Trợ giúp Jailbreak iPhone 2G 3G & 3GS FW 3.1.3 với ToolJail v1.3
dr_mosse
ONLY JailBreak Guidelines/Tutorial iPhone 2G 3G & 3GS FW 3.1.3-ToolJail v1.3
Hi Every One i know we been through this before with Too1Jail v1.0, 1.1, 1.2 and now v1.3
so let's see what's new with this English & Italian update.
There has ever been confused about the state of Jailbreak? Want to know for sure whether you can unlock your iPhone or iPod Touch? New iBoot, models MC, the ECID and Firmware 3.1.3 are balking? Destroyer95 has implemented a program for Windows called ToolJail which will remove all your doubts and now we have a new update, coming version 1.3.
The fact is Extremely simple operation, suitable for both experienced users and beginners.
All you need to do is click on “Guides Jailbreak” A screen similar to this:
Fill out the various voices of the pull-down menu showing:
The type of device
The firmware version installed on your iPhone / iPod
Version dell'iBoot (only for iPhone 3GS)
If you have saved or not the ECID through Cydia (only for iPhone 3GS)
The computer operating system you intend to use
The model of iPod Touch 2G
Once you have filled in all fields, you just click “Search” sentence and will appear in Green “You can do the Jailbreak” or Red “You can not do the Jailbreak”.
If so, you then click on “Start Guide” and immediately open a window with a step by step, specific to your situation, allowing you to run the Jailbreak without errors.
The program also, complements other sections from where you will find instructions to put the phone in DFU or Recovery Mode, the guide to downgrade and also all the links for downloading various versions of firmware for iPhone and iPod Touch!
We did proceed to examine all the changes in Version 1.3:
1- Changes in the code to speed the application
2- Added the requirement to re-click the Search button each time you change the data within the form. This keeps people from reading a tutorial Wrong.
3- Added guides for the tethered jailbreak 3.1.2
4- Added references and guides about all'unlock, the baseband and blacksn0w for iPhone 3GS
5- Replace references and links to Sn0wbreeze 1.5.1 with those in Sn0wbreeze 1.5.2
Download:
ToolJail is unique to iSpazio and you can download it in Italian or English by following these links:
ToolJail v1.3 Italian
ToolJail v1.3 in English
NOTE:
If you get weird errors at startup and you can not use, Simply Download DotNET Framework 3.5.
Source: iSpazio - News iPhone Italian, iPhone 3GS, iPod Touch, iPad Italy and App Store reviews.
doananhtai
Một lần nữa xin XÁC NHẬN lại cho tất cả mọi người được rõ cái TOOLJAIL này không phải là tool dùng để Jailbreak mà nó chỉ là tool hướng dẫn VÀ CHỈ HƯỚNG DÃN mà thôi...
- Cái nào jailbreak được thì nó báo cho biết là jailbreak được và hướng dẫn cách jailbreak .
Hướng dẫn thôi chứ không có làm dùm nhen và thòng thêm câu "không chịu trách nhiệm nếu máy bạn bị hư nếu làm theo hướng dẫn của nó".
- Cái nào không jailbreak được thì nó báo là không jailbreak được .
TÓM LẠI : Cái nào tool này biết thì mọi người đã biết.. ... không có cái mới nào ngoài cái mọi người đã biết.
Bổ sung:
Cái hay của tool này là đối với người mới toanh chưa biết gì..và muốn Jailbreak cho máy của mình, thay vì hỏi trên diễn đàn và chờ câu trả lời.. Thì có thể dùng tool này hỏi và có ngay câu trả lời nhanh nhất và cả các đường link để download các tool cần thiết.....và làm theo hướng dẫn.
Zenki
@dr_mosse: THIS IS NOT A JAILBREAK TOOL.
Be clear when you post a new Topic next time!
MỌI NGƯỜI CHÚ Ý, ĐÂY KHÔNG PHẢI LÀ TOOL JAILBREAK ĐÂU NHÉ. XEM LẠI BÀI VIẾT CỦA doananhtai trước khi sử dụng!
dr_mosse
I Did Not Say JailBreak TOOL
@Zenki: I DID NOT Say this is a Jailbreak Tool, I SAID This is ONLY JailBreak Guidelines / Tutorials
and i believe doananhtai have explained that too in Vietnamese Lang. In His Post.
@doananhtai: Thank You For Your Help & explaining the Benefit of ToolJail =D>
Zenki
You DID but most of the people here don't understand English very well so I would appreciate if you can translate via Google that part!
Thanks!
dr_mosse
@Zenki: Đây là Chỉ JailBreak Hướng dẫn / Hướng dẫn
Is This Right Translation????
Germaniteen
Yes thats right it just shows that ur iPhone jailbreakable or not. Just info not a jailbreak tool.
