TP.HCM Samsung GALAXY Note 3 SM-N9005 4.3 unlock Ok !
Taki7610
Unlock_GSM
To connect GT-N7100 phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->Developer options.
3. Turn on "USB Debugging" option.
4. When message is appear press "Yes".
5. Connect usb cable to phone.
6. Go to dial window.
7. Enter *#9090# number.
8. Set speed to 115200.
9. Go to dial window.
10. Enter "*#7284#" number.
11. Set "UART" radio button to "MODEM" value.
12. Set "USB" radio button to "PDA" value
13. Press "Read Info" in software.
To connect SC-01C phone you have to perform the following steps:
2. Go to Menu->Settings->Applications->Development.
4. When the message appears press "Yes".
5. Connect USB cable to the phone.
6. Press "Read Info" in software.
To connect SM-N9005 phone you have to perform the following steps:
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
Platform: Samsung Android
Selected port: COM343
Selected model: SM-N9005
Mode: Emergency
Unlock for SM-N9005 phone in emergency mode can’t be done
Selected port: COM342
Mode: Normal
Phone model: SM-N9005
Firmware compiled date: Aug 23 2013
Firmware compiled time: 04:00:00
Firmware released date: Oct 30 2013
Firmware released time: 13:50:11
Phone IMEI: 351542-06-136810-2
SW version: M8974A-AAAANAZM-1.0.180057
Unlocking phone...
Creating NVM backup
Reading NVM done!
Connecting to ADB, please waite...
Firmware compiled date: Wed Oct 30 16:58:12 KST 2013
PDA version: N9005XXUDMJ7
CSC version: N9005OXXDMJ4
SW version: N9005XXUDMJ7
Phone IMEI: 351542061368102
Phone SN: R31DB17YRXJ
Android version: 4.3 (JSS15J)
Cheking Root
Erasing old IMEI. It can take some time. Please wait...
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N9005-351542061368102-16-06-2014_16-30-01-.asec file
Phone will restart now. Please don't disconnect cable!
After phone being rebooted and powered on perform the following steps:
1. Disconnect USB cable.
2. Wait for 1-2 minutes.
3. Connect phone via UART cable to the Box.
Serching phone...
Phone found.
Writing new IMEI. Please wait...
Please connect phone to USB cable and press OK button.
Serching phone...
Incorrect IMEI
Found phone on COM342
Repairing NVM for SM-N9005 phone...
Repairing 3G/4G...
3G/4G repair successfully
Phone is successfully unlocked
