TTPod v3.70 Final S60v3 EN Translated by SymPVietGroup!! [Cập nhật 28.04]
Caominh171
[Cập nhật]
Trình nghe nhạc nổi tiếng!!
Trích dẫn từ TM Thangnd31082: (Tks anh Thắng)
Every day is a pleasant to the ears are not required to register, completely free cell phone music player software, set playback, equalizer, lyrics, sleep mode, alarm clock and many other functions, operation simple and powerful. Every day, appealing to the user's need for the development direction and strive to become the user in mind the best player, becoming the most popular cell phone music player software.
Change Log:
New and Improved:
1. Decoded based on a new system architecture to improve performance and results, reduce the CPU occupancy and power consumption;
2. Increase environmental sound adjustment function;
3. Increase the left and right channel balance adjustment function;
4. Optimizing the majority of pop-up box interface display;
5. The new image processing engine, better display;
6. Increase the image rotation display;
7. To increase picture lantern display;
8. Increase the image rotating display;
9. Add "1" key shortcut menu;
10. Optimal adjustment of left menu layout;
11. Increase the power-saving mode;
12. Increase in night mode;
13. Increase by album name, by adding time to sort random ranking;
14. Increase the tag and mobile functionality;
15. Increase the smooth fast forward / rewind mode;
16. Increase the font Stroke effect;
17. Increase the font shadow effects;
18. Increase the font size and color of the lyrics interface regulatory function;
19. Increase the image storage directory customization;
20. To increase the transparency of regulatory function mini player;
21. Support "start play" and "Memory out of position" set separately;
22. Support the left-menu press the left arrow keys to turn off;
23. Optimizing the speed list, scroll and flip;
24. Custom list add "Favorites" list by default;
25. Bluetooth to send support for sending multiple files at the same time;
26. ID3 editor cache optimization methods to improve save rates;
27. Increase the power, the progress bar handle and follow the syntax of animation, and more skin.
Fixes:
1. FP2 models to solve the problem sleep shutdown mode is invalid;
2. Repair some models use JbakTaskMan forcibly closed by the procedure leading to the problem restart the phone;
3. Repair 3250/5500 and other models for music when the phone reboot problems;
4. Fix built-in picture screen in the switch anyway, or skin problems do not appear;
5. Repair part of the model image display area width ranging from pictures shown due to gaps;
6. Fix MPEG-4 AAC Audio Coding format, the problem can not play audio;
Notes:
* N82, N95, N73 sound problems due to environmental hazards, have been shielded environment sound;
* Samsung models sound API call is invalid, has been shielded sound and equalizer options;
* N82, N95 backlight control to open the screen flashes when the cause has been screened the night mode.
Thanks GENERY and his screenshots..
Lưu ý:
- Nếu gặp lỗi "System Error" thì các bạn cài thêm >>> Path4run <<< (dành cho máy hack & chưa hack phone) !!
- Nếu gặp "Lỗi cập nhật" thì các bạn gở hết các phiên bản cũ của TTPod ( vào Application manager gở bỏ những gì liên quan đến TTPod)
***Khuyên dùng >>> PyUninstaller <<< để gở sạch sẽ các bản TTPod cũ, xong cài bản này vào là OK liền!!
Download:
hanhoai
Đề nghị Mod Caominh nên Edit lại cái tiêu đề bài này,vì đây là bản Final chính thức đã có trên trang chủ www.ttpod.com rùi.chứ ko phải là bản Beta nữa.
Thanks trước !
speedhack
đã cài patch for run nhg vẫn báo system error
ko hiểu sao cài py uninstaller xong vào chạy toàn báo lỗi "fatal error". Mình dùng N82 fw 35, máy đã hack. bro nào biết chỉ dùm với.
nhanngoquyen
đã test trên Nokia E63 FW 4 mới nhất , kết quả OK ,scan nhạc có vẻ nhanh hơn beta ,ủng hộ bác chủ thớt !!!
pekuon
Đúng rùi, đây là bản Final mà, nên edit lại cho anh em vào down về dùng thui.
w2k
đợi mãi. cuối cùng thì e nó cũng ra lò.hình như bản này CM vẫn để tích hợp cả cho loại màn hình nhỏ à.
pekuon
Bản này ít giao diện quá. Ai có link down giao diện share cho anh em với.
Caominh171
Mình đã bỏ rồi đó, cả skin nữa cho nhẹ bớt t aịcó 1 số giao diện hok đẹp lắm. Mà làm j mà bạn kỵ việc này thế :-?
tuanloc1
py uninstaller báo lỗi "fatal error" là do bạn chưa bật open4all trong Rompatcher đó. Bật lên là Xong thôi.
w2k
à ko có j đầu M. ý mình chỉ là làm nhẹ để bản cài đặt đỡ tốn ram thôi.còn skin thì đã có 1 tupic riêng rùi. nên ai cần thì có thể qua tupic đó load về rùi copy vào file cài đặt. có phải skin nào M add vào ai cũng thích đâu.:p\-/;;)
vunhudunghd
Anh Cho thêm mấy cái giao diện đẹp (skin) đi, chứ thấy nó ít SKIN quá àh
Đừng dùng cỡ chữ >3 nữa nha bạn!!!
traicauhd
có ai bị như mình không quét ổ c thì bị văng ra ngoài còn quét ổ e thì không làm sao
mình dùng e 63
w2k
TTPod v3.70 Final ENG - ADs Free + New Splash + New Skin​
thêm sự lựa chọn cho các bạn \-/
momvip9
hjx, làm sao mà bản này chán thế nhỉ,máy mình cài bản này nghe tự nhiên cứ có tiếng sôi, âm thanh chả trong tẹo nào, tưởng máy hỏng, nghe thử bằng phần mềm mặc định thì không sao, có khi còn hay hơn TTpod này, hjx
ninhhot
K dùng dc bản này thì quay lại dùng mấy bản cũ thôi b ơi.m cài dc 2 ngày giờ phải gỡ ra cài bản 3.63 thôi.bản này m dùng thấy chậm chậm thế nào ấy và lại hôm qua tới giờ đứng máy liên tục.dùng tai phone nẽt nhanh 1 tý là khởi động lại máy nản qúa
