Tom Topaz WM 6.5 v2.06 WWE Based Rom 2.06 ( CE OS 23007 / CE OS 21925 )
Tom_codon
Based Rom 2.06 ( CE OS 23007 / CE OS 21925 )​
Nền tảng Rom : Topaz 2.06.502.1
Hệ điều hành : Windows Mobile 6.5 Professional
CE OS 5.2.23006 & Build 23007.5.3.0
Phiên bản Rom : Tom.Topaz.2.06
Ngày build : 16/07/09
Phiên bản Rom : Tom.Topaz.WM6.5
Danh sách phần mềm :
AdobePDF_2_5_1_0_378273_01B
AdvancedNetwork_1_0_10_3
Album_3_2_19163529
App_Service_1_69_0_0
Arcsoft_MMS_WM65_5_2_0_22
Audio_Booster_2_5_19163527
Audio_Manager_Engine_2_0_19163527_h
AutoVolumeControl_1_3_0_0
BluetoothSetting_2_11_1_1
BootLauncher_1_0_19152530_1
BTBPP_1_9_3_0
BTSAP_3_2_0_R7
Calculator_1_0_19163530_00
Camera_6_15_35154_0
CleanGPSData_1_1_0_0
ClearStorage_1_40_0_1
CMBandSwitching_0_9_8_0
CMBluetooth_1_1_4_0
CMPhone_1_2_0_0
CMPin_1_3_0_0
CommManager_2_9_1_1
ConcurrenceMgr_1_5_19142726_00
ConnectionSetup_2_7_19153133_01
ContactUtiltiyEngine_1_0_19151624_0000
DataDisconnect_1_14_0_0
DeviceInfo_2_2_0_0
DiscretixDRM_1_0_20090602_00
DRMMiddleware_1_5_19142824_00
DShow_2_0_19163429_00
FacebookEngine_1_0_19153126_00
Facebook_v1_0_0_7
Field_T_e_s_t_2_19_0_0
FileUpload_1_1_0_1
FMRadio_1_7_19171122_00
FullScreenPlayer_1_6_19152225_00
GoogleMap_3_0_012_2
GSensorCalibrator_1_1_18212730_1
HTCAnimation_1_3_5_0
HTCApplication_1_3_5_0
HTCFDN_1_3_0_20
HTCFontLink_1_0_19132133_1
HTCMessage_1_00_281_0
HTCScroll_2_0_19153028_1
HTCSettings_1_4_1_1
HTCStartUp_1_7_0_0
HTCUtil_4_12_0_1
HTC_EmailSetupWizard_1_2_19161327_0
IME_Engine_Western_2_1_19162213_00
IME_EzInput_Western_2_1_19162213_00
Incall Recorder
InvokeSIMMgr_1_12_0_1
JbedJava_5_1_0_0_20090416_5_1
LongPressEndKey_1_2_19143124_00
Manila_2_1_38658_0
MediaToolkit_1_0_19171123_00
Menu_Enhancement_1_1_19162213_00
Message_Enhancement_1_1_19152932_04
mHubVO_1_77_090609_X0
MP3_Trimmer_1_2_19161513_00
Microsoft Voice command V1.6.23004
Mute_1_1_2_0
MyCPL_3_13_0_6
Microsoft My Phone
NewContactCard_1_0_19162213_00
NewMailAccount_1_11_0_1
Notification_Enhancement_2_0_1916_1430
Opera_Browser_9_50_16983_1
PhoneCanvas_3_50_35086_0
PhoneSetting_6_39_0_0
PictureEnhancement_1_50_19142727_00
PKG_1_1_0_0
PowerOffWarning_2_9_0_0
Power_3_1_0_0
PushInternetEngine_1_0_19152224_01
QuickGPS_1_1_19143124_00
RandomAccess_4_1_18224021_1
Redial_1_3_0_0
ResourceProxy_1_0_19151630_00
RingtonePlugin_1_0_19143328_00
RSSHub_2_1_1_1093_02
RunCC_1_1_5_0
SensorSDK_4_1_19161622_00
SharedModules_1.01.19142728.00
SignatureReplace_1_2_0_0
SIMLock_4_24_0_1
SIM_MGR_6_71_0_0
Social Networking
STK_Service_4_89_0_0
STK_UIPPC_4_67_0_0
StorageLow_1_0_0_2
StreamingMedia_3_1_19162213_00
StreamingSrcFilter_2_7_19143024_00
TaskManager_2_1_19163331_10
Task_Manager_ver
Teeter_2_0_19163530_00
TouchOptions_1_0_19143025_2
USBToPCPopUp_2_2_19143124_0
USBtoPC_1_24_0_5
USSD_Service_4_34_0_1
VideoTelephony_2_5_34646_0
VoiceRecorder_1_10_19141328_0
VolumeControl_2_1_19153530_0
Wi-FiWizard_1_7_0_20
WiFiSettings_1_2_4_0
WLANSettings_2_6_0_0
WModem_2_52_0_0
YouTube_2_6_19171131_00
zlibce_m_1_2_3_0
Thông tin chi tiết :
* CE OS 5.2.23006 & Build 23007.5.3.0
* Nền tảng Rom v2.06.502.1
* Cập nhật 99,9% phần mềm htc phiên bản mới
* Use .NET Compact Framework 3.5
* Loại bỏ khu vực ULDR
Hình ảnh :
* Đặc biệt trong ROM có tích hợp ứng dụng TomAutoInstall.exe với chức năng tự cài đặt nhanh chóng các *.CAB, *.proxml, *.xml, *.tsk file từ thẻ nhớ, cách làm như sau:
- Tạo thư mục Autoinstall trên thẻ nhớ
- Copy các CAB, proxml, xml hoặc tsk cần cài đặt vào thư mục trên.
