WM6.1 ROM - PROPHET CE OS 5.2.20749 (Build 20749.1.4.0 PV)
Sonblack
PROPHET BLACK V1.1
===== Core 5.2.20749 Build 20749.1.4.0 PV =====
Lời cám ơn - Thanks:
Manager PhamQuang (everything)
ROM Dev Dvha79_ddt (others)
Mod Lamson (others)
Mod Hoangdat_vista (others)
Trial Mod Medkid (others)
Trial Mod PhamNhatThanh (others)
Trial Mod TranMinhMan (all skins for Calculator, Windows Media Player, Comm Manager; Theme and Welcome Screen)
Trial Mod nhocbanme (IrDA and Bluetooth)
Trial Mod khacduy1978 (GPRS)
Thông tin ROM - Information:
- Core 5.2.20749 Build 20749.1.4.0 PV
- ROM Version: 2.20.8.49 WWE
- ROM Date: 7/09/08
- Compress "LZX" standard.
- "Touch" function included.
- No bigstorage.
Hình minh họa - Illustrative Images:
Các chức năng chính - Main Functions:
- CE OS 5.2.20749 Build 20749.1.4.0 PV
- .NET Compact Framework 3.0.7283.0
- Office Mobile 6.1
- Office Note
- Windows Media Player 10.3 Build 20749 (Mod)
- ArcSoft MMS v5.0.31.19
- Advanced Configuration Tool v3.2 by Julien Schapman
- ClearTemp v1.0.3 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.55
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080704.5.1
- Total Commander CE v2.51 by Christian Ghisler
- PocketScreen v1.3 by JJM. Roseboom.
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- SDAutoRun 2.0
- and more ...
Link tải ROM - Download link: Link is available now - Link đã có sẵn.
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
Giải nén file ROM với password:
SONBLACK
Uncompress ROM file with password: SONBLACK
Máy của bạn cần được HardSPL trước khi Up ROM này!!!
Your PPC has to HardSPL before flashing this ROM!!!
Sonblack
hoangan123
chúc mừng bác với build mới...lần này chắc sẽ không có lỗi nào....^^ dạo box prophet sổi nổi nhất đặc biệt sự trở lại của bác SonBlack ^^ :D đã góp phần nên sự sôi nổi này, chắc các box khác phải ghen tỵ lắm đây:D
dioxda2
too busy days .... too many roms~~~~ >:)>:)>:)
Dear Sonblack, may I edit it and post to XDA? :)
Yes, don't worry! Help yourself! :D (Sonblack)
nguyenthuanbg_pv
Cảm ơn pác SonBlack. Chắc đây là bản Rom mới nhất tại thời điểm này rồi. Mình sẽ Up thử xem sao, đây là lần đầu tiên nên hồi hộp quá. Hic. Vừa mới lấy con Prophet Qtek hôm qua xong, còn chưa rành cách sử dụng...
phuonglev
Anh Sơn ơi bản này có giữ lại chức năng Touch của build 20749 ko?
Có đấy :)) (Sonblack)
letuankhung
=D> hoan ho bác sonblack lai cho ra đòi rom mói thanks bác nhiều dơn ve tét dây hồi hộp qua' đi mất =D>
TranMinhMan
Chúc mừng ROM Dev Sonblack với bản ROM công nghệ nén mới!=D>
Chắc freeram lên được khá nên anh mới dùng chuẩn nén "LZX" này đây!?:-? Nghe nói build chuẩn này thì phải kiếm Sever chuyên nghiệp mới chạy nổi!:p
@ Anh ra liên tục 2 bản cho Prophet, bỏ box Atom mem la quá kìa!:))
CongNam
Anh Sơn nhà mình dạo này quan tâm đến khu vực prophet ghê ta, liên tục cho ra lò những bản rom mới, anh em Prophet xin chân thành cảm ơn đại ca.=D>=D>=D>
nguyenthuanbg_pv
Các pác ơi, mình hỏi chút: cái Rom tải về có đuôi .7z thì bung nén bằng cái gì nhỉ? (Đừng cười nhé, mình gà quá). PC của mình có winrar và zip thôi. Hic.
nguyenthuanbg_pv
:D ấn chuột phải rồi extract file hoặc extract here ^^
Thanks bạn.:)
Mình search trong diễn đàn và đã lấy về được phần mềm bung nén các file dạng .7z rùi. Còn chắc tại mình dùng winrar cũ quá, cái mới hơn (v4.1 chẳng hạn) có lẽ extract được cái .7z.:-?
longak83
hình như nút "X" tắt chương trình nó bị sao ấy,bấm mãi nó mới tắt cho,thậm chí trong phần SMS bấm nút "X" thì lâu lâu nút menu ở góc phải dưới nó xổ lên lun,hem pik có pác nào bị giống như iem hok :( (nói túm lại là nút "X" không hoạt động chuẩn...:D
tundaubu
mình cũng bị lỗi này như bạn, xài bản 20749 của anh HoangAn thì k bị lỗi này
utada286
Lúc đầu mình cũng bị lỗi này, nhưng dùng được 1 lúc là OK thôi.Rom này dùng thích lắm.nhiều thứ mới nhìn rất hay.
phongit
Mình cũng bị như vậy, ROM đẹp mà bị lỗi này nên không thể đóng chương trình, chuẩn bị up bản 20748 thử đây
Sonblack
Do xung đột tính năng TOUCH và WKTask. Vào Setting của WKTask chỉnh là hết ngay thôi. :))
utada286
chỉnh như thế nào hả bác? E chỉnh mãi mà thỉnh thoảng lại bị, cứ tưởng khỏi rồi mà lâu lâu lôi ra chọt lại bị...phiền quá
saokywa
link down chậm quá, bác có mirror khác ko(shared ấy) ? Rom cute mà vẫn chưa vọc được -:(
Host PV là host xịn, mua hẵn hoi, server ở VN sao mà down chậm. Xem lại mạng nhà bạn đi :)) (Sonblack)
conmec
em dung dopod 818 chip G4 sau khi up rom thi search duoc wifi nhung ko the duyet duoc web cung nhu cac phan mem chat ko dung duoc! bac cho e biet bi loi gi dc ko a? ( rom khac thi van vao wifi va duyet web ngon lanh)
