Panorama 360 Camera
NguyenTu
Panorama 360 Camera
This app is designed for both iPhone and iPad.
Category: Photo & Video
Feb 03, 2012
Version: 4.5
5.8 MB
Seller: haiqun deng
© yuan song tao
LANGUAGES: English
REQUIREMENTS: Compatible with iPhone, iPod touch (4th generation), iPad 2 Wi-Fi, and iPad 2 Wi-Fi + 3G. Requires iOS 4.1 or later.​
Thông tin
Description
ONE touch, yes just ONE touch! Pano Camera 360 support Gyroscope Auto Shutter now (iPhone4 and iPad2), you just need to move and move, the camera will capture frames automatic. It is the best way to make high quality panorama photo within 10-30 seconds.
Wouldn’t you like a view of the really big panorama picture?
Ordinary cameras seldom capture the full impact of breathtaking landscapes, city scenes and tall buildings. Even if you’ve got a wide angle lens, it’s hard to squeeze everything into the frame and do the scene justice.
To pack more into the picture, photographers traditionally use the
trick of shooting several frames, shifting the camera’s position to capture different parts of the scene. These shots are combined to create one extra-large image. However it’s a fiddly manual process
that demands skill and patience to stitch frames together without obvious joins.
Now there’s a fun, easy way to create seamless, ultra-wide pictures with a huge field of view of up to 360 degrees, that’s equivalent to a wide angle lens wie in one frame. It is easy and quick.
Pano Camera 360 takes the hard work out of creating fabulous panoramic shots. And best of all, you don’t need a Computer or special software: everything’s done for you inside the iPhone.
Pano Camera 360 can automatically capture and combine a high-speed burst of full-resolution images.Just click the shutter button and sweep the camera clockwise from left to right across your scene. Click done button at the end and wait for the app process all frames. Frames are then stitched together automatically inside the camera: the whole process takes just 10-60 seconds.
Very high resolution:
Sweep Wide mode captures dramatic panoramic shots with detail-packed
11453x1280(360 degress) pixels.
Features:
Adjusting the lans curvature.
White Balance/Brightness Lock to reduce difference for frames
Good for both INDOOR and OUTDOOR
Sweep/Auto shutter, easy and Quick
Accelerometer supported
Gyroscope auto shutter (iPhone4/iPhone4s and iPad2 only)
Very high resolution (Stitch Ultra-wide mode: 11453x1280
for IP4s/iPad2, 5720x640 for IP 3GS)
Recommended shooting distance: >2M
Recommended avoid large areas of walls and sky(Low contrast background)
Flash Light(iPhone4 only) Supported
3D view interface
Landscape and Portrait supported
Universal supported (ipad2 tested)
