TruongHan
Trò xếp Rubik quen thuộc,chỉ cần xếp các mặt trùng màu với nhau là xong,xem bạn mất bao lâu thời gian để hoàn tất trò này
.Ứng dụng java nên giao diện đồ hoạ không được đẹp lắm
Xem hình minh hoạ dưới đây để hiểu thêm cách chơi
![rubik.jpg](http://miravalles.info/varios/rubik.jpg)
Instructions
I've done the game with the hope there was no need of an user manual. But doing some tests with real users I realized that its not so intuitive I thought. So, that's the user manual:
1. To rotate a face of the cube, you have to press in that face and do a movemente in the direction you want to rotate. Note that you have to press in the face you want to rotate. Therefore you only can rotate one of 3 faces each time. To move other faces, yo have to rotate the whole cube.
2. To rotate the entire cube, in order to view other faces, you have to press and move the pointer outside the cube. You can move vertically or horizontally depending on the main component of your movement in the x,y axis. Once you release the pointer the cube stay in the normalized position closest to actual rotation, i.e. the cube rotates allways a entire number of 90º degrees.
![rubiklevo.png](http://www.shrani.si/f/1d/4j/4mLXCGqK/rubiklevo.png)
![rubiknaprej.png](http://www.shrani.si/f/4/uR/4AJg2iIu/rubiknaprej.png)
![rubiksrednja.png](http://www.shrani.si/f/1a/Rj/Tp1a7HW/rubiksrednja.png)
![rubikzadi.png](http://www.shrani.si/f/G/jL/2BwQRJl9/rubikzadi.png)
