[ROM][WWE][Park's ROM]WM6.1/WM6.5/WM6.5.5 SERIES.
ntt2006
http://www.pdaviet.net/showthread.php?85343-[ROM][WWE][Park-s-ROM]WM6-1-WM6-5-WM6-5-5-SERIES&p=1156426#post1156426[ROM][WWE][Park-s-ROM]WM6-1-WM6-5-WM6-5-5-SERIES&p=1156426#post1156426Mình xin mở Topic này để giới thiêu Rom của Tác giả ParkBom từ XDA.Topic này sẽ cập nhật các phiên bản rom mới nhất.
Park Basic Series /Windows Mobile 6.1/Manila 2.1/Manila 2.5
attachment.php
Park Nicki Series/Windows Mobile 6.5/Manila 2.1/Manila 2.5
attachment.php
Park Lotus Series/Windows Mobile 6.5.5/Manila 2.1/Manila 2.5
attachment.php
Park Lotus Series/Windows Mobile 6.5.5/Manila 2.5/Max Manila
NOTES
Sense => HTC Sense 2.5 không có tab ereader, footprints, documents reader, maxmanila..
SenseMaxManila => HTC Sense & MaxManila nhưng không có tab ereader, footprints, documents reader..
Sense+ => HTC Sense 2.5 và tab ereader, footprints, documents reader..
Sense+MaxManila => HTC Sense 2.5 và tab ereader, footprints, documents reader & MaxManila..
http://www.pdaviet.net/showthread.p...-1-WM6-5-WM6-5-5-SERIES&p=1156426#post1156426Park Nicki Series/Windows Mobile 6.5/Manila 2.5/MaxManila
attachment.php
NOTES
ntt2006
Cập nhật [Park's ROM][Sense 2.1/2.5][21056/23541/21893]
Thông tin:
Park Basic Series
Park Basic 1.3
-Updated HTC Apps: (very limited)
*aGPS Confirmation*Connection Setup*CommManager*HTCAnimation
*HTCGeoservice*IME Engine*IME Ezinput*Message Enhancement
*SimContactsImport*StreamingMedia*TimeZoneAutoFix* USBToPC
-Updated WinMo Apps: (from 6.5.5 SYS)
*Windows LIVE 10.6.58*WindowsLIVE IM 10.6.58*RemotedDesktopMobile*
*OfficeMobile 2010 14.0000.23541
-Neos Driver Pack 2010
-NetCF 3.5.9198.0
-Cooked in Opera 9.70.35801.0 and GoogleMaps 4 (Updated)
-reverted colored icons
Park Basic 1.3
Storage: Total: 335.37 MB In Use: 13.36 MB Free: 322.01
Program: Total: 188.32 MB In Use: 63.66 MB Free: 124.66 MB
LINK DOWN
Park Lotus Series
Park Lotus 1.0
-Initial Release
Park Lotus 1.0
Storage: Total: 315.57 MB In Use: 15.96 MB Free: 299.62 MB
Program: Total: 187.98 MB In Use: 86.93 MB Free: 101.05 MB
LINK DOWN
Park Nicki Series
Park Nicki 1.0
-Initial Release
Park Nicki 1.0
Storage: Total: 317.81 MB In Use: 14.76 MB Free: 303.05 MB
Program: Total: 187.98 MB In Use: 82.17 MB Free: 105.81 MB
LINK DOWN
doquangduc
Đang Up thử xem nào. Bước đầu cảm nhận bản Lotus 1.0 là khá nhanh và mượt. Mới dùng được 30", nên chưa thấy lỗi gì
ntt2006
Mình thì đã up bàn Park Nicki Pro,cảm nhận là rem free rất tốt,chạy mượi.
Lổi :
- Music tab không update list nhạc tỏng thẻ nhớ.
- Nhắn tin thì khi xoay máy thì màn hình sẽ chuyển sang nằm ngang nhưng nếu thoát ra thì không tự xoay lại được mà phải vào lại phần nhắn tin để xoay màn hình.
doquangduc
Bản Lotus 1.0 này cái Taskmanager không có trên thanh Taskbar, thay vào đó lại hiện thị giờ, nên hơi bất tiện. nhưng cũng có thể khắc phục bằng cách cài thêm Taskmanager. Nói chung là chạy mượt và Ram Free tốt.
thanhson1411
mình đã sang bên xda down rồi.....rom này máy mình xài bản Park Nicki đã có lúc lên đến 110mb.Đúng là bản room kinh nhất trước h cài.Tiện thể cho mình xin file cab để zoom camera với cả để cài file java.
ntt2006
Mình đã up thử bản SenseMaxManila và có nhận xét :
- Build 23542
- Manila 2.5_20121225
- Max Manila
- Rom nhẹ,chạy mượt.
- Ram free tốt.
- Cần phải cài SignedRilphone để cập nhật my location.
- Tab music không tự động load list nhạc, để fix lổi này thì cần tháo thẻ nhớ ra và lắp lại (không tắt máy).
Vài hình ảnh :
thomastn
ROM này vẫn măc định múi giờ là US-8 Pacific. nên tron Tab thời thiết nếu đề 2 thành phố HANOI va HCM thì khi chon 1 thành phố làm chuẩn thì giờ cùa thành phố kia.... nhảy múa...
Nói chung là ROM này ổn, mình mới phát thấy lỗi đó.
ngoài ra có 4 icon mặc định ở màn hình Home có vẻ như bị trùng với các phím bên dưới. ví dụ ở dưới đã có phím phone rồi thì ko cần icon để vô phone nữa... hình như cái icon giống của Fring cũng dẫn đến Calendar như thanh trượt bên dưới.... có cách nào thay đổi mấy icon mặc định này ko các bạn?
ntt2006
Múi giờ thì bạn có thể vào Clock&Alarm để chỉnh lại múi giờ cho đúng,còn về 4 icon mặc định thì không thể đổi được,các icon đó sẽ chuyển nhanh đến Call History,Calenda,Message và email.Mình thấy cũng rất hay vì nếu bạn để chế độ ẩn tab trong maxmanila thì với 4 icon này cùng với quicklink thì bạn chỉ cần thao tác các tác vụ tại home tab thôi,rất tiện lợi.
thomastn
cũng thích cai ROM này nhưng mà vụ list nhạc thì tháo thẻ nhớ ra vô 5 lần vẫn ko đọc nhận đuoc... hix mới ưng với V92 của chú Quang đuoc mấy ngày bây giờ bị problem treo, tự động tắt phải chọt đít... chẳng biết xài ROM nào nữa... chẳng lẽ quay vê Topix thì đơn điệu quá....
ntt2006
Cách xử lý cho lổi của tab Music thì khi bạn chuyển sang tab music thì bạn hãy lấy thẻ nhớ ra và lắp vào lại (không tắt máy)thì tab sẽ tự động load list nhạc bình thường,bạn hãy thử lại xem.
thomastn
mình đã làm như thế 5-6 lần rùi bạn... vẫn ko đuoc... hay tại cái mày mình nó thế... hàng xách tay từ Mỹ về...
Bạn có thề giới thiệu giúp bản ROM nào được được chút ko? ROM bạn đang xài lài gi chẳng hạn... mình vẫn chưa ưng cái nào cả....
