[S60v2] UC Browser-7.4.0.57 EN Closed Beta Translate by YAKISARA™
Khoi_Vjz_Boy
UCWEB-7.4.057-27-10082511 EN Closed Beta Version
The second round of closed beta
Test focus: WAP2.0 analysis.
Functional development and optimization:
1.WAP2.0 optimization, a new analysis engine, support more dazzling effect.
2. Skins optimization, the menu is more convenient to use.
3. To increase the default setting to download call UC Thunder
4. Camera function optimization, support zoom function
5. Input box Search Box from the painting, more convenient to input use (V5)
6. Search Results page opens a new window
7. Bookmarks interface, interface and other UI effects optimization history
Main bugfix
1. To solve wap site lost map problem arise.
Known Issues (Do not report the following problems)
1.V5 click on input box and search box will be flashed, filling the system, the proposed system for a light color theme can be temporarily resolved.
2. Sina 3G version of the upper-left corner of the picture shows bad, is restoration.
3. Spacing wap site failure, post will do to improve.
4. Select the box to restore the site to the real effect, selected, only the box, and other sites to show how the definition of what.
5. Theme files and ucs video feeds will not call the Thunder download.
6. In the past saved UTHM format, 7.4 can not open properly.
7.V5 help documentation errors, late replacement will do.
8. Part of the model home problems would be fixed.
This version need an your phone imei number for registrasion. How to register it?
Its simple.
1. Install Python 1.45 or higher and Zntxhan 2.04 or higher.
2. Run zntxhan and press menu (left softkey)>Start>Hexadecimal way (see Reg.gif)
3. Browse and open file UCWEB74.app in System>Apps>UcWeb74
4. After showing the Hex screen. press menu>Edit>Search>UTF-8 code.
4. On box Find Content fill it by typing "004400701690172" then press OK and wait for while.
5. After find result use (C) Key to delete the bloked content.
6. After deleted press Menu>Edit>Insert>Enter Your Imei number>OK.
7. Then press Menu>Save>OK or by pressing Right Softkey>Save modify>OK for saving.
8. After this step ok and working you can deleting the original file (UcWeb74.app_.bak file).
Nguồn dotis.com
Ai dịch hộ kái
Đã TEST ngon trên N70
Download
http://www.mediafire.com/?a4ffv5ptiesgbv2
shooter157
UCWEB-7.4.057-27-10082511 EN Phiên bản Closed Beta
Vòng thứ hai của phiên bản beta đóng cửa
Kiểm tra tập trung: phân tích WAP2.0.
Phát triển và tối ưu hóa chức năng:
1.WAP2.0 tối ưu hóa, một công cụ phân tích mới, hỗ trợ nhiều hiệu ứng rực rỡ.
2.Skins tối ưu hóa, trình đơn là thuận tiện hơn để sử dụng.
3.Để tăng thiết lập mặc định để tải gọi UC Thunder
4. chức năng tối ưu hóa, hỗ trợ chức năng zoom
5. Nhập vào ô Search Box từ bức tranh, thuận tiện hơn để đầu vào sử dụng (V5)
6.Kết quả tìm kiếm trang mở ra một cửa sổ mới
7giao diện, giao diện và lịch sử tối ưu hóa các hiệu ứng UI
Chính bugfix
1. Để giải quyết vấn đề trang wap bị mất bản đồ phát sinh.
Được biết vấn (Không báo cáo các vấn đề sau)
1.V5 bấm vào hộp nhập liệu và hộp tìm kiếm sẽ được chiếu, điền vào các hệ thống, hệ thống đề xuất cho một chủ đề màu sắc ánh sáng có thể được tạm thời giải quyết.
2. Sina 3G phiên bản của góc trên bên trái của hình ảnh cho thấy xấu, là khôi phục lại.
3. Khoảng cách thất bại trang web wap, bài sẽ làm gì để cải thiện.
4. Chọn hộp để khôi phục lại trang web để có hiệu lực thực tế, lựa chọn, chỉ có hộp, và các trang web khác để hiển thị như thế nào định nghĩa của những gì.
5. Chủ đề các tập tin và video UCS nguồn cấp dữ liệu sẽ không gọi cho tải về Thunder.
6.Trong quá khứ đã lưu UTHM định dạng, 7,4 không thể mở đúng cách.
7.V5 giúp lỗi tài liệu, chậm thay thế sẽ làm.
8. Một phần của vấn đề nhà mô hình sẽ được cố định.
Phiên bản này cần một số điện thoại của bạn imei cho registrasion. How to register it? Làm thế nào để đăng ký nó?
đơn giản của nó.
1.Cài đặt Python 1,45 hoặc cao hơn và Zntxhan 2,04 hoặc cao hơn.
2. Khởi zntxhan và menu báo chí (trái softkey)> Start> Hexadecimal cách (xem Reg.gif)
3.Trình duyệt và file UCWEB74.app mở System> Apps> UcWeb74
5.Sau khi hiển thị màn hình thập lục. . bấm menu> Edit> Tìm kiếm> UTF-8 mã.
6.Trên hộp Tìm nội dung điền vào nó bằng cách gõ "004400701690172", sau đó bấm OK và đợi trong khi.
7. Sau khi sử dụng kết quả tìm thấy (C) khóa để xóa các nội dung bloked.
8. Sau khi đã xóa nhấn Menu> Edit> Insert> Nhập số IMEI của bạn> OK.
9. Sau đó, nhấn Menu> Save> OK hoặc bằng cách nhấn chuột phải Softkey> Save thay đổi> OK để lưu.
9.Sau bước này ok và làm việc bạn có thể xóa các tập tin ban đầu (UcWeb74.app_.bak file).
bạn nao` down bàng dd thì ở đây nhé,mình kèm theo zntxhan cho các bạn cài đặt.have fun!
manhtu
Bản này giới hạn IMEI sử dụng nên phải dùng SD để sửa lại IMEI thì mới có thể dùng đc
Tduy
UC 7.4 sao mà cùi bắp quá, duyệt chậm, trang web hiển thị ko hài hòa,... 7.3 vẫn OK hơn !!
cute09
Chờ bản final rồi chơi.Beta dùng làm gì, đc mấy hm lại gỡ.
