TP.HCM Samsung Galaxy S3 i9300 Unbrick Ok !
Taki7610
Unlock_GSM
- Phone tình trạng mất boot - unbrick nạp rom lại ok !
SDC Direct Access Connection Module
Card Reset Done!
Initializing Micro SD Card...
Card Initialized OK (V2.0 Compliant)
Waiting for IDLE State...
Card is now IDLE!
Reading Micro SD Card Information...
Manufacturer ID : 0x03
Application ID : SD
Product Name : SU16G
Product Revision : 8.0
Serial Number : 09C33EEC
Manufacture Date: July 2013
Card CID: 03534453553136478009C33EEC00D789
Card CSD: 400E00325B59000076B27F800A404013
Card SCR: 0235800100000000
Card OCR: 00C0FF8000
SD Card Size : 15931539456 Bytes
SD Block Size: 512 Bytes
Maximum Speed: 25000000 Hertz
SDHC / SDXC Card Detected...
Checking Lock Status...
Micro SD Card is NOT Password Protected!!!
Erasing SDC...
Samsung GT-I9300, I9500, N7100 UNBRICK Image
Start Writing to SDC at 0x00000000...
Number of Blocks: 0x0002B055
Process Done...
1. Insert Micro SD Card to Phone
2. Make Sure Battery is Fully Charged
3. Connect UART Cable (150K Resistor)
4. Wait upto 5 Minutes...
5. Remove Battery and Remove Micro SD Card
6. Flash Phone with ODIN
Total Elapsed Time 00:01:03
