Thấy ở 4R xda-developers có bản này có vẻ mới nhưng không có thời gian up thử. Bạn nào có thời gian thử xem thế nào nhé.
This is rDosti V.6 based on the Kitchen of WM 6.1 - THING_V41.build28
Date of Release: June 23, 2008
This is a Vanilla ROM - I have removed everything I could think of to get you 31 to 32MB RAM Freed up & 47MB STORAGE !!
In order to see the below effect, after initial startup be sure to go to Settings - Home Today - and remove extra front screen options (except messages) or remove all Home Today options for even more ram. This is our first ROM that actually gives you 31.4 to 32MB ram for Regular Mode and same for the 128Dpi Mode.
Interestingly in our Version 5, our 192Dpi (normal edition) gave us just 30MB, this version 6.0 gives us 31.9MB (starts at nearly 33MB at boot) !
BE sure to use the attached Ext-Rom Unlock Cab to get 9.xx MB Additional Storage! Also be sure to use Oxios once to recover extra RAM (32MB)
Regular MODE:
Initial Startup Program Memory: 31.44 MB Free
Initial Startup Storage Memory: 37.86 MB Free
Initial Storage from Unlocked Ext. Rom: 9.xx MB Free
VGA 128 Dpi Mode:
Initial Startup Program Memory: 31.90 MB Free
Initial Startup Storage Memory: 37.91 MB Free
However this is a VGA Vanilla ROM (+Good,-Bad/Issue):
+ Added VGA Swictching (tested most of the sizes)
+ WM 6.1
+ No hangs, No Freezes, No battery drainage issues (24 hour usage/standby/usage)
+ Tons of Free Program Memory
+ Supports 16GB SDHC (Tested requires attached .cab)
+ Added Oxios CloseApps
+ Fixed BT-GPS Issues
+ Works on both 64 & 128 Universals
- ROM version & Date will always show "Thingv41 & 2007 date" (Don't really know how to change that - help would be appreciated)
- 8GB MMC Issues (some 8GB cards fail to work, others work fine. The 16GB MMC I tested works great though!)
Important Update:
June 23, 2008
Due to demand of more Vanilla Roms and the fixing of GPS - BT issues, Ive decided to stick around and help release more stable and more fixed up ROMs.
I have released V6 rom which should fix the issue with BT-GPS.
DOWNLOAD:
http://rapidshare.com/files/124485256/rDostiv6.zip
Cập nhật link tải bản rDosti V.7:
Cập nhật 2-7: rDosti V.11 (WM6.1)-Vanila ROM-+37.80MB Free RAM / "80MB" Storage/disk
WHAT'S NEW IN VERSION 11? (Changelogs)
+ More Free RAM (+/- 38 MB)
+ 3.5 CF (NetFramework)
+ New Camera.exe used
+ RamDisk now supports 32MB storage!
+ Performance Improvement (Drivers oriented)
+ 80MB File Storage (Converts ram into "temporary"storage if required)
+ Support for both 64/128 Uni, Both G3 & G4 devices
+ Added Windows Mobile Office Cab (Ext-rom, Optional)
+ SDHC Support
+ Implementation of Memory Cleaners (Oxios and TaskMgr)
+ Added New Ringtones as well (Ext-rom, Optional)
- Issues with Camera (Burst Mode Exist).
Link tải:
Regular MODE:
VGA 128 Dpi Mode:
+ WM 6.1
Important Update:
June 23, 2008
DOWNLOAD:
http://rapidshare.com/files/124742337/rDostiv7.zip
+ SDHC Support
Link tải:
http://rapidshare.com/files/126486478/rDosti_v11.zip
