[ROM] MeDroid ICS 4.0.3 CM9 V4.2 07/01/2012 - Thảo luận và chia sẻ
kutamitsu
Chuẩn bị :
1. have blackrose and the new partition table
2. partition ext3/4
3. full wipe
HBOOT INSTRUCTION BY TEXASICE:
Originally Posted by texasice View Post
[STOP]
For full ICS
You must install blackrose hboot before flashing ICS. Instructions.
BlackRose
Flash this custom blackrose with new partition scheme.
System 220MB Cache 16MB Data 200MB
HBOOT : Mirror MD5: 7147c1bf480ddd0bf2857efb146c056a
Flash:
Code:
fastboot flash hboot hboot_220-16-200.nb0
fastboot reboot-bootloader
to activate the a2sd type in the terminal:
a). su
b). a2sd reinstall
c). a2sd cachesd (to move the Dalvik cache to ext)
d). a2sd zipalign
Working: [person who helped fix it]
cm9 build and mods: [samuaz] :p
automatic network connection [samuaz]
3g (Radio: 5.08.00.04)
Accelerometer (rotation) [texasice][chrs2021]
Bluetooth [texasice]
Calling
Compass [texasice][chrs2021]
Gps
Hardware Acceleration [Rapmv78][rmcc]
Headphone jack [zivan56]
Home button [MongooseHelix]
Led (TrackBall) Notifications
MMS
Network Stats and Quota [texasice]
Screenshots
Sound [sean neeley][texasice]
Signal Strength [cm][texasice]
TouchScreen (w/ Multitouch) [dr1337]
Trackball (navigation) [texasice] (clicking) [jaybob413]
Native USB Mass Storage [tytung]
Wifi [cm]
Wifi Signal Strengh Icon in Status Bar. [preludedrew]
Wifi Tethering
NEW:
init.d [MongooseHelix]
a2sd [texasice]
Trackball wake [texasice]
Camera [rapmv78]
Not Working:
Gapps might not work properly (Please don't complain there is nothing I can do to fix this)
Full Hardware Accelaration (need msm-3.0 kernel)
Tethering (USB)
MTP
Vídeo camcorder
MeDroid ics cm9 v4.2 7/01/2012
- fix for mic and dalvick cache in ext
- add torch, titanium backup (free version) and filemanager
- new inbuild a2sd+ script from texasice evervolv, No need flash any extra, for move apps and dalvik to ext type in terminal:
1. su
2. a2sd install (apps and dalvik its move together)
3. for more commands type a2sd help
- full native usb mount storage support from @tytung, usbmountstorage apk from bexton its no more needed, so thanks bexto for your great app
- back to old gallery2, the new with picasa sync gives more problems than this, it hangs more than usual, remember that we are working even without opengl it is normal to sometimes freeze or lag, its you need picasa sync install the Googlegallery.apk via adb
http://forum.xda-developers.com/show...&postcount=191 thanks to lebartman
- and others who do not remember at this time (so many things I play I always forget some things)
ok in my nexus is working on everything right, I have no problems, so before I say something does not work or have problems, try to do a full wipe and return to try.
for people who say that it reboots when installing an application of the market, no problem is the problem of rom its your ext partition, repair them or turn to him to reformat using recovery amonra or 4ext, i not recommend using cwm
you can flash the last zkernel if you like, I'm using and not problems, by default comes with the Tiamat kernel.
now the widget of the flashlight in the notification bar, not available, will have to manually open torch, let me review it to try to have it ready in the next version
Download http://depositfiles.com/files/sy8i4239g
donwload from pc and no have problem, but if anyone can upload a mirror
Nguồn : http://forum.xda-developers.com/showthread.php?t=1411429
kutamitsu
MÌnh thấy rom này bên xda phát triển rất nhanh và tốt nhưng thực sự là vốn tiếng anh + kinh nghiệm chưa có nhiều nên mình cũng chưa biết up cụ thể như thế nào, đặc biệt là bước :
a). su
b). a2sd reinstall
d). a2sd zipalign
Mình nhớ là cái này giống hồi crack spb shell 3d, nhưng mình cũng chưa làm bao h.
Và hình như phải phân vùng thẻ nhớ trước thì mới có bước C. Cao thủ nào biết xin chỉ giáo giùm với
TaQuangDuc
Not Working:
Tethering (USB)
MTP
Vídeo camcorder
Quan trọng là cái này, 1 vài cái mình rất cần thì chưa fix được và có vẻ là tương lai khá mờ mịt
happyghost2000
N1 khó có thể sử dụng hoàn chỉnh Android 4 . Mình nghỉ phần cứng không tương thích .
Mình mới mua SS2 chạy Android 4.0 tuyệt vời .
Mong rằng thành viên XDA sẽ cố gắng hết mình vì N1, Chúc các bạn vui vẽ
kutamitsu
MUi cũng đang build bản chế ICS, N1 là đứa con đầu tiên của Google mà, kiểu gì chả được chăm chút hì
TaQuangDuc
update: đã dùng được camera, video record, nhưng chưa sử dụng được USB, vẫn phải chờ thêm
kutamitsu
chờ nó hoàn chỉnh nâng cấp cái thẻ luôn thể, dùng cái class 4 8GB nếu mà phân vùng thì lại hơi thấp.
nhatientri
Nay có 1 bản update nho nhỏ trên xda đó,
nghe nói họ đang phát triển tiamat kernel cho n1.
haisolo
a). su
b). a2sd reinstall
d). a2sd zipalign
mìnhm ko biết TA nên củng ko hiểu đc bước này nên ko cài dc ics.hic.hic
mà sao các diển đàn tại VN ko có hướng dẫn chi tiết các bước cài rom ics????????????????
Mong rằng sẻ có cao nhân nào hướng dẩn chi tiết và tổng hợp rom ics trên topic riêng để giúp ae có cơ hội mở rộng tầm mắt.thank
TaQuangDuc
ICS còn tồn tại vài lỗi đặc biệt trầm trọng là USB mount (tác dụng đọc SD như thẻ nhớ qua cổng usb) và 1 vấn đề nữa là Google App (market, Gtalk... chạy vẫn chưa chuẩn) vậy nên phe bảo thủ như mình chưa ngâm cứu
kutamitsu
usb mount thì có ứng dụng khắc phục rồi mình đã cài thử khi cài miui ics. Nhưng cơ bản là cài rom này lằng nhằng quá nên cũng ko khoái mấy.
beti
đã test thử. mình thấy chạy mượt, nhưng Gallery hay bị treo, game chạy không tốt = 2.3.7
_h2_
cho mình hỏi blackrose để làm gì và cài thế nào ! Cảm ơn nếu làm đc bài hường dẫn thì tốt quá :D thank :D trước
