[Updated - v5.1 Blue] Uni WM6 Pro - 5.2.1933 (Build 18533.0.7.0)
nhatdang
Đã có bản rom mới, mình test thấy ổn định hơn bản cũ
Changes of v5.1:
-- WKTask updated
-- PIM Backup updated
-- SD/SDHC driver issue fixed
-- Added ArcSoft MMS Composer
-- Pagepool changed to 5.2 MB
-- Stability improved
-- Few other bug fix / tweaks
Complete Info:
-- WkTask 1.1.7.3 (by waku) Task manager
-- WM5torage 1.78 (USB HDD Emulation)
-- Total Commander 2.5
-- PocketRAR 3.71 (with .zip/.rar association)
-- Adobe Reader LE 2.0 (optimized)
-- ArcSoft MMS Composer
-- OxiosHibernate 1.3 (no popup) and Performance/overclocking applet
-- TodayAgenda 1.0 today plugin
-- Flash plugin 7.0
-- TCPMP 0.72RC1 media player
-- DF's PIM Backup 2.7 (for contact, sms backup etc.) and Task Manager 2.7
-- SynchroTime (by Grachov) for Internet time sync
-- HTC Network plugin
-- Voice notification & ringtones
-- New 9-button ComManager (Blue)
-- SD/SDHC support (settings applet from JW)
-- CompactFramework 2.0 SP1
-- STK srvice, SIM Mamager and all common applications
-- SMS delivery fix (by Saman)
-- SD block transfer size set to 256k (for HQ video playback)
-- Default GSM mode set to "GSM" (to save battery) [it can be changed from phone setting]
-- Set default search to Google (desktop) search
-- PIE cache (temp, cockies & history) relocated to the root (\IE Cache) for easy cleaning
-- PIE cache limit set to unlimited and tweaked to get best performance
-- Improved device wake-up from sleep (before alarms)
-- Registry-type set to file-based; it will help not to forget the settings made by the user
-- Set default dev-id and BT name to "Universal"
-- Disabled incoming beams (to save battery)
-- Disabled today plugin - Date, Appointments & Tasks (replaced with TodayAgenda)
-- Today item set to hidden of "Messaging", "Wireless" and "Keylock" (Unhide from Today settings, if needed)
-- Exe's & Dll's transformed into module (wherever possile)
-- Unlock/Unhiding tool for extROM
-- New Blue theme and boot splash
-- Should work on G3/G4 both devices [No Flash Disk]
Build v5.1 (18533.0.7.0):
http://vidmes.com/Uni/Kitchens/ranju/ROM/Ranju_v51_Blue_1933_18533.rar
happy new year
Tuan1412
Bản cũ rất kén soft và hay treo vặt,mình 0 thể cài đc VNkeyboar,bạn dùng rồi thử xem có cài đc 0 bạn nhé
DucLong
Bản này của ranju nhưng chỉ dừng lại ở 5.2.1933 theo mình so với các bản V 3.9 của Ivan, bản 2.15.00 của mamaich thì vẫn thua một bậc.
ltrhai
Theo tôi thì thông số về 5.2.1933 cũng chưa chắc đã quyết định về một bản Rom tốt chưa mà quan trọng là bản đó có ổn định hay không, các tính năng cần thiết có hoạt động tốt không, có tương thích với các Softs không, các bản trước đây của Ranju thường tương đối tốt, trừ bản V5, còn bản này không biết thế nào, chắc cũng phải thử phát xem thế nào mới được.
djtrungkien
có ai dùng thử chưa cho ý kiến về tốc độ,bộ nhớ cài đặt,ram,tương thích phần mềm và pin cho anh em biết với
ltrhai
Hi, tôi đã dùng thử ít giờ, từ sáng nay tới chiều có vài nhận xét vội:
- Sau khi được tác giả fix một số lỗi thì thấy sau khi up giao diện màu xanh tương đối bắt mắt, ram sau khi cài nhiều phần mềm ứng dụng thì vẫn tương đối cao 20 - 21m sau khi SR, tốc độ nhanh. Về các mặt đều ổn cả.
- Vấn đề không ổn của bản này là bị có vấn đề về phone bị GSM masage và máy tự SR sau 30 giây, có lẽ tác giả vẫn quên chưa fix lỗi này, nếu sửa được lỗi này thì đây cũng là một bản rom hay.
- Cuối giờ chiều phải up lại bản khác để tránh rủi ro.
HungUTD
bản này tương đối ổn định nhưng wifi thì hơi có vẫn đề thì phải. wifi tự động tắt khi đang kết nỗi
18S67705
Xem thông số và những phần mềm được tích hợp thì mình khá kết bản ROM này, chỉ có điều bản trước quả thực kén soft quá, mình cài SU2 cứ khởi động lại là treo luôn. Bác nào đã up thì xem kỹ hộ anh em xem tính tương thích với phần mềm của bản này thế nào nhé (thông cảm vì mình chưa có điều kiện để up ROM).
