Lesangmd
Việt hóa Trinkesoftware NoCalls! 1.0
Chặn cuộc gọi hiệu quả trên PPc - Dung lượng tí hon
Việt hóa : Lê Sáng MD
Ngày 26-12-2008
Ngày 26-12-2008
![NoCalls.jpg](http://trinketsoftware.com/Images/NoCalls.jpg)
Overview
No Calls is a Windows Mobile® application that can automatically reject incoming calls depending on the caller. It silences your phone within the first ring. The caller will reach your voicemail, and you will still see their missed call in Call History. It's perfect when you're working, relaxing, sleeping or out on a date. With No Calls, you can avoid unwanted calls, yet keep your phone on for the people you care about.
Features
Features
- Lots of options to fine tune exactly who can reach you. Accept or reject calls based on contact, phone number or categories (screenshot 1, screenshot 2).
- Simple, touch-friendly user interface to organize and activate "profiles" that reflect your mood (screenshot 1, screenshot 2).
- Rejected callers go directly to your voicemail within a split second after your phone rings.
- All calls still show up in your Call History.
- Fast, small and optimized for Windows Mobile using native C++ code. Does its job and gets out of your way quickly.
Các bạn tải tệp việt hóa về cài đặt vào PPC . Đăng ký với số bất kỳ nếu sai sẽ có hướng dẫn cụ thể !
NHỚ CLICK THANKS ỦNG HỘ MÌNH NHÉ .
