Thangnd31082
Topic này để anh em tổng hợp các bản cập nhật đối với phần mềm Sorcerer nhé. Các bản mới nhất sẽ đựoc cập nhật ở phần P/S cuối bài viết này
Mở màn này
Sorcerer v1.60 S60v3 SymbianOS 9.x Unsigned
Phần mềm hack tiền, điểm, máu , mạng,... trong game offline
Sorcerer is a game cheating tool that can modify game data in memory easily. With Sorcerer, you can search for any value in your game and change or lock it to the value you want to. You can change the number of lives and amount of money you have with this tool. By searching for unique values in your favorite game, you can locate and change game features.
Java games: Theory, all the java games can be changed!
Online Games: Online Game theory can be modified, but because it is network gaming, the data directly from the game server control, so refresh the data, if they become back to the original. Here to teach you a way to use when playing the big strange change immediately under the power of your attacks, and then use the software inside the lock function to modify data locked, so that you can use in a game of high attack power, but you are offline and then on-line, the data will be restored.
SIS Games: All sisx game theory can be modified (still not found the time being can not be changed sisx games).
Simulator games: Some simulators can modify the game we've tested, but we recommend the use of the hand of God to modify, after all, this software only modify the game to memory, not support amending the archive.
Ngage2 Games: Ngage2 game theory, support all the changes (test can be modified).
S60 Software: In theory, yes you can modify some software, such as mobile QQ, to use this software can be compulsory and others, chat, specific methods will not elaborate here, but you can certainly tell you that site is feasible.
What's new:
● Additional search abilities of 64-bit data, search for more large values
● Ability to setup the upper limit for data search
● Changed hotkeys: * button and # button into volume up or down keys
● Reading list, no more set to "Storage" state
P/S: Bản mới hơn: Bản 1.62 cập nhật 30/10 tại đây
Mở màn này
What's new:
Hướng dẫn hack game tại bài này nhéCập nhật mới các nội dung sau :
● Tăng khả năng tìm kiếm của dữ liệu 64-bit, tìm thêm những giá trị lớn
● Có khả năng thiết lập giới hạn trên cho dữ liệu tìm kiếm
● Thay đổi phím nóng: nút * và # nút bởi phím tăng-giảm âm lượng
●Sửa lỗi đang đọc danh sách, không cho dùng thiết bị "lưu trữ"
