Phá Hình Vẽ Và Mật Khẩu Cho SamSung W I8150 !
Taki7610
Unlock_GSM
Samsung I8150 correct way for Hard Reset & solved Too many pattern attemps problem .
________________________________________
Samsung Galaxy Wonder I8150 correct way for Hard Reset
solved too many pattern attemps .
For what problem ?
• Too many pattern attemps
• hang and related problem
Here Hard Reset
Problem: Too many pattern attemps
Procedures:
* Press and Hold "volume Up" and "Home" buttons and press power on, wait until the screen display like this.
* Press "left soft" key to display "Android System Recovery Utilities"
* Select "wipe data/factory reset" by pressing "volume down" key
* Press "Home" button to select.
* Press "Volume Dow" key to select "Yes"
* Press "Home" button again and wait until finished
You are now completely reseted the phone back into his factory settings...
