Recommend useful iPod/iPhone Manager Tools for Winodws and Mac users
percyvonn
Itunes is indispensable application for iPod and iPhone users, but sometimes when we want to manage files in iPod or iPhone, such as: Backup files from iPod/iPhone to PC, import video, audio files or folders from PC to iPod/iPhone, or transfer files from one iPod/iPhone to another one, etc, it is very troublesome to use the itunes.
So today I would like to share some useful iPod/iPhone Manager Tools for Winodws and Mac users.
1. Aiseeoft iPod Transfer
2. Aiseesoft iPhone Transfer
3. Aiseesoft iPod Manager for Mac
4. Aiseesoft iPhone Transfer for Mac
The following guides will respectively introduce their functions in details!
For iPod users:
Part 1: How to transfer files to iPod/iPod to PC/iPod to iPod
Preparation:Install and run Aiseesoft iPod Transfer
Step 1: connect your iPod to your computer via USB cable
Step 2: According your needs to select the the functions
If you want to import video/audio files to your iPod, click “Import files to iPod” button;
If you want to transfer iPod files to PC, click “Transfer files to PC” button;
If you want to transfer iPod to iPod, click “Transfer Files between iPod” button.
Step 3: After you have finished the above two steps, just follow the instructions on it to complete your demands.
Part 2: How to transfer files to iPod/iPod to Computer on Mac
Preparation:Install and run Aiseesoft iPod Manager for Mac
If you want to import video/audio files to your iPod, click “Mac to iPod” button;
If you want to transfer iPod files to PC, click “iPod to Mac” button.
Step 3: After you have finished the above two steps,just follow the instructions on it to complete your demands.
For iPhone users:
Part 1:How to transfer files to iPhone/iPhone to PC/iPhone to iPhone
Preparation:Install and run Aiseesoft iPhone Transfer
Step 1: connect your iPhone to your computer via USB cable
If you want to import video/audio files to your iPhone, click “Import files to iPhone” button;
If you want to transfer iPhone files to PC, click “Transfer files to PC” button;
If you want to transfer iPhone to iPhone, click “Transfer Files between iPhone” button.
Part 2: How to transfer files to iPhone/iPhone to Computer on Mac
Preparation:Install and run Aiseesoft iPhone Transfer for Mac
If you want to import video/audio files to your iPhone, click “Mac to iPhone” button;
If you want to transfer iPhone files to PC, click “iPhone to Mac” button.
Look, with the programs above, you can easily manage your iPod/iPhone files, no waiting, try now!
AVCHD Converter
Free FLV Converter
AnhTu
Translate
Itunes là ứng dụng không thể thiếu cho người dùng iPod và iPhone, nhưng đôi khi chúng ta muốn quản lý ảnh trong iPod hoặc iPhone, ví dụ như: các tập tin sao lưu từ iPod / iPhone với PC, nhập khẩu, video, các file âm thanh hoặc thư mục từ máy tính đến iPod / iPhone, hoặc chuyển các tập tin từ một trong iPod / iPhone với một số khác, vv, rất phiền hà để sử dụng với itunes.
Vì vậy, hôm nay tôi muốn chia sẻ một số iPod hữu ích / Công cụ quản lý cho iPhone và Mac Winodws người sử dụng.
Các hướng dẫn sau đây sẽ giới thiệu các chức năng tương ứng của họ trong các chi tiết!
Phần 1: Làm thế nào để truyền dữ liệu đến iPod / iPod với PC / iPod to iPod
Chuẩn bị: Cài đặt và chạy Aiseesoft iPod Transfer
Bước 1: kết nối iPod của bạn vào máy tính qua cáp USB
Bước 2: Theo nhu cầu của bạn để chọn các chức năng của
Nếu bạn muốn nhập khẩu video / audio files to iPod của bạn, nhấp vào "Nhập tập tin vào nút" iPod;
Nếu bạn muốn chuyển các file iPod với máy PC, bấm nút "Chuyển các tập tin về máy tính" nút;
Nếu bạn muốn chuyển iPod to iPod, bấm vào "Truyền tập tin giữa các nút" iPod.
Bước 3: Sau khi bạn đã hoàn thành hai bước trên, chỉ cần làm theo các hướng dẫn trên đó để hoàn thành yêu cầu của bạn.
Phần 2: Làm thế nào để truyền dữ liệu đến iPod / iPod đến máy tính trên Mac
Chuẩn bị: Cài đặt và chạy Aiseesoft iPod Manager for Mac
Nếu bạn muốn nhập khẩu video / audio files to iPod của bạn, nhấp "Mac để iPod" nút;
Nếu bạn muốn chuyển các file iPod với máy PC, bấm vào "iPod với máy Mac" nút.
Đối với người sử dụng iPhone:
Phần 1: Làm thế nào để chuyển các tập tin cho iPhone / iPhone với PC / iPhone cho iPhone
Chuẩn bị: Cài đặt và chạy Aiseesoft iPhone Transfer
Bước 1: kết nối iPhone của bạn vào máy tính qua cáp USB
Nếu bạn muốn nhập khẩu video / audio files to iPhone của bạn, nhập khẩu nhấn "tập cho iPhone" nút;
Nếu bạn muốn chuyển file iPhone với PC, bấm nút "Chuyển các tập tin về máy tính" nút;
Nếu bạn muốn chuyển iPhone vào iPhone, bấm vào "Truyền tập tin giữa các nút" iPhone.
Phần 2: Làm thế nào để chuyển các tập tin cho iPhone / iPhone vào máy tính trên Mac
Chuẩn bị: Cài đặt và chạy Aiseesoft Chuyển iPhone cho Mac
Nếu bạn muốn nhập khẩu video / audio files to iPhone của bạn, nhấp "Mac cho iPhone" nút;
Nếu bạn muốn chuyển file iPhone với PC, iPhone nhấn "Mac" nút.
Nhìn, với các chương trình trên, bạn có thể dễ dàng quản lý iPod của bạn / files iPhone, không phải chờ đợi, hãy thử ngay bây giờ!
AVCHD Converter
Free FLV Converter
