có cái này cho anh em chơi BA đây . Mình tìm được một ít thông tin anh em xem nhé :
Working Android on BA! (tested myself)
Hi, yesterday i was trying to launch android on my BA and i DID IT!
It works like shit:
Touchscreen doesn't work (you can activate list scrolling by pushing it on the side)
Some buttons don't work
No sound
Navigation:
D-pad (left, right, up, down)
Enter (on the keyboard, since D-Pad center doesn't work)
!WARNING! there is no end call and back buttons, you can't exit applications
How to? Here is the tutorial:
Create a folder on your memory card
Get the latest HaRET from here
http://handhelds.org/~koconnor/haret/
Get the latest zImage from here
http://www.angstrom-distribution.org.../htcblueangel/
(i use zImage-2.6.21-hh20-r16-htcblueangel.bin)
Rename it to zImage
Put that default.txt
Code:
set kernel zImage
set initrd "initrd-android.gz"
set CMDLINE "rootdelay=3 root=/dev/ram0 ramdisk_size=23504 init=/linuxrc"
boot
Now you need the system - Android
Get that:
http://it029000.massey.ac.nz/vogue/initrd-android
Don't forget to rename it to initrd-android.gz
I've got it from here
i tested android and seems a good toy
i did make a rar with all files needed, you need only to extract to SD and run haret
Code:
http://rapidshare.com/files/147524450/android.rar.html
i'm really interested to go further on android.
about my tests, i can conclude two things:
- D-pad works, but not very well
- Touch screen is not working, but i know it detect moves on it
(try to dpad a icon, then touch the touch-screen, you ll see)
I'm not a expert on pocket pc, but i have my skills.
I found an other thing, hardware specification.
Code:
http://www.handhelds.org/moin/moin.cgi/BlueAngelHardware
if the information is right, the touchscreen is from the same family that the vogue one.
To continue this adventure, i need some lights. I know we have a developer from the kernel/Opie/GPE in this forum. If you are him, i need some lights about your work.
The other thing, i'll try to do is asking help to vogue/kaiser android project, to give me some lights how they touchscreen work.
The last thing. All the help is appreciated, everybody is invited in this project and all the help is welcome. And i really need it lol
udapte (23/9/2008)
Well i talk do vogue android project man, and the answer from him is simple. His work was only to port kernel to vogue platform. I will have to find who made the one we are using.
anh em xem có đầy đủ nhé.
