Taki7610
Unlock_GSM
To connect SM-N900A phone you have to perform the following steps:
1. Disconnect USB cable from phone.
2. Go to Menu->Settings->More->About Device.
3.Tap on "Build number" 7 times to enable developer options.
4. Go to Menu->Settings->More->Developer options.
5. Turn on "USB Debugging" option.
6. Go to dial window.
7. Enter "*#0808#" number.
8. Select "DM+Modem+ADB".
9. Press Home button.
10. Go to dial window.
11. Enter "*#9090#" number.
12. Set "Diag config" to "USB" value.
13. Restart phone.
14. Press "Read Info" in software.
To connect SM-N900T phone you have to perform the following steps:
13. Restart phone.
Platform: Samsung Android
Selected port: COM145
Selected model: SM-N900T
Reading info, please wait...
ADB server killed.
Detected phone model: SM-N900T
Firmware compiled date: Fri Aug 22 19:12:58 KST 2014
PDA version: N900TUVUDNF9
CSC version: N900TTMBDNF9
SW version: N900TUVUDNF9
Phone IMEI: Unknown
Phone SN: RV8F30KHJ2F
Android version: 4.4.2 (KOT49H)
Phone IMEI: Unknown
Reading info...
Mode: Normal
Firmware compiled date: May 09 2014
Firmware compiled time: 20:00:00
Firmware released date: Aug 22 2014
Firmware released time: 16:51:49
SW Version: M8974A-AAAANAZM-2.0.10059
Reading QCN...
Send SPC...
Reading mobile property...
Mobile property read successfully
Reading feature mask...
Feature mask read successfully
Reading roaming list 0
Reading roaming list 0 read successfully
Reading NV items...
NV items read successfully
Reading NV SIM1 items...
NV SIM1 items read successfully
Reading NV SIM2 items...
NV SIM2 items read successfully
Reading NV items...
Reading EFS...
EFS read successfully
Reading provisioning items...
Provisioning items read successfully
Reading QCN done!
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\QCN-SM-N900T-04-01-2015_10-46-56-.qcn file
Checking Root:
Phone is Rooted.
Reading security backup, please wait...
Backup saved as C:\Program Files (x86)\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-N900T-04-01-2015_10-50-30-.asec file
Wiping EFS...
EFS wipe successfully
Phone will restart now
Searching for a phone. Please wait...
Reading info...
Mode: Normal
Send SPC...
SPC send successfully
Writing QCN...
Writing NV items...
NV items write successfully
Writing NV SIM1 items...
NV SIM1 items write successfully
Writing NV SIM2 items...
NV SIM2 items write successfully
Wrting EFS...
EFS write successfully
Writing provisioning items...
Provisioning items write successfully.
Writing QCN done
Wipe security successfully complete.
Selected file must be *.cert
Writing Certificate failed
Selected file: H:\Box Setup\IMEI CERT - QCN\cert&qcn\cert&qcn\SM-N9000Q_359542050950920_RF1F33CV0D.cert
Phone IMEI: Unknown
Checking Root:
Phone is Rooted.
Checking Certificate file...
Certificate file successfully checked
Writing Certificate...
Phone connected successfully
Writing new phone IMEI...
Checking certificate compatibility...
Certificate is compatible
Certificate has been written successfully
Please, restart the phone to apply changes
13. Restart phone.
Reading info...
Mode: Normal
Send SPC...
Writing QCN...
Writing NV items...
Wrting EFS...
Writing QCN done
QCN write successfully
Platform: Samsung Swift
Selected model: GT-S3570
Selected port: COM4
Baud rate: 115200
Please, connect phone to UART cable, insert battery and press power button for 3 seconds.
Connecting...
Phone in TAT mode.
Phone IMEI A: 35333905849677
SW version: S3570XXMB
Bluetooth MAC: 08FD0E24BD37
Phone SN : RV1F32S555
Reading phone unlock codes. It can take some time, please wait...
FREZEE : 00000000
NET LOCK : 00000000
Subset LOCK : 00000000
SP LOCK : 00000000
CP LOCK : 00000000
SIM LOCK : 00000000
Activa LOCK : 00000000
User LOCK : 00000000
