Hi,
I have a little trouble with this ROM, or I'm doing sg wrong. This is my third ROM on my P535. Upgrading was always easy and fast.
Yesterday I tried to install the wm6.5 after this ROM 6.1
Downloaded, unpacked, USB inserted , OFF+rec+up+reset pressed as always. But this time an error occured "USB pipe opening error".
I read a few topic about it, but nothing solved this. The same problem when I tried from my notebook. Then I tried to install original Asus WM6 rom via SD card. But there is also a problem: "Failed to copy update files to the device!"
Because upgrade wasn't problem earlier I think that it's caused by this ROM.
Any help would appreciated! Thanks!
Gyurci
