Kojiro
Thấy bản này trên mạng, bung file sis ra rất quen thuộc, dịch bằng google thì ra như bên dưới. Do chưa chắc bản chính thức nên chưa dịch ra Việt, anh em thông cảm nhé.
Do đang ko có máy nên anh em nào test xem sao nhé
Ảnh của andycuong
Ảnh của andycuong
1. Increase the environmental sound effects (soft decoding does not support the environmental sound)
2. Increase the power-saving mode
3. To increase night-time mode (to be optimized)
4. To solve the soft decoding is playing songs not Bluetooth to send the issue
5. To amend SMS or calls can not be continued after the issue of broadcast
6. Modify the # key or the T-shaped key can not copy \ paste related issues such as
7. Fix the problem replace the skin exit
8. Fix will find shortcuts songs set to a long press, unable to respond to the problem
9. Change the first time every day, by default do not scan the system folder and not less than 60 seconds scanning of documents
10. A menu, press the left arrow keys to support the menu disappears
11. The navigation control panel settings changed, and no shortcuts in a similar way, or dial
12. Change the attribute editor, style, rolling up and down the list problem
13. Change the horizontal center-screen dialog box
14. See attributes songs stuck to optimize read method
