XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 19960)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.19960 Build 19960.1.2.2 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.19960 Build 19960.1.2.2 PV
- Pagepool: 6M
- ROM Version: 20080715B9WWE
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 19960
- Windows Live for Windows Mobile v10.6.0034.0800
- Adobe Reader LE 2.0
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.1 by Vicott Wong
- Task Manager v3.0 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.49
- Synchro Time v0.94 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080222.3.1
- Total Commander CE v2.5 by Christian Ghisler
- Mode SMS (change message display on PPC)
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- BatteryStatus Today Plugin v0.05.126 Build 0309 by Chi-Tai Dang
- PHM TrayLaunch
- Pocket Light v1.0 by Sherwin Zadeh
- Pocket Screen v1.3 by JJM. Roseboom
Hướng dẫn - Guides:
Tải file .exe về máy. Chạy nó. Giải nén vào thư mục C:\Windows\Temp. Chạy file Device Software Update Utility.exe từ thư mục này để up rom.
Download the .exe file to PC. Execute it. Uncompress to folder
C:\Windows\Temp. Run file Device Software Update Utility.exe from this folder for flashing rom.
Link đã có sẵn.
The link is available now.
ATOM ROM 19960 - PDAVIET
PASSWORD for uncompress: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Up cả EXtendedROM để có được giao diện màu đen của Wireless Manager.
Flashing with option "Update Item" is "OS+EXtendedROM" for having black skin of
Wireless Manager.
Cứ thong thả mà test rom, chỉ số chưa quan trọng bằng ROM thế nào đâu
Chúc vui.
Enjoy it.
Sonblack
bác Sơn Black này làm ROM kô biết mệt . Hihi. Tiếc là hok có xài Atom nên hok up được ROM của Bác. Nhưng nhìn thèm quá :D. Thanks Bác
takaru
bản rom này mình chưa thử . Mình xin phép đưa ra so sánh về giao diện ( mình dựa vào ảnh mà anh Sơn đưa lên ) thì thấy HTC home có giao diện đẹp hơn , có 1 số chương trình a Sơn đã tích hợp thêm vào và 1 số được update lên .Tuy nhiên giao diện của DIALPAD , Windowmedia cũng như keyboard , máy tính không được đẹp như bản 20266 . Mình thích màu đen . Mong bản rom tới của a Sơn sẽ có HTC home như bản 19960 , các giao diện về windowmedia , keyboard , máy tính .... như của bản 20266 . về DIALPAD mình muốn a Sơn edit giống cái ảnh bên dưới . Bản 20266 là bản mà mình thấy ưng ý nhất ( nếu skin của HTC home màu đen , tuy nhiên mình vẫn cứ thích )
Rất cám ơn anh Sơn và các mod cũng như các mem trong thời gian qua đã chia sẻ
takaru
Đêm qua buồn ngủ quá không đợi được anh Sơn post bản 19965 lên . Sáng ngủ dậy phải vào pdaviet ngay . Tiếc là anh Sơn vẫn chưa post lên . A Sơn cố lên !
mykolor
mình thấy nó same same như nhau cả, anh SonBlack có thể đưa ra bảng so sánh giữa các bảng ROM của anh cho anh em tham khảo được không ạ.
Tiêu chí của em là tốc độ, ổn định và vấn đề ngốn pin của ROM.
Cảm ơn anh vì sự đam mê build ROM của anh :)
Nếu phải làm 1 bảng so sánh thì nghỉ build rom sướng hơn bạn à! Bạn cũng thừa biết mình làm vì đam mê, còn công việc chính là kinh doanh. Đâu có tgian đâu để làm cái "vô tích sự" ấy. Vô tích sự ở chỗ build mới ra hàng ngày, so sánh để làm gì.
hanbaoquan
em nghĩ bàn phím trong bản Rom mới nên có màu đen nhiwnf cho đẹp,và windows media nên lấy giao diện của windows 11 trông nó đẹp với HTC Home hơn
VOKE
đang dùng bản 20266 thấy ok , giao diện đẹp , chạy nhanh hơn ... nên cứ dùng đã ...
Cho hỏi , mình ko muốn dùng HTC Home làm nền mà thích cái để mặc định cái SPB Mobile Shell , cái nào tốn pin nhiều hơn nhỉ và dùng các cái Plugin này làm nền thì tốn pin nhiều lắm ko so với khi để mặc định nền Windows.
TranMinhMan
Việc tốn pin ít hay nhiều là do cảm nhận tương đối của mỗi người, bạn tự mình test thử xem seo!?:p
nikworld07
are these sony xperia ones or kaiser roms?
Build 19960 from SHIP ROM of Raphael
Build 19965 from SHIP ROM of Diamond
ROM ổn, không thấy (hoặc chưa thấy) lỗi, hồng ngoại vẫn chưa hoạt động đúng như mong đợi. Để ngay trước mắt hồng ngoại của PC mà vẫn không nhận, cũng như PC send file qua không được. Chỉ khi kích hoạt chức năng nhận file qua hồng ngoại của c.trình Total Commander thì mới send file từ PC qua phone được. Ngoài việc đó ra send từ phone qua PC vẫn hoạt động bình thường. (đương nhiên là đã thử check và uncheck option "Recieve incoming beam").
Bản này có vẻ chạy ít tốn pin hơn bản build 20226 nhiều. Qua 1 ngày chờ và chơi game, gọi vài cuốc đt, config máy, cài đặt c.trình (qua thẻ nhớ chứ không cắm cáp sync)... đến sáng hôm nay check lai thì còn được đến 71% pin.
Keep up the good works.
Thanks.
ps: có vẻ như bản này hoạt động trơn tru hơn phiên bản build 19965. Bản build 19965 hình như nhiều người gặp lỗi.
maitaison
EM MỚI VÀO NHƯNG THẤY CÁC BÁC NÓI HAY WA EM VỀ LIỀU UP ROM MỘT PHEN
CÁI KON MÁY EM ĐANG DÙNG KO BIẾT VÌ LÍ DO GÌ MÀ LOA CỦA NÓ NGHE NHƯ ÔNG CỤ BỊ HEN ẤY NÓ RÈ KO TÀI NÀO MÀ NGHE ĐƯỢC
maitaison
em up xong rùi chạy rất ngon nhưng ko khắc phục được cái loa rè bác nào biết thì chỉ cho em với
boeing
Cái này có lẽ là do loa rồi, bạn thử cách này coi sao nhé: vào Star/Programs/Media/Equalizer rồi set lại coi sao (nên giảm bớt bass cho nó bớt rè)
Good luk
1413
Mình đã nghịch với registry và giờ thì hồng ngoại nó hoạt động đúng như xưa. Chỉ cần bật đt lên và để ngay mắt hồng ngoại của PC là PC nhận được sau khoảng 2-3s.
(thực sự là chả nhớ mình dọc những gì trong registry nữa)
còn Bluetooth và wifi vẫn hoạt động tốt như bình thường.
Mình thích bản ROM này nhất vì đã được tích hợp PocketLight. PocketLight này điều khiển được camera flash rất tốt. Mình đang tìm cách tách chương trình này ra nhưng vẫn chưa thành công.
