duplicated has been fixed.
- An occasional problem with shared spreadsheet formulas has been fixed.
- An intermittent problem accessing files from an IIS WebDAV server has been fixed.
Coming very soon: Docx compatibility.
For more information, see http://www.bytesquared.com/products/office/iPad
Download:
LANGUAGES: English, Arabic, Chinese, Danish, Dutch, French, German, Italian, Japanese, Korean, Norwegian, Polish, Portuguese, Russian, Spanish, Swedish
REQUIREMENTS: Compatible with iPad. Requires iPhone OS 3.2 or later.
