Ripping Blu Ray DVD and Standard DVD with one tool
mayersusan
Now Blu Ray DVD is popular as the high definitional video effect and tremendous storage capacities, but as we all know, Blu ray DVD can only be played on DVD players, but what we should do if we also want to enjoy the Blu Ray movie on our mobile devices such as PSP, iPhone or Zune?
So here I want to intruduce a powerful tool, which is Aiseesoft Blu Ray Ripper, it can not only rip Blu Ray DVD, but also common DVD. Now the following two parts will show how to do this.
Part 1:How to rip blu ray DVD to video formats
Make preparation: Download and install Aiseesoft Blu Ray Ripper
Step 1: Click "Load Blu Ray" to load your Blu Ray Disc in to your blu-ray driver.
Note: You must first install AnyDVD before you load Blu Ray files. In the process of converting blu ray video, please do not close AnyDVD. Please make sure your AnyDVD is not expired.
Step 2:Select output video format.
After you select the files you want to convert, you can select the output format from "Profile" drop-down list.
You can also click "setteing" button to adjust the settings of your output video, such as "video/audio encoder", "Video/audio Bitrate", "Channels", "Resolution" and so on..
Step 3: Video Editing
Except the "Effect, Trim, Crop" funtions, you can also add txt and picture watermark to your vide. To select word font or adjust your word position is also available.
Step 4: Click "Start" button to start your conversion
Part 2:How to rip Common DVD to video formats
Step 1: Click "Load DVD" to load your dvd.
The editting functions such as "effect, trim, crop, watermark and merge" are also available.
Step 4: Conversion
Click the "Start" button to begin to rip your DVD.
Following is the sceenshot of supported input formats, output formats and devices
TS File Converter
Free Youtube Converter
Mac DVD Ripper
