hacbaoklhh
Welcome to the VictoryMod!
This ROM is based on latest CyanogenMod releases
Also tweaked to get a very fast, stable cool rom with some extras! Thanks to LorD ClockaN for the kernel!
Some features:
* Host files updated
* Build prop tweaks
* SD Card speed fix
* Fully Zipaligned
* Latest LordModUE kernel
* Latest 4EXT recovery included
* Latest super user
* Updated apps
* Battery improvements
* Speed tweaks
* Optimized with init.d scripts
* Latest Google Apps included
* Multilanguage (WWE)
* Bloadware removed
* 2 Way call recording support
* Wake-up CPU speed @ 384Mhz, Max CPU speed @ 1075Mhz. Can be OCed to 2000Mhz
You can change it by using the CyanogenMod settings!
* And more i forgot!
Install Instructions:
To install this rom you need to wipe your partitions to EXT4.
Use the VictoryMod EXT4 Wipe to do this! Thanks to Mike1986.
This WIPE will completely wipe your device but your SDCARD will be untouched!
If you come from a lower version of VictoryMod you can just flash it on top of it, but full wipe is recommend for the best performance!
CWM: 4EXTRecovery recommend for flashing the rom and scripts!
Recommend radio:
Radio_12.65.60.29_26.14.04.28_M
**CHANGELOG**
Downloadlink:VictoryMod 2.8
- Build on Latest CM7.2 from 16 Sept!
- Complete rebuild
** Lot's of fixes and speedups
- Build.prop tweaks added
- All apps updated
- Latest PlayStore included
- Rom cleanups
- 2WCR Support
- Insane speed & battery life!
- More tweaks i forgot!
** Full wipe required
MD5 Checksum: 47a2e91ff7a90fb33def40326bbef232
VictoryMod 2.8
xda
