UPROM BLACKSTONE (TOUCH HD)
OliNex đã hướng dẫn Uprom Blackstone, hãy xem tham khảo tại đây:
http://forum.xda-developers.com/showthread.php?t=431217
UPDATE: Hard-SPL released!
many thanks to testers for testing!
Preparations:
0) this package is for Blackstone devices. for BLAC100 so far (SSPL loader checks this), if your ModelID is different, contact us for testing!!
1) make sure you have .NET framework installed on your PC! if not, get it from http://www.microsoft.com/downloads/d...DisplayLang=en
2) if you have vista, WMDC update is recommended: http://www.microsoft.com/windowsmobi...ce-center.mspx
Instructions:
1) download Hard-SPL package from attachment, extract to an empty folder.
2) you must Have Phone Synced with PC in Windows Mobile!!!
3) run HardSPLWrapper_Blackstone.exe on PC, make sure it's launched from a local drive (not through network drive, etc.). if you are on vista, launching as Administrator is recommended,
4) follow steps in the RUU, check device for prompts after PC shows loading bar, press Yes on phone if asked.
5) some notes: when RUU says it will hard reset, do not worry, it is not going to do that. also when it says the flash will take 10 minutes, ignore that, it will only take a minute or so.
6) device should go to a tricolour screen now that says 1.07.OliNex, the SSPL version, which is temporary.
7) in a bit unusual way, it will take a few seconds for the RUU to detect the device, but do not worry, as soon as the "USB" text on the tricolour screen shows up, RUU will see device.
8) SPL flashes, device automatically reboots, job done.
9) to confirm you got it installed, go into bootloader mode (tricolour screen!) and verify the screen shows 1.14.OliNex, which is the Hard-SPL version.
NOTE: you will not see the SPL version during normal boot, that is the OS version, not SPL!
to enter SPL to check version, fully power the device off by long press of power key, then power on while holding the "volume down" key on the left side of the device. keep holding the volume down key until you see tricolour screen which is the bootloader mode, then release it.
NOTE 2: anyone having problems with the device entering SSPL automatically, please copy SSPL-Manual-TouchHD.exe from SSPL-Manual-TouchHD.zip attachment to the device and run it. then once the screen is sayingn 1.07.OliNex, run RUU manually. i.e. you launch the Hard-SPL RUU (HardSPLWrapper_Blackstone.exe) on the PC and flash.
NOTE 3: this is unsigned Hard-SPL. no limitations on flashing ROMs or radio packages. also, this has overwrite protection against HTC RUU's overwriting HSPL with a stock one, so if someone needs to revert to stock SPL for warranty reasons, a stock SPL downgrade package is posted in this post as well. use this relocker *only* if you need to return the phone for warranty, and only use it as last step - after reflashing stock OS and radio.
NOTE 4: do not use this RUU for anything other than SPL flashing (i.e. hardspl or stock spl restore)!!! nothing other than SPL's made by Olinex team (using OliNex custom cert) will flash to make SSPL more secure. if you want to flash some other rom, then use shipped RUU or blackstone customRUU if you need to flash cooked ROM.
NOTE 5: for developers asking: Hard-SPL is not based on MFG SPL, as that SPL causes the screen not to turn on after a resume. (maybe solved one day ). so currently, MFG SPL can strictly be used for development and hacking.
Troubleshooting:
- read the instructions above.
- anyone having problems with the device entering SSPL automatically, please copy SSPL-Manual-TouchHD.exe from SSPL-Manual-TouchHD.zip attachment to the device and run it. then once the screen is showing 1.07.OliNex, run RUU manually. i.e. you launch the Hard-SPL RUU (HardSPLWrapper_Blackstone.exe) on the PC and flash.
- if you get connection error in RUU after the device goes to 1.07.Olinex screen, then try a different USB port, also do not use USB hub, you can also try rebooting your PC, and can try using another PC. also you can try unticking advanced network functionality in start menu / settings / connections / usbtopc applet.
- if SSPL-Manual.exe or Enterbootloader.exe fails to run (says missing component or similar), try a hard reset of the device.
- USB or connection error: as already said, in a bit unusual way, it will take a few seconds for the RUU to detect the device, but do not worry, as soon as the "USB" text on the tricolour screen shows up, RUU will see device. if not (happens very rarely), wait for RUU to time out (or wait 5 minutes). then remove back cover, reset, it will boot OS again, then you can retry unlocking process from step 1.
- USB or connection error: alternatively, launch SSPL-Manual.exe from attachment, run it, wait until 1.07.OliNex tricolour screen says "USB" on it, then run the HardSPLWrapper_Blackstone.exe on the PC.
Attached Files Unsigned_HardSPL_for_Blackstone_OliNex.zip (1.12 MB, 0 views)
Copy nguyên từ WiKi về, không có hướng dẫn TV không nên !!!
Preparations:
Instructions:
Troubleshooting:
