Sau 1 thời gian im hơi lặng tiếng, hôm nay tác giả ít-right tiếp tục tung ra 3 bản rom như thường lệ: Official/Professional/TouchFLO
Base Rom:
5.2.1620 build 18125.0.7.0
OS: 11.0.0.2 << as you know, 11.x.x.x is for TNT Series or based on
Official Edition:
- 1-Calculator
- Commanager 1.2.0.0 new
- ArcSoft_MMS_5_0_27_5 new
- Camera
- Modem Link (DUN)
- Streaming Media 2.1.1025.621(Fixed) new
- Some tweaks for battery drain and WiFi issues
- Office latest version with zip view and OneNote.
- SIM Manager 6.38 new
- PIM Backup 2.8 new
- Tsk Manager (with registry editor)
- SMS Backup new
- Windows Live Messenger 10.6.0034.800 new
- Net Compact Framework 3.5.7283.0 new
Professional Edition:
- camera app
- 1-calc.
- Modem Link (DUN)
- Network Wizard 1_0_29982_7 support many of networks (Auto run disabled, go to start/settings/connection to set you network settings)
- SmartKey 0.56 (the best settings)
- SoftKeyAppletEx (to change Home SoftKeys)
- WM5torage 1.78 Final new
- STK Service 4.69 new
- TimeZone Tab on the phone settings (just the tab w/o enabling which may show some issues with starup)
- All Help files as the official
- Internet Sharing
- Advanced Config Tool 2.0.2.0 new
- BT_FTP 1_2_30489_1
- BT_SAP 2_02_b0925_r3.
- BtIO 0.6 (to listen sounds via the BT Headset)
- Dr.Yar 1.6 (to show the BT sender name and set the recieving folder).
- MJConfig
- Event Countdown 1.0 (timer)
- GroupSMS 1.2 new
- GSFinder+
- black keyboard
- HTC Audio Manager 1.2.614.712
- Pocket RAR 3.7
- Pocket Screen Capture.
- Mobile Justice
- Network Plugin 1_0_29714_1
- Notepad
- ClearTemp 0.9.6
- CloseApps
- Hibernate
- Peek Pocket 1.4 (WiFi networks manager)
- RealOne (rm ram ra player, files set to it)
- RunEveryDay.
- SMS Backup 1.1
- SMSService
- Total Commander
- WinXplore 0.3.4.1
- HTC Voice Recorder 1.10.611.711
- TaskManager 2.7.0.1 (with reg app shortcut)
- BT_BPP_1_5_0_0
- Call2Contact_1.0
- SK tsync
- 6 smart Games
- HTC_BT_Quicklink_0_4
- Hush SMS
- Alt Tab app.
- BtCrawler
- HTC Home 2_1_1005722_0 (many fixes compared with 1.5.xxx, first HTC Home 2.x for wizard "tnx hm4") new
TouchFLO Edition :
the same as professional edition with HTC Home and its settings on the Today/items tab, with the scrolling feature without the Cube (you can add it as an Add On) and also without VoIP (you can add it later, but make sure to download the new one for TNT.1933, it's compatible with TNT.1620) .
- RealOne removed because of the space (add it manually).
- BT_BPP_1_5_0_0 removed.
Download
[HIDE="http://pdaviet.net/showthread.php?do=post_thanks_add&p=271258"]Official:
http://rapidshare.com/files/90190650/TNT.1620_Official_Wizard.rar
Professional:
http://rapidshare.com/files/90182934/TNT.1620_Professional_Wizard.rar
TouchFLO
http://rapidshare.com/files/90268134/TNT.1620_TouchFLO_Wizard.rar[/HIDE]
Apps Informations:
** Dr.YAR 1.6 bluetooth:
many features, like:
- show bluetooth sender name.
- choose a location for files recieved.
- recieve when the device off.
- don't delete MS bluetooth, you can recive from both.
- ... MANY means MANY
if you want to use it, you find an icon on the tray, double click on it.
note: there is a white window if you recieve just hide it then open it again.
(very useful)
» Group SMS
Summary: Group SMS Solution. As the name suggest it is basically a program to send SMSes to a group of people at the same time. Following are the features: - Category Wise Contact Pickup. - Individual Contact Pickup made easy.
» Event Countdown v1.0
• Summary: From counting down to a movie event, to every day reminders to cooking a dinner. Event Countdown lets you add up to 200 events on your Pocket PC. You can countdown to a particular date or countdown from a se...
ClearTemp
• Summary: ClearTemp is an application for you to clear temporary/unused files and unused registry keys/values on your system easily. It also allows you to clear your Recent Program List, Internet Address History and b...
WinXplore v0.3.4.1
• Summary:WinXplore is a simple tool that allows you to manage certain folders under "\Windows\" in a quick and convenient way. Usage Notes:
- Select a Folder from the dropdown menu to navigate to a certain folder.
- Tap & hold in the listbox to add/delete a file from the folder.
Base Rom:
Official Edition:
- 1-Calculator
- Camera
- Modem Link (DUN)
- SMS Backup new
- camera app
- 1-calc.
- Modem Link (DUN)
- Internet Sharing
- MJConfig
- GroupSMS 1.2 new
- GSFinder+
- black keyboard
- Pocket RAR 3.7
- Mobile Justice
- Notepad
- ClearTemp 0.9.6
- CloseApps
- Hibernate
- RunEveryDay.
- SMS Backup 1.1
- SMSService
- Total Commander
- WinXplore 0.3.4.1
- BT_BPP_1_5_0_0
- Call2Contact_1.0
- SK tsync
- 6 smart Games
- Hush SMS
- Alt Tab app.
- BtCrawler
TouchFLO Edition :
Download
Professional:
TouchFLO
Apps Informations:
(very useful)
» Group SMS
ClearTemp
WinXplore v0.3.4.1
