TruongHan
Giới thiệu cho các bạn Symbian Tool,công cụ làm việc hiệu quả như PC Suite làm việc trên PC
Công cụ giúp bạn Sao lưu,phục hồi,dọn rác,chỉnh sửa,dọn dẹp bộ nhớ MASS MEMORY ....
Cách sử dụng :
Kết nối điện thoại với PC ở chế độ mass storage(bộ nhớ chung) qua USB,install Symbiantool.exe và chạy chương trình
Cách sử dụng :
This is a useful tool to do bunch of tasks:
Backup, Restore, Cleanup, Edit, Optimize, Sterilize Symbian MASS MEMORY storage.
How to use? Connect the phone in mass storage mode to PC via USB cable, install Symbiantool.exe in your PC, and run the program on PC.
note1: Click on top right to change the language.
note2: The tool does NOT work in Bluetooth mode, but works only with the phone is connected with the USB cable.
So, the phone MUST be connected in Mass Storage mode.
Detailed Features:
optimize data (fast symbian defrag)
backup/restore multimedia (media copy)
backup/restore everything (image copy)
cleanup settings, applications
cleanup thumbnails
cleanup registry
copy images
copy sounds
copy videos
move images
move videos
Cleaning tools:
* Jubble - Cleanup registry, applications, settings, cache, leave all the rest
* Sterilize (jubbler++) - Cleanup registry, applications, settings, index files, cache, maps, widget, personal folders, patches, thumbnails, dictionaries, demos, examples, downloads, games, backup settings (Leave only photo, video and audio).
* Regkiller - Quickly cleanup symbian registry, removes installed applications.
* Thumbkiller - Remove image thumbnails and index files
* Optimizer - Remove registry dead links, empty directories and orphans, to speedup phone.
* Quick defrag - Optimize symbian mass storage file system, to speedup file access and boot times.
Backup tools:
* Quickbak - Backup multimedia and personal documents in a click
* Quickres - Restore multimedia and personal documents in a click
* Fullbak - Backup a complete image of your symbian storage
* Fullres - Restore a complete image of your symbian storage
* Custom transfer - Transfer (copy) last photos and videos from the cellular, in a click
* Custom move - Move last images and photos AWAY from cellular phone to PC, in a click
* Selective files copy/move - Choose which files, to move or copy from the cell phone to PC and vice versa
Optional tools (install them on the phone):
*Battery.sis - Reduce cpu time of idle processes, to increase battery performance
*savesms.sis - saves sms into .txt files, just add the phone number of the sender and the sms will be saved into a .txt in the root of mass storage
Important! Be very careful to what you do with this tool! Always perform a full backup, before you try the different functions of this tool.
Certain features may delete your data. Try to experiment with it, and see what features you will find useful.
