Caominh171
TTPod v3.70 Beta S60v3 EN Translated by SymPVietGroup
[Cập nhật]
[Cập nhật]
Trình nghe nhạc nổi tiếng!!
Bản này mình đã cho thêm vài skin của riêng v3.70 khá đẹp!!
Demo:
Trích dẫn từ TM Thangnd31082: (Tks anh Thắng)
Mới vọc được bên IPMart, xin trích dẫn nguyên văn biên dịch bằng tiếng Anh của tác giả . Anh em nào rảnh dịch sát nghĩa giùm !Mình rất ghét dùng Google dịch láo sau đó pót lên --> mất sự trong sáng của Tiếng Việt
New version features {New and Improved}:
1. Decoded based on a new system architecture to improve performance and results, reduce the CPU occupancy and power consumption;
2. Increase environmental sound adjustment function;
3. Increase the left and right channel balance adjustment function;
4. Optimize most of the pop-up box interface display;
5. The new image processing engine, better display;
6. Increase the image rotation display;
7. To increase picture lantern display;
8. Increase the image rotating display;
9. Add "1" key shortcut menu;
10. Optimal adjustment of left menu layout;
11. Increase the power-saving mode;
12. Increase in night mode;
13. Increase by album name, by adding time to sort random ranking;
14. Increase the tag and mobile functionality;
15. Increase the smooth fast forward / rewind mode;
16. Increase the font Stroke effect;
17. Increase the font shadow effects;
18. Increase the font size and color of the lyrics interface regulatory function;
19. Increase the image storage directory customization;
20. To increase the transparency of regulatory function mini player;
21. Support "start play" and "Memory out of position" set separately;
22. Support the left-menu press the left arrow keys to turn off;
23. Optimize the speed list, scroll and flip;
24. Custom list add "Favorites" list by default;
25. Bluetooth to send support for sending multiple files at the same time;
26. ID3 editor cache optimization methods to improve save rates;
27. Increase the power, the progress bar handle and follow the syntax of animation, and more skin.
Fixes:
1. FP2 models to solve the problem of sleep shutdown mode is invalid;
2. Repair some models use JbakTaskMan forcibly closed by the program in the phone reboot problems;
3. Repair 3250/5500 and other models for music when the phone reboot problems;
4. Fix built-in image in the switch if they had not displayed when the screen or skin problems;
5. Repair part of the model image display area width ranging from pictures shown due to gaps;
6. Fix MPEG-4 AAC Audio Coding format, the problem can not play audio;
7. Fix more other details, not repeat them.
Notes:
* N82, N95, N73 sound problems due to environmental hazards, have been shielded environment sound;
* Samsung models sound API call is invalid, has been shielded sound and equalizer options;
* N82, N95 backlight control to open the screen flashes when the cause has been screened the night mode.
Lưu ý:
- Nếu gặp lỗi "System Error" thì các bạn cài thêm >>> Path4run <<< (dành cho máy hack & chưa hack phone) !!
- Nếu gặp "Lỗi cập nhật" thì các bạn gở hết các phiên bản cũ của TTPod ( vào Application manager gở bỏ những gì liên quan đến TTPod)
***Khuyên dùng >>> PyUninstaller <<< để gở sạch sẽ các bản TTPod cũ, xong cài bản này vào là OK liền!!
Download:
Multi Links
4Shared
=============o0*0o=============
Bản fix chức năng Enable/Disable (cho những ai dùng hok wen)
[URL]http://www.mirrorcreator.com/files/1HIWBMFT/TTPod_v3.70Beta_S60v3_EN_Translated_by_Caominh171_SymPViet.rar_links[/URL]
[URL="http://www.4shared.com/file/w5PpYr4y/TTPod_v370Beta_S60v3_EN_Transl.html"]http://www.4shared.com/file/w5PpYr4y/TTPod_v370Beta_S60v3_EN_Transl.html[/URL]
[URL="http://www.mirrorcreator.com/files/1T3NGASK/TTPod_v3.70Beta_S60v3_EN_Translated_by_Caominh171_SymPViet_0.rar_links"]http://www.mirrorcreator.com/files/1T3NGASK/TTPod_v3.70Beta_S60v3_EN_Translated_by_Caominh171_SymPViet_0.rar_links[/URL]
