SpaceTour 1.2 iPhone iPod Touch
azerty250776
Imagine a tour of the solar system from your great device? You can take a look in 3D of the space, planets, starting on your Spacecraft, Show to your friends, children, family the planets
location in space, and the asteroids belt between Mars and Jupiter. You can see spin of both the planets and the sun , and every planet has the two important movements, The first is the rotation of every planet around an invisible axis, and the second important movement that affects every planet is its revolution around the Sun. You can see the 3D asteroids belt and you can fly nearly them with your spaceship.In order to obtain the data of each planet you must smoothly touch each planet, and the information will appear in the screen. You can accelerate your spaceship and go more fast touching the control on the right of the screen.
dl:
http://rapidshare.com/files/229739501/sptrok.zip
