![wtfxbc.jpg](http://i47.tinypic.com/wtfxbc.jpg)
lang thang trên XDA thấy có rom mới up thử xài thấy ok nên giới thiệu cho mọi người xài thử.
Các tính năng:
- Android 4.1.1
- CM10 Kernel
- Superuser & Busybox preinstalled
- Deodexed
- Built in performance/init.d configuration
- Advance Power Menu
- Brightness Slider On Status Bar - Yes Its In There
- Quiet hours
- AOKP Wallpapers
- Mute Camera Sounds
- AOKP Statistics
- Battery Bar
- Expandable Volume Panel
- LED Options
- Clock Location: Right, Center, Disable
- Battery Icon: CircleMod, Bar, Text Only, Icon Only, Icon+Text or None
- Toggles: Auto rotate, Bluetooth, GPS, Wi-Fi, Aiplane mode, Vibrate, Silent, Sync, Data, 4G, Tethering, Torch, Brightness
- More .. See Yourself
lỗi
- Tethering FC's (Try Barnacle wifi tether from playstore * it works )
- Camera - Front Only Force Closes ( If you try and are not able to revert back follow these steps )
1.Go to Settings
2.Go to Apps
3.Search for System Apps
4.Go to Gallery
5.Clear data
-Video Recorder
-FC on Launcher after switching a few times from portrait to landscape and back. ( Happens Sometimes )
Video playback issues try turn off HW overlay
DOW ROM UP NÀO
link dow rom Nik_Jellybean_Evolution ở STC
Md5 Sum: f8cf7a365351bac243cb808ab55bf42a
dow thêm file Gapps ở STC
HƯỚNG DẪN UP ROM
1. ROOT + RECOVERY (có hướng dẫn cũa bác PhamQuang hoặc bác Phoenix
2. Enter recovery
3. Wipe data/factory reset
4. Wipe cache / dalvik cache
5. Install zip from sd card
đợi quá trình up rom hoàn thành thì up tiếp file Gapps
giờ thì cùng hưởng thụ nào .
[video=youtube;n3717MKLp3E]http://www.youtube.com/watch?v=n3717MKLp3E&feature=player_embedded[/video]