- HR lại máy, bạn sẽ thấy sau khi hoàn chỉnh, các CAB đã được cài đặt rồi.
Link tải Rom :
Tom Topaz v2.06 Manila 2.1 Build 23007 [Stable]
Tom Topaz v2.06 Manila 2.5 Build 23007 [Beta]
Tom Topaz v2.06 Manila 2.1 Build 21925 [Stable]
Tom Topaz v2.06 Manila 2.5 Build 21925 [Beta]
Chúc vui !!! :D
klcr24
Hjx ai chỉ cho em cách vào phần setting khi để giao diện Windows default với Em vào start ma chả có phần setting đâu cả ~~
Đã up thành công. Nhưng có 1 số lỗi nhỏ thế này, về phần sóng đt, GPS, Wifi cực tốt. Bluetooth chưa thử. Cảm ứng có vẻ không nhạy bằng ROM ship. Khi nhấn nút start menu thì có vẻ khựng khựng tí mới đưa giao diện Program lên, trong khi ROM ship thì ấn 1 cái là lên liền.
Tiện thể cho mình hỏi muốn add 1 file exe bất kì vào danh sách program fải làm thế nào?! Mới sài nên không biết làm thế nào nữa. Thx trước
GSBS
Cách 1:Bạn cài vào một chương trình quản lý file mạnh, cho phép tạo shortcut như là Resco File Explorer. di chuyển đến file chạy chuơng trình cần add(*.exe), nhấn giữ để mở contextmenu rồi chọn dòng send to->startmenu as shotcut là nó sẽ xuất hiện trong ô all programs thôi.:D
Cách 2:không cần CT. bạn gắn máy với PC, mở active sync->exlorer->My Windows Mobile-Based Device. Rồi mở thư mục có chứa file exe. bấm phải chuột vào file->create shortcut.Sẽ có file shortcut kế bên đó, đổi tên nó nếu thích. Ctrl+x(cut nó)->My Windows Mobile-Based Device->windows->startmenu->programs(->có thể tới luôn thư mục cụ thể nào mà bạn muốn) rồi past nó vào thôi.:D
:-/ Lưu ý là với cách 2 thì bạn phải vào My computer trc, chọn folder option cho phép thấy các folders ẩn thì mới thấy được cái folder Windows trên device ;)
Hungpdahl
Muốn lấy lại giao diên 3D thì lám thế nào nhỉ,mình tìm mãi không biết vào đâu cả?
xboy999
Mình cài bản rom Tom Topaz v2.06 Manila 2.5 Build 23007 [Beta] về, xài khá mượt, chỉ là thấy có 1 số lỗi:
1. Không chỉnh đc contact hay favorites của máy
2.Dùng Menu Extended báo lỗi: "An unexpected error has occurred in Tom_Menu_Extended.exe.
Select Quit and then restart this program or select Details for more information."
3. Mỗi lần unlock máy thì lại hiện bảng ContactUtilityEngine
4. Khi bấm X để tắt soft thì điểm ság bị lệch
5. Khi bấm phím <- thì không back lại trang trước đó mà bị đưa về màn hình TF 3D
6. Tắt soft trong task manager bị đơ 1 chút mới tắt
