WorldMate v7.0 SymbianOS9.by aymnahmd đã có cracked
WorldMate v7.0 SymbianOS9.cr acked by aymnahmd​
App. Name : World Mate
Version : 7.0
Release Date : May 2009
Compitability : SymbianOS9
No.1 mobile travel service
Access your travel plans
Never miss a flight
Never get lost
Never get stranded
Mobile Itinerary
Get your entire travel itinerary automatically synchronized to your mobile device. The itinerary includes all your travel bookings - flights, hotels, car rentals etc.- wherever you've booked them, plus all of your meetings. Everything is synchronized over the air with the WorldMate Live online travel planner and with your calendar, making it easy to share with your colleagues or assistant.
Online Travel Planner
Once your itinerary is created, you can easily review and complete it whenever you wish. Here is how- simply forward your confirmation emails from your PC to trips @ worldmate.com . We will automatically insert the important details into your itinerary and add the meetings from your calendar. You can then see your trip plotted on a map. We'll even remind you when stuff is missing. And since we know to what time zone you're traveling... each item will be listed in the correct time
Flight Alerts
Receive alerts in real time when your flight is delayed, cancelled or diverted. With a single click, find all the other flights which will get you to your destination in time. Get that last seat on the next flight out - before the other passengers do...
Flight Schedules
Access flight schedules for over 800 airlines, including direct and connecting flights. Plan trips ahead, or on the go. Understand your alternatives - even before you talk to the travel agent.
Smart Hotel Search
Finds the right hotel for you. Provides a customized search for a hotel near your upcoming meeting or event, taking into account your budget, star quality and preferred hotel brands. If you're stuck without a hotel and need one right away, instantly search for those around you. You can search and book both on your mobile and on the website. Searches a database of over 100,000 hotels worldwide, with guaranteed low pricing from hotels.com!
Weather Forecasts
Get 5-day weather forecasts for your destination. We'll send the forecast to you a day before your trip so you'll know what to pack.
World Clocks
View up to 5 different clocks with automatic DST corrections, so you can properly schedule those international calls. Get the local time when you land, so you're never out of sync.
Features :
- World day night map
- World currency converter , updated every hour via internet .
- Flight scheduler that tells u about the flights schedule of specific airport , airline , day , .....
- Flight status ( delayed, on time, seats available , which terminal , take-off and arrival time )
- World clocks
-world weather of specific city
-wheather forecasting of any city
-satellite images indicating the clouds movements
And much more to discover
Note : the instructions for using cra ck are included .
inside
World Mate Gold v7.0 SymbianOS9 trial resetter
Thêm thông tin bằng tiếng Việt vào bạn nhé.
BuuPhucCT
Bản này vẫn chưa hoàn chỉnh. File cài đặt thì Ok nhưng file trial reset thì có vấn đề. Dù máy mình đã hack và SIGN file này nhưng vẫn không thể cài đặt được. Bác nào rảnh thì TEST trên các dòng máy khác xem như thế nào.Máy mình là E 71.
BuuPhucCT
sao co mỗi file text vậy bạn ơi
Thì bác mở file text lên rồi dán link vào IE để tải soft về.Đây là quy định của diễn đàn mà. Bác nên đọc kỹ quy định trước.
Do tác giả up lên Zshare nên rất khó DOWNLOAD. mình xin gởi anh em link Mediafire.com cho dễ xài hơn.
BuuPhucCT
mình cài được rồi nhưng sao vào chương trình nó vẫn còn chữ active code vậy.
Bác đọc file hướng dẫn cài đặt kèm theo. File cài đặt chỉ là bản thông thường chứ không phải là bản GOLD đâu. Phải sử dụng file trial reset theo hướng dẫn mới có thể có được bản PRO. Nhưng file này có vần đề rồi.
BuuPhucCT
vậy có ai có file đầy đủ không cho mình xinh đi , đa tạ
Do đây là một dạng dịch vụ online nên khi cập nhật dữ liệu phải thông qua server chủ của hãng do đó nếu đăng ký bằng key dỏm sẽ dễ bị phát hiện lắm.
Hiện nay thì mới có cách TRIAL RESET như ở trên thôi nhưng vẫn chưa hoàn thiện. Hy vọng tác giả sẽ sớm fix lại nó.
FRLVN
Lúc đầu em dùng Wolrd Mate v5 hoặc v6 thì các tính năng Free cho update thông tin đầy đủ . Nhưng khi cài Wolrd mate V7 này thì chỉ xem được mỗi tính năng world clock, còn tất cả các tính năng khác như Weather, Currency không update được nhỉ?
BuuPhucCT
Vừa test xong, mọi thứ vẫn Update bình thường. Chỉ có những dịch vụ GOLd như cập nhật chuyến bay,hình vệ tinh... là xài thử 7 ngày. Còn thời tiết, tiền tệ vẫn update bình thường. Sao bạn không xài cái này vừa free lại có tiếng Việt Psiloc traveler tính năng hay hơn WM nhiều lại update dễ dàng.
FRLVN
Vậy để mình sài Psiloc traveler như bạn recommend thử xem. Cảm ơn bạn nhé.
MinhThang
Đã được nhắc nhở về bài viết, nhưng chủ Topic vẫn không thực hiện, tạm thời Lock khi nào Edit thì pm cho mình bạn nhé!
