Rom mới "WM 6.1 20273 HORNET " a e cùng test thử
anhvanlaanh1987
BrightRom update; based on TNT)
BTFTP (BT Filesharing)
BTBPP (BT Printing)
Commanager 2.0.8.0
ExplorerEXT (extended File Explorer
Hornet Beta 2.2 theme (designed to be as simple as possible to take the least amount of ram)
Inbox Extender (dll)
Inbox Menu Extensibility (dll)
Increase Ring Volume (reg)
IRDA (dll) - Beam BT/IRDA
Yellow Keyboard Skin
Network Plugin (app)
Network Wizard (app)- configures network settings
One Calc Lite (app) - replaces standard calculator
Opera Mini (app) Esmertec Java + OperaMini 4.1
HTC Gesture (dll/reg)
Diamond Outlook Enhancement (dll/reg)
Smart Touch (dll/reg)
PocketXpdf (app)
Arcsoft MMS 5 (mutation)*
Disable Securuty Warning When Installing Non-Cert Apps (reg)
Enable Auto TimeZone from Network "NTIZ" (reg)
Retro PPC (today Plugin) the huge clock on the today screen***
Security Off (reg)
Smartskey (app/dll) lets you long tap the softkeys for menu and OK/CLOSE
Ariel Battery 2 (app) a battery meter that covers up the ugly windows start flag. colors can be changed. http://forum.xda-developers.com/show...=ariel+battery
S.V.I Camera 3.3 (mutation)**
DotFred Task Manager 3.1.0.1 (app) - the most functional task manager there is for ppc
QuickMenu 2.7.388 (app) - Replaces the start menu; tap and hold to close apps; mem/batt meter; Screen/SIP/bluetooth toggle;Hybernate/suspend/reboot/execute/IE favorites; and more.
TouchFlo (app/dll/reg) - touch scroling
Google Maps 2.1 (app) - navigation for those who do not have GPS. gives you your aproximate location via cell tower triangulation; directions; conatct lookup; business search/dial; and more
MS Voice Command (app) - MS voice dial and messages reader. It is supposed to be a launcher and media player control, but I don't know how well it works.
WM5torage (app) - lets you use your phone as a card reader. mine is a 2gb microSD/MiniSD adapter. helps with speed and loading thumbnail on the computer.
Full Office 6.1 (app suite) - Excel; Notes; OneNote; PowerPoint; Tasks; Word - compatable with Office 2008 docx format
VoIP (not tested)
And Then Download here:
http://www.badongo.com/file/10819397
Bản Rom này tác giả base từ bản TNT mới nhất!!!! Ai có thể giúp đưa lên host khác cho a e dễ download :D
bonmat8888
Vừa upRom xong, chưa biết nó có gì đặc biệt không...., trước mắt thấy free Ram ít quá (chưa cài đặt thêm j ngoài Pocket Controller để capture. Up mấy cái hình cho mọi người xem
ghekua
vừa up xong, nản luôn, xài được 5' up lại rom kia. Cái này pagepool = 4mb hay sao y', sợ quá, ram ít kinh người, lại còn cài thêm mấy cái google map ( xài với GPS, mà miniS thì có dùng được cái này đâu) với lại touch flo, voip tốn ram kinh, xài TNT Vanilla cho nó lành. Nhớ bác hongkong quá, chả hiểu dạo này bác bận việc hay sao mà không thấy bác làm rom mới up tặng cho anh em. Dù sao mình là người Việt vẫn thích xài rom made in Việt Nam hơn là made in Australia .
hector
thấy giao diện được fet nhỉ?nhưng thấy đồn kô ổn về tốc độ thế này thì...ngắm thôi!
evilcca
Sao nhìn cái màu vàng là thấy gai gai rùi hjhj. 2 thanh trạng thái trên và dưới trông cứng nhắc nữa.
VUHEO
Dòng ROM này được xem là tệ nhất trong các loại Rom cho Vizard. Nhưng tác giả vẫn miệt mài cho ra sản phẩm mới. Chỉ đáng tham khảo chứ đừng up, chân thành
bonmat8888
chậm lắm. nhắn tin một lúc mà Ram tụt xuông còn 13-14mb....đang muốn up lại diamond....
0988456766
Chán chơi 6.1, chán Diamon, chán SpbShell. Up lại bản Wm5 chơi Active 02 thấy hay hơn. Cái Active O2 hay thế mà sao Wm6 ko có nhỉ. X-(
vuquang
cac bac ơi sao em không tải được bác nào giúp em với em cám ơn nhiều nha
khanhham
da bác nao Download được chưa vậy nếu dơload được rồi thì up cho anh em thưởng thức với thanks;nhiều nha
