Ứng dụng văn phòng - QuickOffice v6.1.88 (cập nhật trang 22)
dung1291985
QuickOffice.Premier.Upgrade.v5.0.32.S60v3.SymbianOS9.1.Unsigned
Quickoffice Premier 5.0 is the FIRST and ONLY mobile solution to support Microsoft Office 2007® on S60 3rd Edition devices. Enjoy all of the great features of Quickoffice Premier 4.5 + the ability to edit and create new Microsoft Office 2007 documents on your device. Unlock the full potential of your smartphone and turn your device into a powerful mobile office. Quickoffice preserves documents during editing preventing document corruption and loss of formatting.
Version 5.0 Updates
  • Microsoft Office 2007 support (Word & Excel)
  • Printer support (Nokia E Series devices)
  • Tighter integration with Adobe Reader LE
  • Easy to create new Office docs while on main screen
  • Marquee scrolling of long file names
  • More short cut keys for increased productivity
  • Easier to adjust fonts, fewer steps
Key Benefits
  • Increase Your Productivity
  • Easy to Navigate Desktop Look & Feel
  • Retain File Formatting with No Data Loss
  • Easy and intuitive to use
  • Read text easier than ever
Key Features
  • Complete Editing of Word®, Excel® and PowerPoint® files
  • Advanced Editing of text, lists, tables, style, and formatting
  • View documents in multiple views
  • Performance optimizations for handling documents
  • ZoomView™ lets you pick the display size that’s best for you
  • Support For complex formulas
  • Complete graphical editing
  • Advanced email integration with Mail for Exchange 2.0
  • Free spell check dictionaries available in multiple languages
  • Add images to Word and PowerPoint documents
Quickoffice Premier 5.0 Compatibility
  • Supports the following file formats; DOCX, DOC, XLSX, XLSM, XLS, PPT, PPS & TXT
  • Microsoft Office version support; 97, 2000, XP, 2003, & 2007
  • Compatible with all S60 3rd Edition Devices
* Microsoft Office 2007 hỗ trợ (Word & Excel)
* Máy in hỗ trợ (Nokia E Series thiết bị)
* Tighter tích hợp với Adobe Reader LE
* Dễ dàng để tạo mới Văn phòng docs trong khi trên màn hình chính
* Marquee di chuyển dài của tên tập tin
* Các phím tắt cho gia tăng sản xuất
* Dễ hơn để điều chỉnh phông chữ, ít hơn bước
Lợi ích KKK
* Tăng cường sản xuất của bạn
* Dễ dàng Điều hướng Desktop Look & Feel
* Giữ lại tập tin với định dạng không mất dữ liệu
* Dễ dàng sử dụng và trực quan
* Đọc văn bản dễ dàng hơn bao giờ hết
KKK Tính năng
* Sửa đổi hoàn của ® Word, Excel ® và PowerPoint ® file
* Nâng cao Hiệu chỉnh văn bản, danh sách, bảng, phong cách, và định dạng
* Xem tài liệu trong nhiều lần xem
* Hiệu suất tối ưu hóa cho xử lý tài liệu
* ZoomView ™ cho phép bạn chọn hiển thị kích thước phù hợp nhất cho bạn
* Hỗ trợ Đối với công thức phức tạp
* Hoàn chỉnh sửa đồ họa
* Nâng cao tích hợp với thư điện tử cho Thư 2,0 Tỉ giá ngoại tệ
* Spell kiểm tra miễn phí từ điển có sẵn trong nhiều ngôn ngữ
* Thêm hình ảnh vào văn bản Word và PowerPoint
Quickoffice Premier 5,0 Khả năng tương thích
* Hỗ trợ các định dạng tệp tin; DOCX, DOC, XLSX, XLSM, XLS, PPT, pps & TXT
* Microsoft Office hỗ trợ phiên bản; 97, 2000, XP, 2003, & 2007
* Tương thích với tất cả các thiết bị S60 3rd Edition
Trả lời kèm theo trích dẫn này
Finally!!No hacking,No complicated tutorials,No Licence Manager
Just sign and install
http://rapidshare.com/files/162237330/QuickOffice.Premier.Upgrade.v5.0.32.S60v3.SymbianOS9.1.Unsigned.Crcked-illusion.rar
http://www.mediafire.com/?mummyzzgzml
Zenki
Nếu update thêm thông tin bằng tiếng Việt thì hay quá :( Nhắc nhở nhiều rồi mà :(
Kojiro
Bổ sung nhanh nội dung TV nhé! Thấy nhắc cũng nhiều rồi, mình xác định không tính số lượng mà tính chất lượng là tốt cho PV ta. PV khác tí nha bạn!
miu170687
Giúp bác chủ thớt cái ,sẵn spam bài lun :D
Tin cập nhật phiên bản 5.0
Lợi ích KKK
KKK Tính năng
kennho
Ối trời ! bạn dịch cái đó cũng như không , rốt cuộc bản này là bản full ? và cài như thế nào khi đang có bản mặc định trong máy ??????
Kojiro
Cứ nhấp file cài bình thường, không quan tâm có sẵn hay chưa, đã test trên N95-1, tốt!
dung1291985
Cảm ơn bạn miu170687, tại vì phiên bản này illusion mới cho ra lò đêm qua, lấy vội post lên đây để sáng cho các bạn sài lun, bùn ngủ quá rùi, chỉ bít post cái rùi đi ngủ lun, mong bạn thông cảm, ko phải là số lượng vì phần mềm này rất hữu ích và cần thiết mà,
Nhưng máy có sẵn QuickOffice.v3.8 thì cứ cài, cài xong nó sẽ tự đè và update lên bản mới ! Have fun!
dig31vn
Hơ hơ.... N73ME của em up lên là ko vào được quickoffice nữa >_<, bị bệnh j thế nhỉ các bác?
rinhvh
Máy của mình cài vào chay được tí là nó báo không thể cài đặt!không hỉu bị ji nữa!có ai cùng bệnh không nhỉ???:(
thanhlonely
Có phiên bản nào ko phải sign nữa thì yêu lắm (cái này sign online không được). Máy mình V30 đang ngồi khóc đây
JustinNguyen79
Mình thấy có bản QuickOffice 6.0 rồi đó. Ko biết nó như thế nào nhỉ, có anh em nào thử chưa, cho y kiến với. Thanks!!!
smackdun
Mình đã cài quickofiice 5.0, vào New Document thì đứng yên luôn, kô biết bị jì. Bạn nào biết giúp với, Mình xài N95 8GB.
phngoctuan
Mình cài vào máy N95 8g, máy báo: ''lỗi cập nhật" không biết có cần đổi lại ngày tháng không. Mong bạn giúp giùm. mình rất thích pm này
MinhThang
Nếu Sign thì không cần đổi, còn nếu hack thì bạn cứ thử vì cứ miễn sao cài được là làm.(Vì đây là pm cho 9.1 còn N95 là 9.2)
