sn0wbreeze Jailbreaks iPhone OS 3.1.3 : blackra1n & ultrasn0w Can Still Unlock
nguyenhai2310
Well folks, that didn't take long at all. We now have the ability to jailbreak and unlock the iPhone on the new OS 3.1.3 only days after it's release. We have two options for different basebands, 04.26.08 and 05.11.07.
Sn0wbreeze 3.1.3 can jailbreak iPhone 2G, 3G and iPhone 3GS (old bootrom only) on iPhone OS 3.1.3. (Guide to follow.) It also jailbreaks the iPod Touch 1G and iPod Touch 2G (model number not starting with MC). Baseband 04.26.08 can be unlocked using Ultrasn0w. If your baseband is 05.11.07, GeoHot's blacksn0w will work just the same as it did before. (That was released last year )
For those of you that have never used any of these programs, please head over to our guides section. Note: We have NOT tested this method. Be smart. Don't do this unless you absolutely have to, or if you want to test and inform others of your success/failure stores Again, THIS IS FOR OLD BOOTROMS OF THE 3GS. If you have jailbroken 3.1.2 previously and the jailbreak was untethered you have the old bootrom. If you have a newer 3GS, just stay away.
Cash EDIT/
A couple notes. iPhone 3GS and iPod Touch 2G users check your model number Settings -> General -> About. If it starts with MC don't try any 3.1.3 jailbreak.
Next, for those of you that do not know, sn0wbreeze is a custom .ipsw creator for Windows much like the dev team's pwnagetool is for Mac. There are things you need to be aware of because of this. First of all grab the correct firmware for your device. Making a custom .ipsw for the wrong device will do you no good. Second the custom 3.1.3 firmware you create with sn0wbreeze is restored to your device via iTunes. Do not use DFU mode, normal recovery mode should be sufficient. Last and most important YOU CAN NOT restore the custom .ipsw that sn0wbreeze makes on to your device unless you device is ALREADY jailbroken. If you aren't jailbroken then jailbreak your current firmware (under 3.1.3) using the software of your choice (redsn0w, balckra1n, pwnagetool, wtvr), then create the custom 3.1.3 .ipsw with sn0wbird, then restore it on to your device using normal recovery mode and iTunes.
After you have restored your custom 3.1.3 firmware on to your device you can unlock. iPhone 2G users search for bootneuter in cydia. Users with baseband 04.26.08 search for ultrasn0w in cydia. Baseband 05.11.07 users add the repo blackra1n.com to Cydia and search for blacksn0w.
I have not tried this jailbreak yet so try at your own risk. We'll get a guide up asap assuming everything is working fine (read in 6 hrs when I wake up).
/Cash EDIT
Official 3.1.3 Firmware directly from Apple:
Download iPhone 3.1.3 firmware for iPhone 2G
Download iPhone 3.1.3 firmware for iPhone 3G
Download iPhone 3.1.3 firmware for iPhone 3GS
Download 3.1.3 firmware for iPod Touch 1G
Download 3.1.3 firmware for iPod Touch 2G
Download .NET Framework 3.5 (required to run Sn0wbreeze)
Download Sn0wbreeze 3.1.3 for Windows
MMi Member Download
Rapidshare
Megaupload
Nguồn Modmyi.
hai7641
Cái này là gì vậy bác???
HuynhThanh
Theo thông tin trên là dùng Sn0wbreeze 3.1.3 để tạo được bản F.W custom tương ứng với I.P 2G, 3G, 3GS (old bootrom) trên OS 3.1.3 bạn à!
dungeasy
Snowbreeze 3.1.3 để tạo 1 firmware custom 3.1.3 , up lên vẫn giữ được baseband , và unlock bằng công cụ cũ , nhưng máy có số MODEL bắt đầu là MC của 3gs hay ipod touch gen 2 thì đừng thử jailbreak cách này ( A couple notes. iPhone 3GS and iPod Touch 2G users check your model number Settings -> General -> About. If it starts with MC don't try any 3.1.3 jailbreak )
Khi tạo ra và restore firmware custom bằng snowbreeze không nên đưa về chế độ DFU mà để ở recovery mode !
Orbit
Dear Anh Dũng...
Cách này có ai thử chưa vậy? mình có con 3G 8G chạy FW 3.1, nhưng cái Cydia nó khìn, đang cần up lại FW... ko biết có làm được cách này ko nhỉ?
Chỉ giúp nhé
Thanks
saigon3
Các bạn cẩn thận sau khi xong khởi động lại nó cứ chạy cái hoa tuyết suốt không thể nào hoạt động được . . .
Mình đã làm thử 3 lần đành phải bye bye nó khg thấy tốt lành gì cả !!!
vanduc
iPHONE của mình là số 87933....... , model MC131X.Vậy có jailbreak được không? ( 3GS phiên bản quốc tế )
conanlinh
Cập nhật lại chút, đoạn này không chính xác lắm, hiện thời 3G Lock và 3GS Lock vẫn chưa thể unlock được trên firmware 3.1.3 ;;)
Zenki
Nếu Up lên 3.1.3 Gốc và BB đã lên thì không Unlock được, còn nếu Up bằng FW Custom lên BB vẫn còn giữ lại thì vẫn Unlock vô tư :D
hailua_8
Với FW 3.1.3 custom - 3G lock với BB 04.26.08 đã chính thức confirmed unlock với ultrasn0w rồi, còn lại BB 05.11.07 thì vẫn chưa có ai xác nhận đến thời điểm hiện tại!
Zenki
BB 04.26.08 thì Unlock bằng Ultrasn0w
BB 05.11.07 thì Unlock bằng Blacksn0w
Còn BB mới của FW 3.1.3 - 05.12.01 thì hiện tại chưa Unlock được
hailua_8
Câu nầy cũa em cần phải cẩn thận check lại, không thể nói "vô tư" như thế được. Tránh sự ngộ nhận cũa các thành viên trên nầy em nhé. Hiện tại cho tới thời điểm nầy với 3G phiên bản At&T với BB 05.11.07 vẫn chưa có thành viên nào chính thức xác nhận là có thể unlock với blackra1n được.
Em đừng có viết ra theo info như thế. Cái cần là bằng chứng xác thực để các thành viên khác biết mà làm. Vấn đề là không phải theo info mà phải chính thức được kiểm tra bằng người thật việc thật! Em đã thật sự chính tay mình làm chưa mà viết ra như thế? Anh đang chờ câu confirm từ em từ khi lập topic tới giờ mà vẫn chưa thấy gì hết.
Zenki
Có gì mà phải Confirm nữa :|
Tìm đọc lại - cái này - xem BB 05.11.07 đã Unlock được chưa :|
Có ai đã Confirm BB 05.12.01 đâu :|
