PhongQuang
Total Commander for Android v1.0 RC6 (Việt hóa: Phong Quang)
Phần mềm quản lý file nhiều tính năng cho Android.
Main features:
Copy, Move whole subdirs
Inplace rename, create dirs
Delete (no recycle bin)
Zip and unzip, unrar
Properties dialog, change attributes
Built-in text editor
Search function (also for text)
Select/unselect groups of files
Select by tapping on file icons
List of installed Apps (built-in plugin)
FTP client (plugin)
WebDAV (Web folders) (plugin)
LAN access (plugin)
Root support for the main functions
Send files via Bluetooth (OBEX)
Thumbnails for pictures
Two panels side by side, or virtual two panel mode
Bookmarks as in Total Commander
Directory history through dropdown list
Configurable button bar for changing directories, internal commands, launching apps, and sending shell commands
Simple help function in English, German, Russian, Ukrainian and Czech
Supported languages of the main program: English, German, Czech, Danish, Dutch, French, Greek, Hungarian, Italian, Korean, Polish, Russian, Simplified Chinese, Slovak, Slovenian, Spanish, Swedish, Traditional Chinese and Ukrainian
What's new:
Background operations: Show icon/progress bar in notification bar
Support for devices with MIPS processors
Improved root functions
Various bugfixes (mainly for crashes)
New language: Vietnamese
![37ce82ad407fcf06518527fed0d85ecc_43790087.sc20120422233916.png](http://nl7.upanh.com/b6.s13.d5/37ce82ad407fcf06518527fed0d85ecc_43790087.sc20120422233916.png)
![d0bb0ac52129d3345244ca274227be64_43790146.sc20120422233900.png](http://nl6.upanh.com/b2.s26.d2/d0bb0ac52129d3345244ca274227be64_43790146.sc20120422233900.png)
