[ROM] Android Revolution HD 6.3.3 | High Quality & Performance | O/C | Legendary
coolpixs4
Ngại dịch sang TV, bác nào ko hiểu thì hỏi mình trả lời.... Hiện mình dùng thấy ROM này GOOD nhất
>>> Very fast | rock stable | stock look | great support <<<
Source [xdadevelopers]
System details:
Android 2.3.5 (Gingerbread) - latest official HTC RUU 3.12.405.1 (WWE)
This is improved version of stock ROM - no visual changes!
Very fast, clean & stable!
Full HTC Sense 3.0 Interface
Multi-language (WWE)
Arabic and Hebrew languages support! (see the second post)
For HTC Desire HD & HTC Inspire 4G
Thanks to HTC for the base firmware
Video Review by Flow-Wolf
Included kernel details:
New kernel: 2.6.35.14 (under-volted & tweaked)
CPU up to 1.61 GHz (1.15 GHz by default) - controlled automatically by built it O/C Daemon.
If you want to control CPU manually, you would need SetCPU from here: SetCPU
In SetCPU remember to check "Set on Boot", but using O/C Daemon gives much better performance and battery then SetCPU
Many CPU governors (SmartAss, Ondemand, Performance, Conservative, UserSpace)
GPU+ patch (Improved 2D & 3D Graphics performance - Thanks to -snq)
V(R) I/O as default scheduler
SLQB Memory Management
CIFS, TUN & UTF8 support
LZMA compression
Wi-Fi module improved drivers
2-way recording patch
Possibility to change VDD levels dynamically - check question 21 in FAQ
Code cleaned up with custom voltages, tweaks & many more!
You can find custom kernels here
Kernel source
ROM details:
Removed software (CPU) rendering - full Adreno200 (GPU) rendering
Fully optimized and tweaked
ROOT (su + SuperSu Permissions - Thanks to chainfire)
Unsecured boot.img
Newest BusyBox
RAM optimizations
System signatures check enabled for system security and safety
Improved virtual memory management
Speed optimizations
Enabled GPU UI rendering
SD Card speed tweak
Data, cache and system partitions mounting tweaks
Battery auto-calibration script (Thanks to seo)
Bloatware applications removed
All /system applications updated to latest available
All /data applications updated to latest available
Improved camera performance
Improved CPU governors performance
Most optimal system scheduler
Disabled kernel debugging for better performance
ZRAM ready!
Advanced Power Menu and CRT Animation as extra add-ons
Zipaligned (Improved RAM management)
Zipalign on boot (for user applications on data partition)
Fully de-odexed
init.d scripts (BusyBox run-parts) support
Auto init.d permissions set on boot
sysro/sysrw commands support
Excellent battery life!
Improved EXT4 performance
You can replace HTC boot animation with any custom one (or use ICS default)
SD card EXT4 partition support
OpenVPN support
4EXT Recovery (Thanks to madmaxx82)
Most up-to-date system files permissions
A lot of themes made for my ROM & plenty of extras like Advanced Power Menu or CRT in the second post
Support almost 24h a day ...and many more!
You need:
For HTC Desire HD S-OFF ---> [TOOL] One click ENG S-OFF
For HTC Inspire 4G S-OFF ---> [GUIDE]Inspire 4G, Rooting, Flashing, Softbrick, Fixes, Sideloading
Radio S-OFF in order to flash new radio ---> [TOOL][VIDEO] One click Radio S-OFF, SimUnlock (Easy Root Guide)
4EXT Touch Recovery by madmaxx82
If you have problems or further question, please read this guide ---> [GUIDE] How to flash a ROM onto your Desire HD
--- release date: 8 May 2012 ---
Tweaked ondemand governor
Fixed [sys/kernel/debug] being unmounted
Added small compability fix for GPU Performance Patch
Debugging only via the application's manifest for better performance
SuperUser by ChainsDD replaced with SuperSU by chainfire (latest version)
