WM 6.5 build 21501 Titanium Neo Shadow WWE
wapvirus
HTC EzInput Keyboard Suite 1.5 Language Packs Here: http://forum.xda-developers.com/showthread.php?t=426281
HTC Claculator Language Packs Here: http://forum.xda-developers.com/showthread.php?t=485349
HTC Comm Manager v2.7.5.0
Solitiare Graphics updated
Mobile Office 2007
Mobile Word
Mobile Excel
Mobile Power Point
WinRar 3.80
WM Storage 1.9 by Igor v Bozhko
PHM Reg Edit 7.0 by Philippe Majerus
Quick Menu 2.8 (Toggle WiFi)
Fexploreext 2.05
PimBack-up 2.8.0.0 by FdcSoft
Synchro Time 0.95 by Dennis Grachov
Netframework 3.5
Task Manager 3.1 by FdcSoft
MoDaCo NoData 2.0
Password Safe 1.0 by Thomas Gerber
UPX4ppc (compress your installed exe files and save space on your device)
HTC Boot Launcher (Now HTC EzInput Keyboard default SIP even after reset)
SyncManager 0.3 (Take control of your ActiveSync) (set to allow USB charging without syncing and wifi while on USB)
(easy to change the settings to what you want just edit the settings.txt file in program files\w@p\SyncManager )
CHome Editor v1.6 by showaco
ATContacts v0.98 by greatbal
Make sure you read this first or your Titanium Neo Shadow wont look like the screenshots
1/Goto settings\Today\Appearance Select PureBlack2 theme and press ok
2/Goto Start\Utilities folder and run ChomeEditor (remove the plugins not wanted)Enable At contacts plug in save then exit
Thanks again to Lamson for the SYS and XIP
Thanks to greatbal For his Titanium Shadow Neo Skin
Thanks to blazingwolf For help packaging Neo
For those who use Titanium Weather this version is made to go with Neo
http://forum.xda-developers.com/atta...5&d=1244737608
My recommendations for this ROM here
http://forum.xda-developers.com/showthread.php?t=512121
Around 21mb free Ram with Titanium G4
Around 41mb free Space + 10mb Extended ROM G4
Download Here:
793 Downloads
http://www.adrive.com/public/9a44264...97be84e69.html
Mirror:
http://www.4shared.com/file/113334462/cfd75f0f/NeoTitaniumRomKit.htm
Always HardReset After A Successful ROM Flash To Remove Any Previously Installed Software or Settings That Could Interfere With your New ROM Installation
Quick Tip
This reg setting allows other plugins to work with titanium so now you can have battery status running with it's great opmap overclocking feature : i have my device @ 286mhz with 299mhz boost and it works fine on my G4 soooooooooooooFaaaaaaaast
This is mealy a tip and if you damage your device trying this then it's your fault not mine ;)
[HKEY_LOCAL_MACHINE\Software\Microsoft\Today\Items\"Windows Default"]
"Exclusive"=dword:00000000
wapvirus
Can you give me the theme " today" ? :D it's very nice =D>
thanks so much.
I can give you the OEM packages that i made for this ROM or the ỏiginal cab files please tell me what you need ?
@ tayhomieu Mirror added Post#1 ;)
Thanks, I' ve downed, that's nice.
You can download here if you have problems let me know i will post the cab files ;)
http://forum.xda-developers.com/showthread.php?t=524979
wapvirus
CMultiClock ported to Neo by BlazingWolf
Features:
Large or small digital and analogue clocks
Weather
RSS Feeds
Installation Guide for Neo ROM:
1/ First you need to install Mortsript you can get that here :Download:
2/ Download Neo CMultiClock :Download:
3/ Goto Programs\Utilities\Chome Editor Disable CClock and Enable CMultiClock ,Save Order then Exit ( Soft Reset )
4/ Goto Home tab on screen and set up the settings you like to have
That's it all done ;)
wapvirus
Wapvirus : Thank for you hard work! =D>
It Mean : Can't download! Any one can upload to Mediafire Pls
Thank you Lamson for your help :)
hoangkimma I am sorry but i have uploaded to adrive and 4shared Please try those links again ;)
hwangzhiang
Quick Tip
Code:
Ai dịch cho em đoạn này với ạ? Em định Up mà đọc đoạn này thấy hơi sợ vì em Tiếng Anh kém quá,à mà sao ROM này lại là đuôi exe ạ?Em thấy nó cứ khác khác mấy ROM trước thế nào ý.
traitimbuiduong
Trời loằng ngoằng quá.Mình lại vốn dốt TA.Phải vào từng link 1 để down về sao?mà sao link die hết rồi
Shy
hix down công nhận là lằng nhằng,tại chủ topic lại là người nc ngoài e lại ngu TA :(( ai post lên mediafire đi T.T có link die bác ah :p
