anhthai
Pm này thì quá quen thuộc rồi không cấn phải dài dòng.
LINK FULL
S2P Change Log: v1.00
"Album View" is officially discarded (both Portrait & Landscape).
single installation file, no more separate file for QVGA & VGA.
added support to Landscape mode.
added option to save On-The-Go playlist as another file at the Library folder.
added "Genres" list.
S2P treats each sub-folder as an album. In turn, all songs under a sub-folder will be regarded as having a same genre. S2P will only scan the first song to determine what genre that folder belongs.
added search function under all lists.
A search box is at the top of each list. If you are in the middle of a list, tap the top system status bar.
added more information on the "Songs" list.
added option to sleep S2P without S2U2 (Settings > General).
added support to show lyrics.
Lyrics can be stored in an additional file with the same file name as the song but with extension .LRC or .TXT. It can also be embedded as USLT ID3 tag within a song. On the play music screen, tap the song title/artist/album area to toggle the display of lyrics if it exists. * Synced Lyrics is not supported yet.
added option to align the lyrics (Setting > Appearance).
improved ID3 tags parsing compatibility.
added support to show ID3 tags info of WMA music file.
removed option "Load fast pic" as now S2P always load pic with fast code.
added option to save the current song info as WMP registry key values (title/artist/album/duration/elapsed) (Settings > Advanced).
added a Black theme & it's installed as default; for other themes, they will be available at my website later.
removed option "Display Mode".
a lot minor bugs fixed.
LINK FULL