Google Play (Android Market) updated to latest 3.5.16
Facebook updated to latest 1.9.2
Fixed auto-permissions on boot for init.d scripts
Gmail updated to latest 2.3.6
YouTube updated to latest 2.4.4 and moved to data/app
Adobe Flash Player updated to latest 11.1.111.7
Adobe Reader updated to latest 10.2.0
Google Plus updated to latest 2.5.0.329322
ES File Explorer updated to latest 1.6.1.3
Google Maps updated to latest 6.6.0
Maxthon updated to latest 2.6.2
Twitter updated to latest 3.2.1
Recovery updated to latest 1.0.0.4 RC3
Zip-aligned using newest SDK r18
Included latest DropBox because HTC merged with DB
Other minor changes and fixes
--- MD5 Checksum: C78E3A444D7BCC1DB7E5FEA7B486E871 ---
Download
Super Wipe
--- This script will erase and format your data, system and cache partition ---
--- Your SD card will remain untouched FAT32 and it's recommended to leave it like that ---
Download
Mods for Android Revolution HD 6.3.x/7.0.x
http://forum.xda-developers.com/showthread.php?t=1384197
[THEME][v3.9 Dec 17] BlueHD for ARHD 6.3.x (includes beats audio)
http://forum.xda-developers.com/showthread.php?t=1258453
vip_47
có bác nào biết bản 7.0.4 file boot.img ở mục nào ko giúp mình với. thanks
coolpixs4
trong *.zip, folder kernel có 2 file *.img là lord.img và rcmix.img
bạn lấy 2 file đó ra rồi đổi tên thành boot.img
Theo tôi đánh giá bản 6.3.3 chạy mượt và cảm nhận là tốt hơn 7.0.4
vip_47
Đổi file nào vậy bạn? Nếu đổi cả 2 file thì nó ra 2 cái boot.img,vậy biết lấy cái nào ah? Thanks all
vip_47
Ah các bác đã cài bản 7.0.4 rồi cho mình hỏi là bản 7.0.4 có thêm tính năng gì mới do với bản này vậy ah? Sr mình là mem mới của android nên chưa biết gì nhiều về hdh này ah. Mong các pro chỉ giáo thêm ah. Thanks
venusian
Bạn dùng cái Kernel nào thì đổi cái đấy. Rồi áp dụng cách Flash file boot.img theo cách này của mình: http://www.pdaviet.net/showthread.php?207437-huong-dan-nap-file-bootimg-vao-may-one-x-voi-s-on
Bản 7.0.4 là Sense 3.5 - Android 2.3.5 (Gingerbread) - đc leck từ Rom của HTC Sensation XL RUU 1.05.401.4.
Bản 6.3.3 là Sense 3.0 - Android 2.3.5 (Gingerbread) - latest official HTC RUU 3.12.405.1 đc build từ phiên bản Rom của ship của DHD
vip_47
Mod tư vấn dùm mình nên chọn kenel nào thì tốt.nhất ah. Thanks mod nhiều ha
vip_47
Hix bản 6.3.3 này bác nào cài rồi cho mình hỏi xíu. Bản này có bị lỗi máy quay film và camera ko ah, và sau khi cài xong thì free ram đc bao nhiêu ah. Mình cài bản 7.0.4 thì bị lỗi cái quay film và free ram đc có 160mb. Nhờ các bác dùng rồi tư vấn dùm minh với ah.thanks
coolpixs4
Hix bản 6.3.3 này bác nào cài rồi cho mình hỏi xíu. Bản này có bị lỗi máy quay film và camera ko ah, và sau khi cài xong thì free ram đc bao nhiêu ah. Mình cài bản 7.0.4 thì bị lỗi cái quay film và free ram đc có 160mb. Nhờ các bác dùng rồi tư vấn dùm minh với ah.thanks[/QUOT
Bản này cook từ rom gốc của DHD thì sao mà có lỗi gì được ?
người cook chỉ Tweak và làm cho nó tốt hơn thôi, bạn đọc thông tin ở post #1
sau cài đặt RAM free >345MB, như mình cài 1 số app như Easy battery saver+adds on Easy Task Killer thì RAM free lúc nào cũng tầm 400MB
vip_47
Hix bạn cài sao mà free ram đc nhiều vậy. Mình cài xong vào ktra thì free đc có 160mb thôi ah. Mình cài bản 7.0.4. Còn quay film thì quay đc, nhưng bấm dừng thì nó ghi là tắt ko đúng cách. Vào ktra thì nó ko có seve. Có bác nào cài bản 7.0.4 bị giống mình ko, chỉ mình cách fix với ah. Thanks
phong19c
Bạn ơi cho mình hỏi, máy mình chưa s-off còn s-on (đã root, unlock bootloader, recovery) có cài được rom này không?
coolpixs4
đã root, unlock bootloader+recovery thì tất nhiên là cài được rom này
